Full Version: XBMC Constellation For iPad/iPhone by FSS.cc (unofficial remote)
Hello All Smile This is my first post on this forum so I Would like to introduce myself and XBMC Constellation. A new remote for iPad/iPhone.
Forum about XBMC Constellation:
http://constellation.ictcsc.net/
Facebook FanPage
Features:
-Movie library support
-Remote (buttons/gestures)
-Audio library support
-Tv Show library support(banners/posters)
-YouTube search your movies on iPad and play on XBMC
-Cinema Experience Script support (hold play in movies for 2s) (experimental)
-XBMC Subtitles script support
-FaceBook (post your recently watched movies/episodes strate to your wall)
Integrates:
-CouchServer v2
-Headphones
-SABnzbd
-SickBeard
-Trakt.tv
..and much much more.. Just go ahed and try its Free(ad supported)
How to set up XBMC and the XBMC Constellation: http://www.youtube.com/watch?v=pOVUEeHJAfQ
Available on Appstore
http://facebook.com/xbmc.constellation
<Place Holder....>
im already install on my iphone4 - ***** awsomeBig GrinBig GrinBig GrinBig Grin
I just downloaded it on iPad. Love the design and the volume knob is a kicker Smile.
I nice peace of work!!! From today this is my nr 1 for ipad Smile
PS.
I'm missing 1 thing picture integration... Can I make a feature request on that ?
Regards.
I've just installed (and bought) Constellation on my iPad.
I like the design and controls.
Connecting to XBMC was easy. So far so good.
I'm able to use the remote functions, that works just fine.
But unfortunately, I can't get my libraries visible in the application. Nothing shows up, the screens remain black.
@FSS_Dawid: any idea?
I must say, this remote looks promising!
Keep up the good work!
For some reason the app crash when I try to play a video on my iPhone4
I can't seem to get it to work. I do as instructed in the YouTube video, I passed the test but the http status shows "Failed" and the JSON RPC status shows "disconnected.
What am I doing wrong?
Thanks in advance.
not2fast Wrote:I've just installed (and bought) Constellation on my iPad.
Well I don't actually know how to tell you this and not make a big idiot out of myself Smile One of our developers put a # (commented out) a line of code that was responsible for syncing the library Smile The update fixing this issues has been submitted to app store. I have also filled in a request to get this update a bigger priority. I can send you an ad-hoc distribution version if You provide me your UUID od the devices...
Confused I really apologize for the inconvinience.
Well you can call this a big fail start Smile as a project manager for this one Im heading to a pub...
PS
The library works ok with XBMC v10
uuuh_hello Wrote:For some reason the app crash when I try to play a video on my iPhone4
Hmm strange it works ok on my ip4 try killing some other processes it's possible that you are low on memory. We will have a look @ this tomorrow.
meh1965 Wrote:I can't seem to get it to work. I do as instructed in the YouTube video, I passed the test but the http status shows "Failed" and the JSON RPC status shows "disconnected.
Thanks in advance.
do you have port 9090 open ? If you are using windows you have to open port 9090 (the json-rpc port to get this remote to work) on you system firewall.
Nice work, I can't see anywhere that you can view the Now Playing controls? Also on the iOS 5 beta the "Pull this view down to explore more" doesn't work on the iphone. It clashes with the notification drag down bar. I'm assuming this is where the controls are, but it is impossible to look at them because the activation zone of the drag down is the same as notifications.
You've already got a purchase through me though, it looks like a very promising start to the project.
ProphetVX Wrote:You've already got a purchase through me though, it looks like a very promising start to the project.
thx Big Grin
The IOS 5 Covers the pulldown bar for our remote... so you can't access the now playing features. The IOS 5 should not do that in fullscreen apps. but its still in beta so it does Wink
FSS_Dawid Wrote:do you have port 9090 open ? If you are using windows you have to open port 9090 (the json-rpc port to get this remote to work) on you system firewall.
I have a Mac Mini running XBMC.
FSS_Dawid
ive just downloaded and installed it
The library doesnt work for me not in xbmc v10 and not in any beta builds .
any eta when the fix is going to released?
thx in advance
moshelog
I installed it early this morning (like 4ish hours ago) and it showed the correct number of albums but the TV and Movies had the wrong count and pretty much anything I tried to do would cause the app to outright freeze so I had to force quit and when I reopened it, it'd just do the same thing... I've been able to play for a couple minutes at a time and really like some of the views and other things, just not sure why it's crashing like this.
Specs:
64GB iPad (1st Gen) Wifi Only Model running 4.3.3
XBMC running on Windows 7 Ultimate x64
222 Albums in Music Library
500+ Movies and 240+ TV Shows (over 10,000 Episodes)
Any ideas?
