ABC is fixed. Thanks.
start of FREE CABLE plugin
18:51:26 T:4573908992 NOTICE: DEBUG Entering play function
18:51:26 T:4573908992 NOTICE: Using proxy: http://*****:3128
18:51:26 T:4573908992 NOTICE: FREE CABLE --> common :: getURL :: url = http://link.theplatform.com/s/dJ5BDC/udjqsOhRzbQT?format=SMIL&Tracking=true&mbr=true
18:51:26 T:4573908992 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: 'NoneType' object is unsubscriptable
File "/Users/*/Library/Application Support/XBMC/addons/plugin.video.free.cable/default.py", line 68, in <module>
modes ( )
File "/Users/*/Library/Application Support/XBMC/addons/plugin.video.free.cable/default.py", line 64, in modes
exec 'sitemodule.%s()' % common.args.sitemode
File "<string>", line 1, in <module>
File "/Users/*/Library/Application Support/XBMC/addons/plugin.video.free.cable/resources/lib/cbs.py", line 482, in play
data=common.getURL(url,proxy=proxy)
File "/Users/*/Library/Application Support/XBMC/addons/plugin.video.free.cable/resources/lib/_common.py", line 729, in getURL
response = urllib2.urlopen(req)
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 126, in urlopen
return _opener.open(url, data, timeout)
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 391, in open
response = self._open(req, data)
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 409, in _open
'_open', req)
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 369, in _call_chain
result = func(*args)
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 698, in <lambda>
meth(r, proxy, type))
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib2.py", line 707, in proxy_open
if req.host and proxy_bypass(req.host):
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib.py", line 1404, in proxy_bypass
return proxy_bypass_macosx_sysconf(host)
File "/Applications/XBMC.app/Contents/Frameworks/lib/python2.6/urllib.py", line 1378, in proxy_bypass_macosx_sysconf
mask = int(m.group(2)[1:])
TypeError: 'NoneType' object is unsubscriptable
18:51:26 T:140735246823808 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.free.cable/?url="udjqsOhRzbQT"&mode="cbs"&sitemode="play"]
18:51:27 T:4573908992 NOTICE: Thread Background Loader start, auto delete: false
