(2013-02-10, 14:53)acejh1987 Wrote: [ -> ] (2013-02-10, 02:26)deadspeak Wrote: [ -> ]did'nt copy it into the threat correctly it is as per below.
The files look good to me, if possible could you post up a logfile?
Here you go.
22:36:06 T:3936 NOTICE: -----------------------------------------------------------------------
22:36:06 T:3936 NOTICE: Starting XBMC (12.0 Git:20130127-fb595f2), Platform: Windows 7 SP1 64-bit, build 7601. Built on Jan 28 2013 (compiler 1600)
22:36:06 T:3936 NOTICE: Intel® Core i3 CPU 530 @ 2.93GHz
22:36:06 T:3936 NOTICE: Desktop Resolution: 1920x1080 32Bit at 50Hz
22:36:06 T:3936 NOTICE: Running with restricted rights
22:36:06 T:3936 NOTICE: Aero is disabled
22:36:06 T:3936 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
22:36:06 T:3936 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
22:36:06 T:3936 NOTICE: special://masterprofile/ is mapped to: C:\Users\Paul\AppData\Roaming\XBMC\userdata
22:36:06 T:3936 NOTICE: special://home/ is mapped to: C:\Users\Paul\AppData\Roaming\XBMC\
22:36:06 T:3936 NOTICE: special://temp/ is mapped to: C:\Users\Paul\AppData\Roaming\XBMC\cache
22:36:06 T:3936 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
22:36:06 T:3936 NOTICE: Local hostname: HTPC2012-PC
22:36:06 T:3936 NOTICE: Log File is located: C:\Users\Paul\AppData\Roaming\XBMC\xbmc.log
22:36:06 T:3936 NOTICE: Enumerated DirectSound devices:
22:36:06 T:3936 NOTICE: Device 1
22:36:06 T:3936 NOTICE: m_deviceName : {0E2D1A3E-C79D-4349-B1BB-4E179683B9F8}
22:36:06 T:3936 NOTICE: m_displayName : SPDIF - Digital Audio (S/PDIF) (2- High Definition Audio Device)
22:36:06 T:3936 NOTICE: m_displayNameExtra: DirectSound: Digital Audio (S/PDIF) (2- High Definition Audio Device)
22:36:06 T:3936 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
22:36:06 T:3936 NOTICE: m_channels : FL,FR
22:36:06 T:3936 NOTICE: m_sampleRates : 44100
22:36:06 T:3936 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3
22:36:06 T:3936 NOTICE: Device 2
22:36:06 T:3936 NOTICE: m_deviceName : {403EBB3F-C8B4-4C05-B8EC-18215A361518}
22:36:06 T:3936 NOTICE: m_displayName : HDMI - SONY AVAMP (Intel® Display Audio)
22:36:06 T:3936 NOTICE: m_displayNameExtra: DirectSound: SONY AVAMP (Intel® Display Audio)
22:36:06 T:3936 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
22:36:06 T:3936 NOTICE: m_sampleRates : 48000
22:36:06 T:3936 NOTICE: Enumerated WASAPI devices:
22:36:06 T:3936 NOTICE: m_displayNameExtra: WASAPI: Digital Audio (S/PDIF) (2- High Definition Audio Device)
22:36:06 T:3936 NOTICE: m_sampleRates : 192000,96000,88200,48000,44100
22:36:06 T:3936 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
22:36:06 T:3936 NOTICE: m_displayNameExtra: WASAPI: SONY AVAMP (Intel® Display Audio)
22:36:06 T:3936 NOTICE: m_channels : FL,FR,FC,LFE,SL,SR,BL,BR
22:36:06 T:3936 NOTICE: m_sampleRates : 192000,176400,96000,88200,48000,44100,32000
22:36:06 T:3936 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
22:36:06 T:3936 NOTICE: load settings...
22:36:06 T:3936 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:36:06 T:3936 NOTICE: loading special://masterprofile/guisettings.xml
22:36:06 T:3936 NOTICE: Getting hardware information now...
22:36:06 T:3936 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
22:36:06 T:3936 NOTICE: Loaded playercorefactory configuration
22:36:06 T:3936 NOTICE: Loading player core factory settings from special://profile/playercorefactory.xml.
22:36:06 T:3936 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
22:36:06 T:3936 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
22:36:06 T:3936 NOTICE: Default DVD Player: dvdplayer
22:36:06 T:3936 NOTICE: Default Video Player: dvdplayer
22:36:06 T:3936 NOTICE: Default Audio Player: paplayer
22:36:06 T:3936 NOTICE: Disabled debug logging due to GUI setting. Level 0.
22:36:06 T:3936 NOTICE: Log level changed to 0
22:36:06 T:3936 NOTICE: Loading media sources from special://masterprofile/sources.xml
22:36:06 T:1884 NOTICE: Thread CSoftAE start, auto delete: false
22:36:06 T:3936 NOTICE: Running database version Addons15
22:36:06 T:6192 NOTICE: Thread CRemoteControl start, auto delete: false
22:36:06 T:3936 NOTICE: Found screen: Generic PnP Monitor on Intel® HD Graphics, adapter 0.
22:36:06 T:3936 NOTICE: Primary mode: 1920x1080 @ 50.00 - Full Screen
22:36:06 T:8572 NOTICE: Thread XBMC Peripherals start, auto delete: false
22:36:06 T:3936 NOTICE: Additional mode: 640x480 @ 59.94 - Full Screen
22:36:06 T:3936 NOTICE: Previous line repeats 2 times.
22:36:06 T:3936 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 720x480 @ 59.94 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 720x576 @ 50.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1152x864 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1280x600 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1280x720 @ 50.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1280x720 @ 59.94 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1280x960 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1280x1024 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1360x768 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1366x768 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1400x1050 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1440x480 @ 59.94 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1440x480 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1440x480 @ 30.00i - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1440x576 @ 50.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1440x576 @ 25.00i - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1440x900 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1600x900 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Previous line repeats 1 times.
22:36:06 T:3936 NOTICE: Additional mode: 1680x1050 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1920x1080 @ 50.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1920x1080 @ 25.00i - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1920x1080 @ 59.94 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1920x1080 @ 29.97i - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1920x1080 @ 60.00 - Full Screen
22:36:06 T:3936 NOTICE: Additional mode: 1920x1080 @ 30.00i - Full Screen
22:36:06 T:3936 NOTICE: Checking resolution 16
22:36:07 T:3936 NOTICE: Running database version Addons15
22:36:07 T:3936 NOTICE: Running database version ViewModes4
22:36:07 T:3936 NOTICE: Running database version Textures13
22:36:07 T:3936 NOTICE: Running database version MyMusic32
22:36:07 T:3936 NOTICE: Running database version MyVideos75
22:36:07 T:3936 NOTICE: Running database version TV22
22:36:07 T:3936 NOTICE: Running database version Epg7
22:36:07 T:3936 NOTICE: initializing playlistplayer
22:36:07 T:3936 NOTICE: DONE initializing playlistplayer
22:36:09 T:6476 NOTICE: Thread XBPyThread start, auto delete: false
22:36:09 T:6476 NOTICE: Previous line repeats 2 times.
22:36:09 T:6476 NOTICE: -->Python Interpreter Initialized<--
22:36:09 T:6300 NOTICE: Thread XBPyThread start, auto delete: false
22:36:09 T:3936 NOTICE: Previous line repeats 1 times.
22:36:09 T:3936 NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
22:36:09 T:1716 NOTICE: -->Python Interpreter Initialized<--
22:36:09 T:6272 NOTICE: -->Python Interpreter Initialized<--
22:36:09 T:3844 NOTICE: Thread CVideoInfoScanner start, auto delete: false
22:36:09 T:3936 NOTICE: initialize done
22:36:09 T:6504 NOTICE: Thread XBPyThread start, auto delete: false
22:36:09 T:3936 NOTICE: Running the application...
22:36:09 T:3936 NOTICE: ES: Starting event server
22:36:09 T:6064 NOTICE: Thread CEventServer start, auto delete: false
22:36:09 T:6064 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
22:36:09 T:6064 NOTICE: UDP: Listening on port 9777
22:36:09 T:7784 NOTICE: Thread CTCPServer start, auto delete: false
22:36:09 T:3844 NOTICE: VideoInfoScanner: Starting scan ..
22:36:09 T:6300 NOTICE: -->Python Interpreter Initialized<--
22:36:09 T:4960 NOTICE: Thread Jobworker start, auto delete: true
22:36:09 T:8652 NOTICE: -->Python Interpreter Initialized<--
22:36:09 T:6504 NOTICE: -->Python Interpreter Initialized<--
22:36:09 T:1068 NOTICE: -->Python Interpreter Initialized<--
22:36:10 T:6272 NOTICE: Artwork Downloader: ## Service - Run at startup: False
22:36:10 T:6272 NOTICE: Artwork Downloader: ## Service - Delayed startup: minutes
22:36:10 T:6272 NOTICE: Artwork Downloader: ## Service - Run as service: False
22:36:10 T:6272 NOTICE: Artwork Downloader: ## Service - Time: :00
22:36:10 T:6504 NOTICE: StorageServer Module loaded RUN
22:36:10 T:6504 NOTICE: StorageClient-2.5.0 Starting server
22:36:10 T:6504 NOTICE: StorageServer-2.5.0 Storage Server starting C:\Users\Paul\AppData\Roaming\XBMC\userdata\addon_data\script.common.plugin.cache\commoncache.db
22:36:13 T:5580 NOTICE: Thread Jobworker start, auto delete: true
22:36:13 T:5352 NOTICE: Thread XBPyThread start, auto delete: false
22:36:13 T:5352 NOTICE: -->Python Interpreter Initialized<--
22:36:13 T:7288 NOTICE: Thread Jobworker start, auto delete: true
22:36:13 T:8080 NOTICE: Thread CAlarmClock start, auto delete: false
22:36:13 T:1232 NOTICE: Thread Jobworker start, auto delete: true
22:36:18 T:3844 WARNING: No information found for item 'smb://SERVER/Blu-Ray Movies/Alien Anthology/Making The Alien Anthology - Disk 5/Making The Alien Anthology - Disk 5.iso', it won't be added to the library.
22:36:19 T:3844 WARNING: No information found for item 'smb://SERVER/Blu-Ray Movies/Alien Anthology/The Alien Anthology Archives - Disk 6/The Alien Anthology Archives - Disk 6.iso', it won't be added to the library.
22:36:19 T:4960 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 28
22:36:19 T:4960 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
22:36:19 T:4960 ERROR: XFILE::CFileCache::Open - failed to open source <http://mirrors.xbmc.org/addons/frodo/addons.xml.md5>
22:36:19 T:3844 WARNING: No information found for item 'smb://SERVER/Blu-Ray Movies/Blade Runner/Blade Runner - Disc 4 Enhancement Archive/Disc 4 Enhancement Archive.iso', it won't be added to the library.
22:36:20 T:3844 WARNING: No information found for item 'smb://SERVER/Blu-Ray Movies/Blade Runner/Blade Runner - Disk 1 The Final Cut/Blade Runner - Disk 1 The Final Cut.iso', it won't be added to the library.
22:36:20 T:3844 WARNING: No information found for item 'smb://SERVER/Blu-Ray Movies/Blade Runner/Blade Runner - Disk 2 Dangerous Days Making Blade Runner/Blade Runner - Disk 2 Dangerous Days Making Blade Runner.iso', it won't be added to the library.
22:36:21 T:3844 WARNING: No information found for item 'smb://SERVER/Blu-Ray Movies/Blade Runner/Blade Runner - Disk 3 3 versions/Disc 3 U.S. Theatrical Cut (1982), International Theatrical Cut (1982), Director's Cut (1992).iso', it won't be added to the library.
22:36:21 T:3844 WARNING: No information found for item 'smb://SERVER/Blu-Ray Movies/Blade Runner/Blade Runner - Disk 5 Workprint/Blade Runner - Disk 5 Workprint.iso', it won't be added to the library.
22:36:22 T:3844 WARNING: No information found for item 'smb://SERVER/Blu-Ray Movies/Star Wars - The Complete Saga/Disk 1 - Bonus Disk Episodes I-III Archives/Disk 1 - Bonus Disk Episodes I-III Archives.iso', it won't be added to the library.
22:36:23 T:3844 WARNING: No information found for item 'smb://SERVER/Blu-Ray Movies/Star Wars - The Complete Saga/Disk 2 - Bonus Disk Episodes IV-VI Archives/Disk 2 - Bonus Disk Episodes IV-VI Archives.iso', it won't be added to the library.
22:36:23 T:3844 WARNING: No information found for item 'smb://SERVER/Blu-Ray Movies/Star Wars - The Complete Saga/Disk 3 - Bonus Disk Documentaries & Spoofs/Disk 3 - Bonus Disk Documentaries & Spoofs.iso', it won't be added to the library.
22:36:24 T:3844 WARNING: No information found for item 'smb://SERVER/Movie Downloads Blu-Ray Disks/Kick-Ass (2011)/Kick-Ass.mkv', it won't be added to the library.
22:36:24 T:3844 WARNING: No information found for item 'smb://SERVER/Movie Downloads Blu-Ray Disks/Tha Amazing Spiderman/Tha Amazing Spiderman.mkv', it won't be added to the library.
22:36:24 T:3844 WARNING: VIDEO::CVideoInfoScanner:
rocess directory 'smb://SERVER/Movie Downloads Blu-Ray Disks/Tombstone/' does not exist - skipping scan.
rocess directory 'smb://SERVER/Movie Downloads Blu-Ray Disks/Toy Story 2/' does not exist - skipping scan.
rocess directory 'smb://SERVER/Movie Downloads Blu-Ray Disks/Toy Story 3/' does not exist - skipping scan.
rocess directory 'smb://SERVER/Movie Downloads Blu-Ray Disks/Toy Story/' does not exist - skipping scan.
rocess directory 'smb://SERVER/Movie Downloads Blu-Ray Disks/Up/' does not exist - skipping scan.
rocess directory 'smb://SERVER/Movie Downloads Blu-Ray Disks/Wall-E/' does not exist - skipping scan.
rocess directory 'smb://SERVER/Movie Downloads Blu-Ray Disks/War Of The Worlds/' does not exist - skipping scan.
rocess directory 'smb://SERVER/Movie Downloads Blu-Ray Disks/Woman In Black/' does not exist - skipping scan.
22:36:26 T:3844 WARNING: No information found for item 'smb://SERVER/Movie Downloads/Peterpan/Peterpan.mkv', it won't be added to the library.
22:36:27 T:8204 NOTICE: Thread Background Loader start, auto delete: false
22:36:27 T:3844 WARNING: No information found for item 'smb://SERVER/Movies/Pirates Of The Carribean (The Curse Of The Black Pearl)/Pirates Of The Carribean (The Curse Of The Black Pearl).mkv', it won't be added to the library.
22:36:28 T:3844 WARNING: VIDEO::CVideoInfoScanner:
rocess directory 'smb://SERVER/Tv/American Horror Story/' does not exist - skipping scan.
rocess directory 'smb://SERVER/Tv/An Idiot Abroad/' does not exist - skipping scan.
rocess directory 'smb://SERVER/Tv/Rev/' does not exist - skipping scan.
rocess directory 'smb://SERVER/Tv/True Blood/' does not exist - skipping scan.
22:36:28 T:3844 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:19
22:36:29 T:6376 NOTICE: Thread Background Loader start, auto delete: false
22:36:32 T:1232 ERROR: DVDFileSeekForce - ignored size of file indicated in UDF
22:36:33 T:3936 ERROR: Previous line repeats 99 times.
22:36:33 T:3936 WARNING: Trying to add unsupported control type 1
22:36:33 T:1420 NOTICE: Thread CFileCache start, auto delete: false
22:36:44 T:4960 NOTICE: Previous line repeats 1 times.
22:36:44 T:4960 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 28
22:36:44 T:4960 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
22:36:44 T:4960 ERROR: XFILE::CFileCache::Open - failed to open source <http://mirrors.xbmc.org/addons/frodo/service.watchdog/service.watchdog-0.7.1.zip.md5>
22:36:49 T:3936 NOTICE: Storing total System Uptime
22:36:49 T:3936 NOTICE: Saving settings
22:36:49 T:3936 NOTICE: stop all
22:36:49 T:3936 NOTICE: ES: Stopping event server
22:36:49 T:3936 NOTICE: stopping zeroconf publishing
22:36:50 T:6064 NOTICE: ES: UDP Event server stopped
22:36:50 T:3936 NOTICE: stop sap announcement listener
22:36:50 T:3936 NOTICE: clean cached files!
22:36:50 T:3936 NOTICE: unload skin
22:36:55 T:3936 ERROR: XBPyThread:
top - script C:\Users\Paul\AppData\Roaming\XBMC\addons\service.skin.widgets\default.py didn't stop in 5 seconds - let's kill it
22:36:55 T:6504 NOTICE: StorageServer-2.5.0 Closed down
22:37:00 T:3936 ERROR: XBPyThread:
top - script C:\Users\Paul\AppData\Roaming\XBMC\addons\service.watchdog\service.py didn't stop in 5 seconds - let's kill it
22:37:00 T:3936 NOTICE: stop python
22:37:00 T:1716 WARNING: The python script "C:\Users\Paul\AppData\Roaming\XBMC\addons\service.skin.widgets\default.py" has left several classes in memory that we couldn't clean up. The classes include: Window,Monitor,Player
22:37:01 T:3936 NOTICE: stopped
22:37:01 T:3936 NOTICE: destroy
22:37:01 T:3936 NOTICE: closing down remote control service
22:37:01 T:3936 NOTICE: unload sections
22:37:01 T:3936 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
22:37:01 T:3936 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
22:37:01 T:3936 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
22:37:01 T:3936 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
22:37:01 T:3936 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
22:37:01 T:3936 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
22:37:01 T:3936 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
22:37:01 T:3936 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
22:37:01 T:3936 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
22:37:01 T:3936 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
22:37:01 T:3936 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
22:37:01 T:3936 NOTICE: application stopped...
