(2012-09-06, 21:50)Gingerbread Man Wrote: [ -> ] (2012-09-06, 21:39)bluray Wrote: [ -> ] (2012-09-06, 19:33)Gingerbread Man Wrote: [ -> ]I understand that I put this into 'AppData\Roaming\XBMC\userdata folder' which is fine.
If I then restart XBMC, will this automaticly be read by the 'Play Disc' button or will I have to marry them up?
Many thanks.
It will use PDVD12 when you click PlayDisc in XBMC UI.......
If I double click the .bat file for playdisc.bat in explorer, powerdvd loads up.
if I click play disc in XBMC, a circular timer icon appears as it thinks and then nothing happens.
Since PDVD12 don't work with PlayBDMV.bat, I'm not sure that it will work. I explained my finding in the earlier post on this matter.
You can try the codes below [for it to work, you have to create playercorefactory.xml, playdisc.bat and playbdmv.bat and save all 3 files in <C:\Users\Media Centre\AppData\Roaming\XBMC\userdata> folder]-
Playercorefactory.xml:
<playercorefactory>
<players>
<player name="PowerDVD" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Media Centre\AppData\Roaming\XBMC\userdata\PlayDisc.bat</filename>
<args>"{1}" /close</args>
<hidexbmc>true</hidexbmc>
<hideconsole>false</hideconsole>
<warpcursor>none</warpcursor>
</player>
<player name="BDMV_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Media Centre\AppData\Roaming\XBMC\userdata\PlayBDMV.bat</filename>
</player>
</players>
<rules action="prepend">
<!-- Bluray BDMV -->
<rule filenames="bdmv" filetypes="bdmv" player="BDMV_Player"/>
<!-- Bluray Disc -->
<rule filenames="BD" name="F:\\.*" filetypes="bdmv" player="PowerDVD"/>
</rules>
</playercorefactory>
PlayDisc.bat:
echo off
rem you can place your PlayDisc file in \Roaming\XBMC\userdata\
"C:\Program Files (x86)\cyberlink\PowerDVD12\PowerDVD12.exe" F:
PlayBDMV.bat:
echo off
rem you can place your PlayBDMV file in \Roaming\XBMC\userdata\
set pth=%1
set pth=%pth:BDMV\index.bdmv=%
"C:\Program Files (x86)\cyberlink\PowerDVD12\PowerDVD12.exe" %pth% exit
(2012-09-06, 22:19)_novalis Wrote: [ -> ]Hi bluray,
my stuttering problem with tmt5 only occurs in combination with xbmc. The bluray iso started directly in tmt works perfect.
If I launch my bluray from within xbmc, tmt5 is playing, the movie stutters. Then, if I close xbmc, tmt continues to play, the stuttering goes away.
Tried hide xbmc true/false, no difference. HW acc on/off. Tried almost every setting I guess.
Any explanation/solution for this?
novalis
What are your CPU and GPU?
