dear Bluray, I am having trouble playing sbs3d.mkv files using TMT5 as an externla player in xbmc. I downloaded your relevant files ( I want xbmc to handle everything else except the sbs & bluray discs) modified acc to my system but am not successful.
heres my codes & playercorefactory.xml
your help would be greatly appreciated
<playercorefactory>
<players>
<player name="ISO_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\*****\AppData\Roaming\XBMC\userdata\PlayISO.bat</filename>
<args>"{1}" /fullscreen</args>
<hidexbmc>false</hidexbmc>
<hideconsole>false</hideconsole>
<warpcursor>none</warpcursor>
</player>
<player name="BDMV_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\*****\AppData\Roaming\XBMC\userdata\PlayBDMV.bat</filename>
</player>
<player name="Disc_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\*****\AppData\Roaming\XBMC\userdata\PlayDisc.bat</filename>
<player name="Universal_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uMCEPlayer5.exe</filename>
<args>"{1}"</args>
<forceontop>true</forceontop>
</player>
</players>
<rules action="prepend">
<!-- Bluray ISO -->
<rule filename=".*iso.*" player="ISO_Player"/>
<!-- Bluray BDMV -->
<rule filename=".*bdmv.*" player="BDMV_Player"/>
<!-- Bluray Disc -->
<rule protocols="bd" player="Disc_Player"/>
<!-- sbs3d -->
<rule filetypes=".*sbs3d." filename=".*sbs3d.*" player="Universal_Player"/>
<!-- Bluray M2TS -->
<rule filename=".*m2ts.*" player="Universal_Player"/>
</rules>
</playercorefactory>
sbs3d.bat=
echo off
set pth=%1
set pth=%pth
bs3d\sbs3d=%
"C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uTotalMediaPlayer5.exe" %pth%
bs3d=%
PlayISO.bat=
"C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 %1
"C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uMCEPlayer5.exe" N:
"C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 /u
PlayDisc.bat
echo off
rem you can place your PlayDisc file in \Roaming\XBMC\userdata\
"C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uMCEPlayer5.exe" E:
play BDMV.bat=
echo off
rem you can place your PlayBDMV file in \Roaming\XBMC\userdata\
set pth=%1
set pth=%pth:BDMV\index.bdmv=%
"C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uMCEPlayer5.exe" %pth% exit
