2013-10-15, 21:22
So, just curious, I've updated to Carb0's most recent ver (windows7,frodo), but while you fine nerdy-er than I gents continue to poke at this, will the fiddler fix still work for live games in the meantime?
(2013-10-15, 20:20)juggie Wrote: [ -> ]How are you doing your loop to keep asyncore running? You should be doing like:
while not xbmc.abortRequested:
asyncore.loop(timeout=1)
when xbmc tries to close the addon, this loop should exit. I have not tested this, that is just what I found in various places.
If you could send me a link to what you have so far, I will debug it more tonight.
(2013-10-15, 21:22)dazed Wrote: [ -> ]So, just curious, I've updated to Carb0's most recent ver (windows7,frodo), but while you fine nerdy-er than I gents continue to poke at this, will the fiddler fix still work for live games in the meantime?
(2013-10-15, 15:05)Hyperium Wrote: [ -> ]I see now, this is super easy. You can download this mongoose server temporarily, until carb0 adds a HTTP server through XBMC. What you do is just add your folder path to the document_root path in mongoose ( C:\Users\Hyperium\AppData\Roaming\XBMC\addons\plugin.video.nhl-gamecenter\m3u8 )
Replace this string in gamecenter.py * Not sure if it's exactly right, but it should be close -- pathToKey.append(os.path.join("http://localhost:8080/" + filename + str(i) + ".m3u8.key"))
And that should do it temporarily for Windows users.
(2013-10-15, 22:20)Carb0 Wrote: [ -> ](2013-10-15, 20:20)juggie Wrote: [ -> ]How are you doing your loop to keep asyncore running? You should be doing like:
It doesn't work if you use "while not xbmc.abortRequested". The server doesn't keep running.
You have to use the previous version for the fiddler fix. Or you can try this with the latest version:
18:56:43 T:4200 NOTICE: -----------------------------------------------------------------------
18:56:43 T:4200 NOTICE: Starting XBMC (12.0 Git:20130127-fb595f2), Platform: Windows 7 SP1 64-bit, build 7601. Built on Jan 28 2013 (compiler 1600)
18:56:43 T:4200 NOTICE: Pentium(R) Dual-Core CPU E6700 @ 3.20GHz
18:56:43 T:4200 NOTICE: Desktop Resolution: 1280x720 32Bit at 60Hz
18:56:43 T:4200 NOTICE: Running with administrator rights
18:56:43 T:4200 NOTICE: Aero is enabled
18:56:43 T:4200 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
18:56:43 T:4200 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
18:56:43 T:4200 NOTICE: special://masterprofile/ is mapped to: C:\Users\InnerCity\AppData\Roaming\XBMC\userdata
18:56:43 T:4200 NOTICE: special://home/ is mapped to: C:\Users\InnerCity\AppData\Roaming\XBMC\
18:56:43 T:4200 NOTICE: special://temp/ is mapped to: C:\Users\InnerCity\AppData\Roaming\XBMC\cache
18:56:43 T:4200 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
18:56:43 T:4200 NOTICE: Local hostname: InnerCity-PC
18:56:43 T:4200 NOTICE: Log File is located: C:\Users\InnerCity\AppData\Roaming\XBMC\xbmc.log
18:56:45 T:4200 NOTICE: Enumerated DirectSound devices:
18:56:45 T:4200 NOTICE: Device 1
18:56:45 T:4200 NOTICE: m_deviceName : {56B86E20-FACA-4D92-96C2-321BA63873B0}
18:56:45 T:4200 NOTICE: m_displayName : Digital Passthrough - Digital Audio (S/PDIF) (Envy24 Family Audio Controller WDM)
18:56:45 T:4200 NOTICE: m_displayNameExtra: DirectSound: Digital Audio (S/PDIF) (Envy24 Family Audio Controller WDM)
18:56:45 T:4200 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
18:56:45 T:4200 NOTICE: m_channels : FL,FR
18:56:45 T:4200 NOTICE: m_sampleRates : 48000
18:56:45 T:4200 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3
18:56:45 T:4200 NOTICE: Device 2
18:56:45 T:4200 NOTICE: m_deviceName : {5DF6C08E-6E6F-4F97-8E1B-B696A6615587}
18:56:45 T:4200 NOTICE: m_displayName : Speakers - Speakers (Envy24 Family Audio Controller WDM)
18:56:45 T:4200 NOTICE: m_displayNameExtra: DirectSound: Speakers (Envy24 Family Audio Controller WDM)
18:56:45 T:4200 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:56:45 T:4200 NOTICE: Device 3
18:56:45 T:4200 NOTICE: m_deviceName : {967D95C2-3CF6-4635-8CF0-782A11148705}
18:56:45 T:4200 NOTICE: m_displayName : HDMI - AMD HDMI Output (2- AMD High Definition Audio Device)
18:56:45 T:4200 NOTICE: m_displayNameExtra: DirectSound: AMD HDMI Output (2- AMD High Definition Audio Device)
18:56:45 T:4200 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
18:56:45 T:4200 NOTICE: Enumerated WASAPI devices:
18:56:45 T:4200 NOTICE: m_displayNameExtra: WASAPI: Digital Audio (S/PDIF) (Envy24 Family Audio Controller WDM)
18:56:45 T:4200 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
18:56:45 T:4200 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S32NE,AE_FMT_S32LE,AE_FMT_S32BE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_S8,AE_FMT_U8,AE_FMT_LPCM
18:56:45 T:4200 NOTICE: m_displayNameExtra: WASAPI: Speakers (Envy24 Family Audio Controller WDM)
18:56:45 T:4200 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S32NE,AE_FMT_S32LE,AE_FMT_S32BE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_S8,AE_FMT_U8,AE_FMT_LPCM
18:56:45 T:4200 NOTICE: m_displayNameExtra: WASAPI: AMD HDMI Output (2- AMD High Definition Audio Device)
18:56:45 T:4200 NOTICE: m_channels : FL,FR,FC,LFE,SL,SR,BL,BR
18:56:45 T:4200 NOTICE: m_sampleRates : 192000,176400,96000,88200,48000,44100,32000
18:56:45 T:4200 NOTICE: m_dataFormats : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
18:56:45 T:4200 NOTICE: load settings...
18:56:45 T:4200 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:56:45 T:4200 NOTICE: loading special://masterprofile/guisettings.xml
18:56:45 T:4200 NOTICE: Getting hardware information now...
18:56:45 T:4200 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:56:45 T:4200 NOTICE: Loaded playercorefactory configuration
18:56:45 T:4200 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:56:45 T:4200 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:56:45 T:4200 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
18:56:45 T:4200 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
18:56:45 T:4200 NOTICE: Default DVD Player: dvdplayer
18:56:45 T:4200 NOTICE: Default Video Player: dvdplayer
18:56:45 T:4200 NOTICE: Default Audio Player: paplayer
18:56:45 T:4200 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:56:45 T:4200 NOTICE: Log level changed to 0
18:56:45 T:4200 NOTICE: Loading media sources from special://masterprofile/sources.xml
18:56:45 T:4200 NOTICE: Running database version Addons15
18:56:45 T:4188 NOTICE: Thread CSoftAE start, auto delete: false
18:56:45 T:4296 NOTICE: Thread CRemoteControl start, auto delete: false
18:56:45 T:1404 NOTICE: Thread XBMC Peripherals start, auto delete: false
18:56:45 T:4200 NOTICE: Found screen: Generic PnP Monitor on AMD Radeon HD 6450, adapter 0.
18:56:45 T:4200 NOTICE: Primary mode: 1280x720 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 640x480 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 720x480 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 720x480 @ 29.97i - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 720x480 @ 30.00i - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 720x576 @ 50.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 720x576 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 720x576 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 720x576 @ 25.00i - Full Screen
18:56:45 T:4200 NOTICE: Previous line repeats 2 times.
18:56:45 T:4200 NOTICE: Additional mode: 800x600 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1024x768 @ 24.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1024x768 @ 29.97 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1024x768 @ 30.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1024x768 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1152x648 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1152x648 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x720 @ 50.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x720 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x768 @ 24.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x768 @ 29.97 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x768 @ 30.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x768 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x800 @ 24.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x800 @ 29.97 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x800 @ 30.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x800 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x960 @ 24.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x960 @ 29.97 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x960 @ 30.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x960 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x960 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x1024 @ 24.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x1024 @ 23.98 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x1024 @ 30.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x1024 @ 29.97 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x1024 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1280x1024 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1360x768 @ 24.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1360x768 @ 29.97 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1360x768 @ 30.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1360x768 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1360x768 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1360x1024 @ 24.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1360x1024 @ 23.98 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1360x1024 @ 30.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1360x1024 @ 29.97 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1360x1024 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1360x1024 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1366x768 @ 24.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1366x768 @ 29.97 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1366x768 @ 30.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1366x768 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1366x768 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1400x1050 @ 24.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1400x1050 @ 23.98 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1400x1050 @ 30.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1400x1050 @ 29.97 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1400x1050 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1400x1050 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1440x900 @ 24.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1440x900 @ 29.97 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1440x900 @ 30.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1440x900 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1440x900 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1600x900 @ 24.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1600x900 @ 29.97 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1600x900 @ 30.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1600x900 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1600x900 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1680x1050 @ 24.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1680x1050 @ 23.98 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1680x1050 @ 30.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1680x1050 @ 29.97 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1680x1050 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1680x1050 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1776x1000 @ 24.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1776x1000 @ 29.97 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1776x1000 @ 30.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1776x1000 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1776x1000 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1776x1000 @ 29.97i - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1776x1000 @ 30.00i - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1920x1080 @ 24.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1920x1080 @ 23.98 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1920x1080 @ 30.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1920x1080 @ 29.97 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1920x1080 @ 60.00 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1920x1080 @ 59.94 - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1920x1080 @ 25.00i - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1920x1080 @ 30.00i - Full Screen
18:56:45 T:4200 NOTICE: Additional mode: 1920x1080 @ 29.97i - Full Screen
18:56:45 T:4200 NOTICE: Checking resolution 16
18:56:46 T:4200 NOTICE: Running database version Addons15
18:56:46 T:4200 NOTICE: Running database version ViewModes4
18:56:46 T:4200 NOTICE: Running database version Textures13
18:56:46 T:4200 NOTICE: Running database version MyMusic32
18:56:46 T:4200 NOTICE: Running database version MyVideos75
18:56:46 T:4200 NOTICE: Running database version TV22
18:56:46 T:4200 NOTICE: Running database version Epg7
18:56:46 T:4200 NOTICE: initializing playlistplayer
18:56:46 T:4200 NOTICE: DONE initializing playlistplayer
18:56:47 T:4312 NOTICE: Thread XBPyThread start, auto delete: false
18:56:47 T:4312 NOTICE: -->Python Interpreter Initialized<--
18:56:47 T:5016 NOTICE: Thread XBPyThread start, auto delete: false
18:56:47 T:5016 NOTICE: Previous line repeats 3 times.
18:56:47 T:5016 NOTICE: -->Python Interpreter Initialized<--
18:56:47 T:2532 NOTICE: -->Python Interpreter Initialized<--
18:56:47 T:3492 NOTICE: -->Python Interpreter Initialized<--
18:56:47 T:4032 NOTICE: -->Python Interpreter Initialized<--
18:56:48 T:4200 NOTICE: initialize done
18:56:48 T:3684 NOTICE: Thread Jobworker start, auto delete: true
18:56:48 T:4356 NOTICE: Thread XBPyThread start, auto delete: false
18:56:49 T:4356 NOTICE: -->Python Interpreter Initialized<--
18:56:49 T:4032 NOTICE: Artwork Downloader: ## Service - Run at startup: False
18:56:49 T:4032 NOTICE: Artwork Downloader: ## Service - Delayed startup: -- minutes
18:56:49 T:4032 NOTICE: Artwork Downloader: ## Service - Run as service: False
18:56:49 T:4032 NOTICE: Artwork Downloader: ## Service - Time: 00:00
18:56:49 T:4356 NOTICE: StorageServer Module loaded RUN
18:56:49 T:4356 NOTICE: StorageClient-2.5.2 Starting server
18:56:49 T:4356 NOTICE: StorageServer-2.5.2 Storage Server starting C:\Users\InnerCity\AppData\Roaming\XBMC\cache\commoncache.db
18:56:51 T:4200 NOTICE: Running the application...
18:56:51 T:4200 NOTICE: Webserver: Starting...
18:56:51 T:4200 NOTICE: WebServer: Started the webserver
18:56:51 T:4200 NOTICE: starting upnp server
18:56:51 T:4200 NOTICE: ES: Starting event server
18:56:51 T:4668 NOTICE: Thread CEventServer start, auto delete: false
18:56:51 T:4668 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:56:51 T:4668 NOTICE: UDP: Listening on port 9777
18:56:52 T:564 NOTICE: Thread CTCPServer start, auto delete: false
18:56:54 T:3096 NOTICE: Thread Jobworker start, auto delete: true
18:56:54 T:4676 NOTICE: Thread XBPyThread start, auto delete: false
18:56:54 T:4676 NOTICE: -->Python Interpreter Initialized<--
18:57:12 T:1180 NOTICE: Thread Background Loader start, auto delete: false
18:57:13 T:4256 NOTICE: Thread XBPyThread start, auto delete: false
18:57:13 T:4256 NOTICE: -->Python Interpreter Initialized<--
18:57:14 T:4256 NOTICE: Mode: None
18:57:14 T:4256 NOTICE: URL: None
18:57:14 T:4256 NOTICE: Name: None
18:57:14 T:4104 NOTICE: Thread Background Loader start, auto delete: false
18:57:15 T:3636 NOTICE: Thread XBPyThread start, auto delete: false
18:57:15 T:3636 NOTICE: -->Python Interpreter Initialized<--
18:57:16 T:3636 NOTICE: Mode: 8
18:57:16 T:3636 NOTICE: URL: /live
18:57:16 T:3636 NOTICE: Name: Live
18:57:16 T:3636 NOTICE: /live
18:57:16 T:2768 NOTICE: Thread Background Loader start, auto delete: false
18:57:20 T:5100 NOTICE: Thread XBPyThread start, auto delete: false
18:57:20 T:5100 NOTICE: -->Python Interpreter Initialized<--
18:57:21 T:5100 NOTICE: Mode: 9
18:57:21 T:5100 NOTICE: URL: /liveVAN vs. PHI 10/15/2013 07:00
18:57:21 T:5100 NOTICE: Name: 10/15/2013 07:00 PM: Vancouver @ Philadelphia
18:57:21 T:5100 NOTICE: /liveVAN vs. PHI 10/15/2013 07:00
18:57:21 T:5100 NOTICE: Downloading m3u8 file
18:57:21 T:5100 NOTICE: Done
18:57:23 T:5100 NOTICE: AWAY
18:57:23 T:4200 NOTICE: DVDPlayer: Opening: C:\Users\InnerCity\AppData\Roaming\XBMC\addons\plugin.video.nhl-gamecenter\m3u8/away.m3u8
18:57:23 T:4200 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
18:57:23 T:5100 WARNING: Attempt to use invalid handle -1
18:57:23 T:2484 NOTICE: Thread CDVDPlayer start, auto delete: false
18:57:23 T:2484 NOTICE: Creating InputStream
18:57:23 T:2484 NOTICE: Creating Demuxer
18:57:28 T:2484 NOTICE: Opening video stream: 0 source: 256
18:57:28 T:2484 NOTICE: Creating video codec with codec id: 28
18:57:28 T:2484 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
18:57:28 T:2484 NOTICE: Creating video thread
18:57:28 T:2484 NOTICE: Opening audio stream: 1 source: 256
18:57:28 T:2484 NOTICE: Finding audio codec for: 86018
18:57:28 T:2484 NOTICE: Creating audio thread
18:57:28 T:2056 NOTICE: Thread CDVDPlayerAudio start, auto delete: false
18:57:28 T:2056 NOTICE: running thread: CDVDPlayerAudio::Process()
18:57:28 T:2056 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 44100, no pass-through)
18:57:28 T:4660 NOTICE: Thread CDVDPlayerVideo start, auto delete: false
18:57:28 T:4660 NOTICE: running thread: video_thread
18:57:28 T:4660 NOTICE: fps: 29.970030, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
18:57:28 T:4660 NOTICE: Display resolution DESKTOP : 1280x720 @ 60.00 - Full Screen (16)
18:57:28 T:4660 NOTICE: D3D: rendering method forced to DXVA2 processor
18:57:41 T:2484 WARNING: msvcrt.dll: dll_lseeki64 called, TODO: add 'int64 -> long' type checking
19:51:16 T:1424 NOTICE: -----------------------------------------------------------------------
19:51:16 T:1424 NOTICE: Starting XBMC (12.2 Git:20130502-32b1a5e), Platform: Windows 7 SP1 64-bit, build 7601. Built on May 2 2013 (compiler 1600)
19:51:16 T:1424 NOTICE: Intel(R) Atom(TM) CPU D2550 @ 1.86GHz
19:51:16 T:1424 NOTICE: Desktop Resolution: 1766x982 32Bit at 29Hz
19:51:16 T:1424 NOTICE: Running with administrator rights
19:51:16 T:1424 NOTICE: Aero is enabled
19:51:16 T:1424 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
19:51:16 T:1424 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
19:51:16 T:1424 NOTICE: special://masterprofile/ is mapped to: C:\Users\XBMC\AppData\Roaming\XBMC\userdata
19:51:16 T:1424 NOTICE: special://home/ is mapped to: C:\Users\XBMC\AppData\Roaming\XBMC\
19:51:16 T:1424 NOTICE: special://temp/ is mapped to: C:\Users\XBMC\AppData\Roaming\XBMC\cache
19:51:16 T:1424 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
19:51:16 T:1424 NOTICE: Local hostname: HTPC
19:51:16 T:1424 NOTICE: Log File is located: C:\Users\XBMC\AppData\Roaming\XBMC\xbmc.log
19:51:16 T:1424 NOTICE: Found 2 Lists of Devices
19:51:16 T:1424 NOTICE: Enumerated DirectSound devices:
19:51:16 T:1424 NOTICE: Device 1
19:51:16 T:1424 NOTICE: m_deviceName : {D6346B2C-56B4-4E3E-9546-A44A934E57DC}
19:51:16 T:1424 NOTICE: m_displayName : HDMI - GV46L HDTV10A-1 (NVIDIA High Definition Audio)
19:51:16 T:1424 NOTICE: m_displayNameExtra: DirectSound: GV46L HDTV10A-1 (NVIDIA High Definition Audio)
19:51:16 T:1424 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
19:51:16 T:1424 NOTICE: m_channels : FL,FR
19:51:16 T:1424 NOTICE: m_sampleRates : 48000
19:51:16 T:1424 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3
19:51:16 T:1424 NOTICE: Device 2
19:51:16 T:1424 NOTICE: m_deviceName : {DF90D39D-AA3C-425E-B29B-464F6999F9DC}
19:51:16 T:1424 NOTICE: m_displayName : SPDIF - Realtek Digital Output (Realtek High Definition Audio)
19:51:16 T:1424 NOTICE: m_displayNameExtra: DirectSound: Realtek Digital Output (Realtek High Definition Audio)
19:51:16 T:1424 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
19:51:16 T:1424 NOTICE: Enumerated WASAPI devices:
19:51:16 T:1424 NOTICE: m_displayNameExtra: WASAPI: GV46L HDTV10A-1 (NVIDIA High Definition Audio)
19:51:16 T:1424 NOTICE: m_sampleRates : 48000,44100
19:51:16 T:1424 NOTICE: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
19:51:16 T:1424 NOTICE: m_displayNameExtra: WASAPI: Realtek Digital Output (Realtek High Definition Audio)
19:51:16 T:1424 NOTICE: m_sampleRates : 192000,96000,48000,44100
19:51:16 T:1424 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
19:51:16 T:1424 NOTICE: load settings...
19:51:16 T:1424 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:51:16 T:1424 NOTICE: loading special://masterprofile/guisettings.xml
19:51:16 T:1424 NOTICE: Getting hardware information now...
19:51:16 T:1424 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:51:16 T:1424 NOTICE: Loaded playercorefactory configuration
19:51:16 T:1424 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:51:16 T:1424 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:51:16 T:1424 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
19:51:16 T:1424 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
19:51:16 T:1424 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.1.200</host>
<name>xbmc_video</name>
<user>xbmc</user>
<pass>xbmc</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<name>xbmc_music</name>
<user>xbmc</user>
<pass>xbmc</pass>
</musicdatabase>
</advancedsettings>
19:51:16 T:1424 WARNING: VIDEO database configuration is experimental.
19:51:16 T:1424 NOTICE: Default DVD Player: dvdplayer
19:51:16 T:1424 NOTICE: Default Video Player: dvdplayer
19:51:16 T:1424 NOTICE: Default Audio Player: paplayer
19:51:16 T:1424 NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:51:16 T:1424 NOTICE: Log level changed to 0
19:51:16 T:1424 NOTICE: Loading media sources from special://masterprofile/sources.xml
19:51:16 T:1944 NOTICE: Thread CSoftAE start, auto delete: false
19:51:16 T:1424 NOTICE: Running database version Addons15
19:51:17 T:3924 NOTICE: Thread XBMC Peripherals start, auto delete: false
19:51:17 T:2092 NOTICE: Thread CRemoteControl start, auto delete: false
19:51:17 T:1840 NOTICE: Thread XBMC Peripherals start, auto delete: false
19:51:17 T:1424 NOTICE: Found screen: Generic PnP Monitor on NVIDIA GeForce 610M, adapter 0.
19:51:17 T:1424 NOTICE: Primary mode: 1766x982 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 640x480 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Previous line repeats 2 times.
19:51:17 T:1424 NOTICE: Additional mode: 640x480 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 640x480 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 640x480 @ 50.00 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 640x480 @ 59.94 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 720x480 @ 59.94 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 720x480 @ 50.00 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 720x576 @ 60.00 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 720x576 @ 59.94 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 720x576 @ 50.00 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 800x600 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 800x600 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 800x600 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1024x768 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1024x768 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1024x768 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1152x864 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1152x864 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1152x864 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1176x664 @ 50.00 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1176x664 @ 60.00 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1176x664 @ 59.94 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x720 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x720 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x720 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x720 @ 50.00 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x720 @ 59.94 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x768 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x768 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x768 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x800 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x800 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x800 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x960 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x960 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x960 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x1024 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x1024 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1280x1024 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1360x768 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1360x768 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1360x768 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1366x768 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1366x768 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1366x768 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1600x900 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1600x900 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1600x900 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1600x1024 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1600x1024 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1600x1024 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1680x1050 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1680x1050 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1680x1050 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1768x992 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1768x992 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1768x992 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1920x1080 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1920x1080 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1920x1080 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1766x982 @ 30.00i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1766x982 @ 29.97i - Full Screen
19:51:17 T:1424 NOTICE: Additional mode: 1766x982 @ 25.00i - Full Screen
19:51:17 T:1424 NOTICE: Checking resolution 15
19:51:17 T:1424 NOTICE: Running database version Addons15
19:51:17 T:1424 NOTICE: Running database version ViewModes4
19:51:17 T:1424 NOTICE: Running database version Textures13
19:51:17 T:1424 NOTICE: Running database version xbmc_music32
19:51:17 T:1424 NOTICE: Running database version xbmc_video75
19:51:17 T:1424 NOTICE: Running database version TV22
19:51:17 T:1424 NOTICE: Running database version Epg7
19:51:17 T:1424 NOTICE: initializing playlistplayer
19:51:17 T:1424 NOTICE: DONE initializing playlistplayer
19:51:22 T:652 NOTICE: Thread XBPyThread start, auto delete: false
19:51:22 T:652 NOTICE: Previous line repeats 3 times.
19:51:22 T:652 NOTICE: -->Python Interpreter Initialized<--
19:51:22 T:440 NOTICE: -->Python Interpreter Initialized<--
19:51:22 T:3384 NOTICE: -->Python Interpreter Initialized<--
19:51:22 T:2928 NOTICE: -->Python Interpreter Initialized<--
19:51:22 T:1372 NOTICE: Thread XBPyThread start, auto delete: false
19:51:22 T:1424 NOTICE: Previous line repeats 1 times.
19:51:22 T:1424 NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
19:51:24 T:440 NOTICE: Artwork Downloader: ## Service - Run at startup: False
19:51:24 T:440 NOTICE: Artwork Downloader: ## Service - Delayed startup: minutes
19:51:24 T:440 NOTICE: Artwork Downloader: ## Service - Run as service: False
19:51:24 T:440 NOTICE: Artwork Downloader: ## Service - Time: :00
19:51:27 T:2784 NOTICE: -->Python Interpreter Initialized<--
19:51:27 T:1372 NOTICE: -->Python Interpreter Initialized<--
19:51:28 T:3544 NOTICE: Thread CVideoInfoScanner start, auto delete: false
19:51:28 T:1424 NOTICE: initialize done
19:51:28 T:3156 NOTICE: Thread XBPyThread start, auto delete: false
19:51:28 T:1424 NOTICE: Running the application...
19:51:28 T:1424 NOTICE: Webserver: Starting...
19:51:28 T:1424 NOTICE: WebServer: Started the webserver
19:51:28 T:1424 NOTICE: starting upnp renderer
19:51:28 T:1424 NOTICE: ES: Starting event server
19:51:28 T:1424 NOTICE: starting zeroconf publishing
19:51:28 T:3616 NOTICE: Thread CEventServer start, auto delete: false
19:51:28 T:3872 NOTICE: Thread CTCPServer start, auto delete: false
19:51:28 T:3616 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
19:51:28 T:3616 NOTICE: UDP: Listening on port 9777
19:51:28 T:3960 NOTICE: Thread Jobworker start, auto delete: true
19:51:28 T:3544 NOTICE: VideoInfoScanner: Starting scan ..
19:51:28 T:3580 NOTICE: Thread AirPlayServer start, auto delete: false
19:51:28 T:3576 NOTICE: Thread Jobworker start, auto delete: true
19:51:31 T:3156 NOTICE: -->Python Interpreter Initialized<--
19:51:31 T:3544 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:03
19:51:32 T:3156 NOTICE: StorageServer Module loaded RUN
19:51:32 T:3156 NOTICE: StorageClient-2.5.2 Starting server
19:51:32 T:3156 NOTICE: StorageServer-2.5.2 Storage Server starting C:\Users\XBMC\AppData\Roaming\XBMC\cache\commoncache.db
19:51:34 T:2452 NOTICE: Thread XBPyThread start, auto delete: false
19:51:34 T:2452 NOTICE: -->Python Interpreter Initialized<--
19:51:37 T:3540 NOTICE: Thread CAlarmClock start, auto delete: false
19:51:37 T:3292 NOTICE: Thread Jobworker start, auto delete: true
19:51:49 T:3664 NOTICE: Previous line repeats 1 times.
19:51:49 T:3664 NOTICE: Thread XBPyThread start, auto delete: false
19:51:49 T:3664 NOTICE: -->Python Interpreter Initialized<--
19:51:49 T:3664 NOTICE: Mode: None
19:51:49 T:3664 NOTICE: URL: None
19:51:49 T:3664 NOTICE: Name: None
19:51:50 T:3672 NOTICE: Thread Background Loader start, auto delete: false
19:51:50 T:2028 NOTICE: Thread XBPyThread start, auto delete: false
19:51:50 T:2028 NOTICE: Previous line repeats 1 times.
19:51:50 T:2028 NOTICE: -->Python Interpreter Initialized<--
19:51:50 T:1668 NOTICE: -->Python Interpreter Initialized<--
19:51:50 T:3484 NOTICE: Thread XBPyThread start, auto delete: false
19:51:52 T:3484 NOTICE: -->Python Interpreter Initialized<--
19:51:56 T:2268 NOTICE: Thread XBPyThread start, auto delete: false
19:51:59 T:2268 NOTICE: -->Python Interpreter Initialized<--
19:51:59 T:2268 NOTICE: Mode: 8
19:51:59 T:2268 NOTICE: URL: /live
19:51:59 T:2268 NOTICE: Name: Live
19:51:59 T:2268 NOTICE: /live
19:52:05 T:2196 NOTICE: Thread Background Loader start, auto delete: false
19:52:10 T:3288 NOTICE: Thread XBPyThread start, auto delete: false
19:52:10 T:3288 NOTICE: -->Python Interpreter Initialized<--
19:52:10 T:3288 NOTICE: Mode: 9
19:52:10 T:3288 NOTICE: URL: /liveCHI vs. CAR 10/15/2013
19:52:10 T:3288 NOTICE: Name: LIVE - END 1st: Blackhawks vs. Hurricanes
19:52:10 T:3288 NOTICE: /liveCHI vs. CAR 10/15/2013
19:52:10 T:3288 NOTICE: Downloading m3u8 file
19:52:11 T:3288 NOTICE: Done
19:52:11 T:3288 NOTICE: Downloading m3u8 file
19:52:13 T:3288 NOTICE: HOME
19:52:13 T:1424 NOTICE: DVDPlayer: Opening: C:\Users\XBMC\AppData\Roaming\XBMC\addons\plugin.video.nhl-gamecenter\m3u8/home.m3u8
19:52:13 T:1424 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
19:52:13 T:3220 NOTICE: Thread CDVDPlayer start, auto delete: false
19:52:13 T:3220 NOTICE: Creating InputStream
19:52:13 T:3220 NOTICE: Creating Demuxer
19:52:15 T:3220 ERROR: CDVDDemuxFFmpeg::Open - Error, could not open file C:\Users\XBMC\AppData\Roaming\XBMC\addons\plugin.video.nhl-gamecenter\m3u8\home.m3u8
19:52:15 T:3220 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
19:52:15 T:3220 NOTICE: CDVDPlayer::OnExit()
19:52:15 T:3220 NOTICE: CDVDPlayer::OnExit() deleting input stream
19:52:15 T:1424 NOTICE: DVDPlayer: Opening:
19:52:15 T:1424 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
19:52:15 T:3388 NOTICE: Thread CDVDPlayer start, auto delete: false
19:52:15 T:3388 NOTICE: Creating InputStream
19:52:15 T:3388 ERROR: perror:
19:52:15 T:3388 ERROR: Error on dvdnav_open
19:52:15 T:3388 ERROR: CDVDPlayer::OpenInputStream - error opening []
19:52:15 T:3388 NOTICE: CDVDPlayer::OnExit()
19:52:15 T:3388 NOTICE: CDVDPlayer::OnExit() deleting input stream
19:52:15 T:1424 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.nhl-gamecenter/?url=%2FliveCHI+vs.+CAR+10%2F15%2F2013&mode=9&name=LIVE+-+END+1st%3A+Blackhawks+vs.+Hurricanes]
19:52:15 T:3128 NOTICE: Thread Background Loader start, auto delete: false
19:52:15 T:1424 NOTICE: CDVDPlayer::CloseFile()
19:52:15 T:1424 NOTICE: DVDPlayer: waiting for threads to exit
19:52:15 T:1424 NOTICE: DVDPlayer: finished waiting
(2013-10-16, 01:53)Von Hockey Wrote: [ -> ]I can't believe I had to register to ask this, but how do I add custom UA in fiddler? All I can find in the thread is ->Open fiddler->add custom UA. I can't find an option to add a custom UA
(2013-10-16, 01:59)Hyperium Wrote: [ -> ](2013-10-16, 01:53)Von Hockey Wrote: [ -> ]I can't believe I had to register to ask this, but how do I add custom UA in fiddler? All I can find in the thread is ->Open fiddler->add custom UA. I can't find an option to add a custom UA
That's exactly how you do it. In the box that pops up, put this 'AppleTV/2.4' -- If I misread that -- on the toolbar it says "Rules' Then down that box it says "User Agent" - Down that box, it says Custom UA - Then follow the step above.
