Full Version: [Discontinued] NHL Gamecenter Addon
@fumbrunner
Did you remove the line you added from the hosts file? If you still have an edited hosts file, it won't work. Also, don't change the user-agent.
@ jayace
If you want to use the add-on on these devices, then yes. :-)
(2014-02-08, 23:54)Carb0 Wrote: [ -> ]@fumbrunner
@ jayace
Thanks, just wanted to be sure before I start updating all my devices. Great work btw.
16:00:12 T:1362248568 INFO: void XCURL:Big GrinllLibCurlGlobal::CheckIdle() - Closing session to http://feeds.xbmc.org (easy=0x616dd008, multi=0x60ed63c0)
16:00:14 T:1362248568 DEBUG: SECTION:UnloadDelayed(DLL: libImageLib-arm.so)
16:00:14 T:1362248568 DEBUG: Unloading: libImageLib-arm.so
16:00:27 T:1622796888 ERROR: ffmpeg[60B9EA58]: Unable to open key file http://nlsk.neulion.com/nlsk/hls/securek...0.m3u8.key
16:00:27 T:1622796888 ERROR: ffmpeg[60B9EA58]: [crypto] Unable to open input
16:00:27 T:1622796888 ERROR: ffmpeg[60B9EA58]: [hls,applehttp] Error when loading first segment 'http://nlds141.cdnak.neulion.com/nlds/nhl/bruins/as/live/bruins_hd_800_20140208184810.ts'
16:00:27 T:1622796888 DEBUG: Error, could not open file http://nlds141.cdnak.neulion.com/nlds/nh...0_ced.m3u8
16:00:27 T:1622796888 ERROR: bool CDVDPlayer::OpenDemuxStream() - Error creating demuxer
16:00:27 T:1622796888 NOTICE: CDVDPlayer::OnExit()
16:00:27 T:1622796888 NOTICE: CDVDPlayer::OnExit() deleting input stream
16:00:27 T:1622796888 DEBUG: virtual void CApplication::OnPlayBackStopped() : play state was 1, starting 1
16:00:27 T:1362248568 DEBUG: virtual void CApplication::OnPlayBackStopped() : play state was 3, starting 0
16:00:27 T:1362248568 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
16:00:27 T:1362248568 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
16:00:27 T:1362248568 ERROR: Playlist Player: skipping unplayable item: 0, path [http://nlds141.cdnak.neulion.com/nlds/nh...ion%204%29]
16:00:27 T:1362248568 DEBUG: Playlist Player: one or more items failed to play... aborting playback
Are you sure that you're on XBMC Gotham (13.0)?
@ jayace
Got it. Thanks. Had to delete the host file, Working well now. Thanks for all your help on this addon
You shouldn't have deleted the hosts file. Just remove the line you added for the last fix.
(2014-02-09, 00:08)Carb0 Wrote: [ -> ]You shouldn't have deleted the hosts file. Just remove the line you added for the last fix.
Sorry, that's what i meant. Deleted the line. Thanks again.
Thanks Carb0. Just updated to the latest nightly on Gotham and voila...it loads the games very quickly and with great stability. thanks for all your hard work.
Carb0, I love you. Thanks for all the hard work!!!
Thank you for not giving up on the addon eracknaphobia and all your hard work also!!
You can thank eracknaphobia. He found out that the add-on works with the user-agent string of the PS3.
I really like the new menus. Great stuff!
I'm getting a "dependencies not met" error when I try to update to the latest version of the add on. I'm running Gotham from the 2/2 nightly. Any suggestions welcome, thanks.
edit: if I uninstall the add on I can't re-install it from scratch. Says "add on is incompatible or has been marked broken in the repository. dependencies not met. please contact the add on author".
(2014-02-09, 03:26)[brick] Wrote: [ -> ]I'm getting a "dependencies not met" error when I try to update to the latest version of the add on. I'm running Gotham from the 2/2 nightly. Any suggestions welcome, thanks.
- Install a version XBMC Frodo (12.x)
- Install / Update NHL Gamecenter addon
- Install latest version of XBMC Gotham
Probably not the best method, but I've used it before.
Alternatively you could try unzipping and placing the plugin in the XBMC addon folder manually
Operative system File path
Android
Android/data/org.xbmc.xbmc/files/.xbmc/addons/
iOS
/private/var/mobile/Library/Preferences/XBMC/addons/
Linux
~/.xbmc/addons/
Mac OS X
/Users/<your_user_name>/Library/Application Support/XBMC/addons/
OpenELEC
/storage/.xbmc/addons/
Windows XP, 7, 8
%appdata%\XBMC\addons\
Method 2 didn't work for me. Method 1 did, it's working well for me now. Thanks!
well, updated my xbmcbuntu to gotham nightly build
get same error as with my window 8 running xbmc
title: Remote Share
Coult not connect to network server
no modification on hosts file on either builds
anyone else ?
weird, i tried to force refresh on the add-on, and got the exact error
seems like whatever site i need to get to from the plugin, it will not go to
most recent log:
http://pastebin.com/CBB92QEH
============ UPDATE =============
for anyone else who gets this error,
I was using '3rd party' DNS server on my router, which was the reason for the error(s)
put back main DNS on my router to my ISP , all is working
Thanks Carb0
you're the best !! along with those who steered you in the right direction
they are the best also
