(2013-03-26, 18:25)jespermart Wrote: [ -> ] (2013-03-26, 13:39)acejh1987 Wrote: [ -> ] (2013-03-25, 19:24)jespermart Wrote: [ -> ]I forgot to mention, that TMT 5.3 works without any issues with the codes from #1610, but as soon as i replace the 5.3 exe with the 6.0 exe I only get to the TMT 6.0 front screen but the playback don't start
TMT6 works fine for me.
Are you using the PlayISO.bat from #1610 or the PlayISO.bat from the first post?
Hello
I'm from Germany and I hope my english is good enough
I use this simple code with TMT 6
it works well with Frodo 12 (not 12.1) new relase new problems.
I think XBMC is just for nerds not for people who actually want to watch only movies!
I look so bluray iso including 3d and bluray drive with Bluray
my iso files have the names. bluray. in the name.
Example: avatar.3d.bluray.iso!
Make sure the path highlighted in red is correct for your system!!!!!!!!!!
<playercorefactory>
<players>
<player name="uMCEPlayer6" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Usersbat\Luncher.cmd</filename>
<args>"{1}"</args>
<hideconsole>true</hideconsole>
<playcountminimumtime>3600</playcountminimumtime>
</player>
</players>
<!-- REGELN -->
<rules action="prepend">
<rule filetypes="iso|bdmv|mpls" filename=".*bluray.*" player="uMCEPlayer6"/>
<rule name="Blu-Ray" protocols="bd" player="uMCEPlayer6"/>
<rule filetypes="bdmv" filename=".*bdmv" player="uMCEPlayer6"/>
<rule filetypes="bdmv" filename=".*m2ts" player="uMCEPlayer6"/>
</rules>
</playercorefactory>
and Luncher.cmd ( Create with editor )
echo off
set ext=%1
set ext=%ext:"=%
set ext=%ext:~-4%
if %ext%==.iso goto iso
if %ext%==bdmv goto disk
if %ext%==.ifo goto disk
"C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uMCEPlayer6.exe" %1
goto end
:iso
"C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 %1
ping -n 2 -w 1100 127.0.0.1 > nul
"C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uMCEPlayer6.exe" H:\
"C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe" /d=0 /u
Set ProcessName=uMCEPlayer6
earch
TaskList /FI "ImageName EQ %ProcessName%" | Find /I "%ProcessName%"
If %ErrorLevel%==0 ping localhost&&goto
earch
goto end
:disk
"C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\uMCEPlayer6.exe" AUTOPLAY BD %1
goto end
rem #########################################################################
:System
%1
goto end
:end
exit
i hope it works for you also
Daniel
