Full Version: Another External Player Code, but Very Simple to Setup
@Ghostdivision-
I'm not entirely sure what you are trying to do. I use both TMT5, 7MCE and XBMC on all my HTPC's, and it never crash on me. 7MCE is mainly use for Netflix and Live HD OTA.....I can launch XBMC through 7MCE. I use this little software "XBMC Windows 7 Media Center Integration 2.1" to tie XBMC to 7MCE. Both XBMC and 7MCE uses TMT5 for external player. It work great......
Here is my 7mce screen shot-
Well basically if you use the latest version with automatic refresh rate switching and have automatic refresh rate enabled, arcsoft is telling me it will produce a crash when i close it (only with the mce player), because we launch it using a command line, and not the player loader. Why that matters i have no idea, they should really work it out on their end but have not.
Not really something i think you can correct unless its possible to call up the tmt mce player not using command line but using the "playerloader" as he put it. I just thought i would ask. I dont even know what he means by playerloader, but apparently media browser users have correct it, by calling up the playerloader.
If you dont care about automatic refresh rate switching it wont crash upon exit and none of this matters. Unfortunately automatic refresh rate switching is a must for me, blurays just look improper being output at incorrect refresh rate to my eyes.
Basically if you have this enabled in the mce player, and you use an ati card, it will crash when close it...
http://oi48.tinypic.com/29zbdx0.jpg
While not a good solution at all a poor workaround but one that works, i dont see or notice the crash report anymore by disabling windows crash report gui.
HKEY_CURRENT_USER\Software\ Microsoft\Windows
\Windows Error Reporting\Dont Show UI = 1
The crash did not do anything negative, it was just bothersome when i closed the program everytime i received a crash report.
? Not quite sure if your referring to the playercorefactory bluray posted for me, but he was using my path i use on my pc.
Was a nice detail he included.
(2012-06-28, 07:45)Ghostdivision Wrote: [ -> ]Basically if you have this enabled in the mce player, and you use an ati card, it will crash when close it...
It seems that the crash have nothing to do with XBMC, TMT5 and playercorefactory.xml code then.....it's an issue between 7MCE and TMT5. Is the screen shot you posted 7MCE or TMT5 playback screen shot?
Hi there,
was anyone succesful on integrating PowerDVD12?
I want to use internal player as default and PowerDVD to play file wih mask *.3dbd.*
So my playerfactory.xml look like this:
<playercorefactory>
    <players>
        <player name="PowerDVD" type="ExternalPlayer" audio="false" video="true">
            <filename>c:\Program Files (x86)\CyberLink\PowerDVD12\PowerDVD12.exe</filename>
            <args>"{1}"</args>
            <hidexbmc>false</hidexbmc>
            <hideconsole>false</hideconsole>
            <warpcursor>none</warpcursor>
        </player>
        <player name="PowerDVDISO" type="ExternalPlayer" audio="false" video="true">
            <filename>c:\batches\PlayISOPowerDVD.bat</filename>
            <args>"{1}"</args>
        </player>
    </players>
    <rules action="prepend">
        <rule filetypes="iso" filename="*.3dbd.*" player="PowerDVDISO"/>
    </rules>
        <rule filetypes="mkv" filename="*.3dbd.*" player="PowerDVD"/>
    </rules>
</playercorefactory>
My problem is that the PowerDVD Task ends immediately or isn't even created. When i play an iso file i can see the batch job starting, so the problem doesn't seem to be the playercorefactory. When i start the same command from outside XBMC PowerDVD starts up and plays the file just fine.
Any ideas someone?
@poetter,
You can try the codes below (you need to replace everything marked in RED to match your HTPC and you can name your movie this way- Avatar_3dbd.iso):
Playercorefactory.xml:
<playercorefactory>
</player>
<player name="ISO_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\HTPC\AppData\Roaming\XBMC\userdata\PlayISO.bat</filename>
<args>"{1}"</args>
<hidexbmc>true</hidexbmc>
<hideconsole>true</hideconsole>
</player>
</players>
<rule filename=".*_3dbd.iso*" protocols="*_3dbd.iso*" player="ISO_Player"/>
</rules>
PlayISO.bat:
@echo off
"C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 %1
"C:\Program Files (x86)\CyberLink\PowerDVD12\PDVDLaunchPolicy.exe" K:
Hey again,
I'm getting some very weird results.... Tryed it on Win 7 x64 and x86.
Only installed the following...
Win 7 Ultra (x64/x86) + latest drivers + all updates
MS SQL Server 2008 R2 SP3 (x64/x86)
ForTheRecord Server, Argus tuner, Management console and Argus management console
Cyberlink PowerDVD Ultra 12.0.1618.54
SlySoft Virtual CloneDrive 5.4.5.0
SlySoft AnyDVD HD 6.9.1.0
And of course XBMC, but different versions...
XBMC v11.0 Eden official build (Without SQL Server and ForTheRecord)
XBMC v11.0 Eden PVR v3 margro build
Each time I changed XBMC to a different version, i started all over with a fresh Windows installation.
As you might have figured out, there's 4 possible combinations...
1. Win 7 x86 + XBMC official (Without SQL Server and ForTheRecord)
2. Win 7 x86 + XBMC PVR margro
3. Win 7 x64 + XBMC official (Without SQL Server and ForTheRecord)
4. Win 7 x64 + XBMC PVR margro
The first combination works fine, after changing directories and drives in the bat and xml files to the appropriate ones.
The second, third and fourth combination starts PowerDVD, mounts the image, but unmounts it again before getting a chance to start the movie. And sometimes i get a "disc with unsupported format in drive x:" error.
What i did was remove the unmount command line i the PlayISO.bat file and that worked for images. Although it takes quite some time to mount and start the movie. And of course playing discs still doesn't work.
Any Ideas on what I should be trying with the PVR builds (I'd like to be able to watch Live-TV as well as using external players)? Smile
Thanks a lot m8! Wink
(2012-07-01, 00:06)Hessi Wrote: [ -> ]And of course playing discs still doesn't work.
Can you post your playercorefactory code in here? For Live TV, I use this "post #751".....
Hi. I'm not sure why but I have some mp4s that when I launch from the videos section tmt gets launched. Besides that, everything else seems to be working normally. Playcorefactory detail below
<playercorefactory>
<players>
<filename>C:\Users\Andy D\AppData\Roaming\XBMC\userdata\PlayISO.bat</filename>
<args>"{1}" /fullscreen</args>
</player>
<player name="BDMV_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Andy D\AppData\Roaming\XBMC\userdata\PlayBDMV.bat</filename>
</player>
<player name="Disc_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Andy D\AppData\Roaming\XBMC\userdata\PlayDisc.bat</filename>
</player>
<player name="Universal_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uMCEPlayer5.exe</filename>
</player>
</players>
<!-- Bluray ISO -->
<rule filename=".*iso.*" player="ISO_Player"/>
<!-- Bluray BDMV -->
<rule filename=".*bdmv.*" player="BDMV_Player"/>
<!-- Bluray M2TS -->
<rule filename=".*m2ts.*" player="Universal_Player"/>
<!-- Bluray Disc -->
<rule protocols="bd|dvd" player="Disc_Player"/>
</rules>
@andy.....
You need to tight up the rules a little bit........here are your rules:
<!-- Bluray ISO -->
<rule filename=".*iso.*" filetype="iso" player="ISO_Player"/>
<rule filename=".*bdmv.*" filetype="bdmv" player="BDMV_Player"/>
<rule filename=".*m2ts.*" filetype="m2ts" player="Universal_Player"/>
Here's the latest playercorefactory.xml i've tried. None of my files have filetype-ish names. F.x. Master & Commander.iso and not Master & Commander.bdmv.iso.
<playercorefactory>
    <players>
            <filename>C:\Users\Media Center\AppData\Roaming\XBMC\userdata\PlayBDMV.bat</filename>
        </player>
            <filename>C:\Users\Media Center\AppData\Roaming\XBMC\userdata\PlayDisc.bat</filename>
        </player>
            <filename>C:\Program Files (x86)\CyberLink\PowerDVD12\PDVDLaunchPolicy.exe</filename>
        </player>
    </players>
        <rule filetypes="bdmv" player="BDMV_Player"/>
        <rule filetypes="m2ts" player="Universal_Player"/>
        <rule name="Blu-Ray" protocols="bd" player="Disc_Player"/>
    </rules>
And the batch files...
PlayBDMV.bat
@echo off
set pth=%1
set pth=%pth:BDMV\index.bdmv=%
"C:\Program Files (x86)\CyberLink\PowerDVD12\PDVDLaunchPolicy.exe" %pth% exit
PlayDisc.bat
@echo off
"C:\Program Files (x86)\CyberLink\PowerDVD12\PDVDLaunchPolicy.exe" F:
PlayISO.bat - This one's modified a lot... the modifications allow PowerDVD to autostart the movie, and every other second it checks if PowerDVD is still running, and if not it'll unmount the image.
@echo off
"C:\Program Files (x86)\CyberLink\PowerDVD12\PDVDLaunchPolicy.exe" G:
timeout /T 2
:loop
timeout /T 2
tasklist /FI "IMAGENAME eq PowerDVDCinema12.exe" 2>NUL | find /I /N "PowerDVDCinema12.exe">NUL
if "%ERRORLEVEL%"=="0" goto loop
"C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 /u
With the above playercorefactory.xml every type of AV media just starts PowerDVD with the previous selected drive. Nothing else happens. In fact, almost every combination of rules makes selecting any AV media start PowerDVD with either defualt drive or a previous manually selected drive. I'm trying to get XBMC to start PowerDVD and autoplay when I insert a BD-disc or select a movie with a BD-disc file structure (e.g. BDMV folder and so on). I'm on the Eden PVR v3 margro build because I don't want to use 3 different media center software for 1 complete solution. Live-TV is a necessity, and at the same time I'd rather have 1 complete (or at least almost 1 complete) UI solution.
Hope there's a solution... thanks a lot anyways! Smile
Have you tried to set up DVD Fab Video Player to launch from within XBMC? it's something I am looking at doing and would like to know if it's possible...I should say I am sure it's possible just unsure of the steps.
@ Hessi,
I'm not sure that it is possible to playback BDMV file using PDVD12 as an external player, and I stated my finding in post #668...
For ISO, M2TS and BD, you can try the codes below:
<playercorefactory>
<players>
<args>"{1}"</args>
</player>
<player name="Bluray_Player" type="ExternalPlayer" audio="false" video="true">
<args>"{F:}"</args>
</player>
<args>"{1}"</args>
</player>
</players>
<!-- Bluray ISO -->
<rule name="Blu-Ray" filename="F:\\.*" filetypes="bdmv" player="Bluray_Player"/>
</rules>
I tried the ISO codes below on my HTPC's, and it worked fine.
PlayISO.bat:
@echo off
bluray - will try those at once! Thanks! Smile
You say it's not possible with BDMV file structures, but why then have the....
...rule?
Maybe you could explain the rules to me in detail, if it's not too much to ask? Smile
The reason for my modifying the PlayISO.bat is that i found, that when i was done watching the movie, the iso was still mounted. And I changed the order of VCDMount.exe and PDVDLaunchPolicy.exe so that the movie would autostart.
Now maybe it has something to do with the fact that I'm using the margro PVR build?? And Win 7 x64??
Oh and, I actually ONLY want Blu-Ray discs (actual discs) to play with PowerDVD12... is that possible?
