2012-08-12, 18:46
(2012-08-12, 08:08)Fred_Dorfman Wrote: [ -> ]It's very possible.....(2012-08-12, 04:15)bluray Wrote: [ -> ]@Fred_Dorfman,
I'm glad that you got it to work.......
What is version is your TMT5? It doesn't seem to work with version 5.0.1.114.
I have no problem getting TMT5 to start DVD IFO file with this "<rule filenames="video_ts.ifo" filetypes="ifo" player="DVDIFO_Player"/>" and the same .bat file as what you listed it....but TMT5 crashed after it started the movie......the same IFO file worked fine with MPC-HC.....
I'm using TMT5 version 5.3.1.146. Maybe this newer version fixes the problem??
(2012-08-12, 08:08)Fred_Dorfman Wrote: [ -> ]Have you tried using the simpler <rule dvdfile="true" player="IFO_Player"/> ? Not sure if this would make a difference. Maybe it is launching the wrong .IFO file in the VIDEO_TS folder.I tried all the above since I'm starting using external player last year, and I tried it again before I suggested MPC-HC.....as I said, I don't have problem launching IFO automatically using TMT5....it crashed with version 5.0.1.114 after it start playing IFO for a few seconds.......
Also, as I mentioned in my last post, for some reason launching the uTotalMediaTheatre5.exe from the batch file works for me, but launching uLaunchTMT5.exe seems to cause TMT5 to hang.
I don't mind using XBMC to playback IFO because I have a few IFO movies only.......I traded all my old DVD's for blu-ray's......
