Dear bluray,
so, i have tried your "simple playercorefactory" for playing BDMV.
The result, xbmc dissapear, tmt5 comes up, (its trial version of tmt new build with automatic refresh rate change), i press "Free Trial" box, xbmc comes back and the movie i tried to watch is markes as "watched". i Alt+Tab, and tmt5 is ther but would not play the film. it just waits for my command to do something.
Next thing i did was to use your "Play BDMV", in conjuction with the full relevant playercorefactory, and now the result is much better, but still not there.
now, when i play a bdmv film with xbmc ( the default player now for bdmv is "play bdmv" ,obviously ), xbmc dissapear, tmt5 come on, i press "Free Trial", tmt5 dissapear, xbmc comes on with the movie marked as watched (as Before), but now when i Alt+Tab, i can see that tmt5 is starting to play the movie. which is good, but not quite.
please see the playercorefactory ( which i have modified a little) attached and please tell me how do i make the tmt5 stay on top.
playercorefactory:
<playercorefactory>
<players>
<player name="BDMV_Player" type="ExternalPlayer" audio="false" video="true">
<!-- You can place your PlayBDMV file anywhere -->
<filename>C:\Users\Kiper\AppData\Roaming\XBMC\userdata\PlayBDMV.bat</filename>
<args>"{1}"/fullscreen</args>
<hidexbmc>true</hidexbmc>
<hideconsole>true</hideconsole>
<warpcursor>none</warpcursor>
</player>
</players>
<rules action="prepend">
<rule filetypes="bdmv" player="BDMV_Player"/>
</rules>
</playercorefactory>
_______________________________________________________________-
Play Bdmv:
echo off
rem you can place your PlayBDMV file in \Roaming\XBMC\userdata\
set pth=%1
set pth=%pth:BDMV\index.bdmv=%
"C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uLaunchTMT5.exe" %pth% exit
_________________________________________________________________
i am using :
Win7 ultimate 64bit.
tmt5 ver: totalmediatheatre5_retail_tbyb_all
Thanx in advance for any help,
Tomer
