NHL Gamecenter Mod 0.7.6
Fixed playing archive games for Montreal / Ottawa playoff French games.
Installation instruction:
You could go to XBMC SYSTEM/Settings/Add-ons and use the Install from zip file to install this add-on. You will see the NHL Gamecenter Mod in the VIDEO/Add-ons.
plugin.video.nhl-gamecenter-mod_0.7.6.zip
NHL Gamecenter Mod 0.7.7
This season NHL GameCenter Live has 4500 Kbps French stream for archive games which is supported in this release.
plugin.video.nhl-gamecenter-mod_0.7.7.zip
http://forum.kodi.tv/showthread.php?tid=...pid2245030
(2015-10-10, 04:08)hscotty55 Wrote: [ -> ]link does not work.
Sorry, fixed the link. It should work now.
NHL Gamecenter Mod 0.7.9
NHL GameCenter Live has changed to NHL.TV. As the result, the previous version not working.
There are some changes:
1) You need to login in order to watch
Full video even archive games (only need to login for live games in previous version). No login needed to watch
Extended Highlights or
Recap games.
2) Old archive games only available from 2016-01-13.
3) Only see French feed for
Full video. I don't see French feed for
Recap games with the new NHL.TV yet.
Note: I tried to keep the previous way of game navigation which is quick enough for navigation between game, date, etc...
I've tested using NHL credentials (you could use either username or email address) with Kodi 15.2 (Windows 10 and Raspberry Pi). It seems working fine, no login issue.
I don't have Rogers credentials to test. So please test to see if it works for you.
Also thanks to the developers of other 2 NHL versions, I have learned from them to make my own version.
plugin.video.nhl-gamecenter-mod_0.7.9.zip
http://forum.kodi.tv/showthread.php?tid=...pid2259447
Note: tinyupload might display advertise page, better close them to avoid any surprise.
Works on kodi (native linux).
[quote='TB123' pid='2245030' dateline='1455414388']
works great with rogers setup too!!
thank you!!
(2016-02-14, 12:32)WHamilton Wrote: [ -> ]Works on kodi (native linux).
Doesn't seem to work with the Kodi Linux version that Pivos has for its XIOS XS box...too bad as I'll probably have to flash mine and friends XIOS XS boxes to Android to get hockey.
NHL Gamecenter Mod 0.8.0
There are some new features added
+ Recent Games: you could change the number of days in the add-on Visual Settings, it might take longer time to load the list for higher number of days.
+ Play all the Condensed Games or Games Recap of the day (configured in the add-on Visual Settings)
+ Favorite Team: show a list of 30 recent games for your favorite team
+ NHL Videos: list all the video topics (Most Popular, Gorgeous Goals, Great Saves, etc) of the
http://www.nhl.com/video
+ Support icon + fanart
plugin.video.nhl-gamecenter-mod_0.8.0.zip
http://forum.kodi.tv/showthread.php?tid=...pid2412700
It works with Kodi 15.2 (Windows 10 and Raspberry Pi)
Installed the newest version on Macbook and Q3 Media Box.
Works perfectly on Macbook, can not watch anything that requires login on Q3
FYI ,,,,,Rogers customer
Here is link to log file:
http://xbmclogs.com/p52x03cy3
Any advice would be appreciated
(2016-02-27, 18:28)egd27 Wrote: [ -> ]Installed the newest version on Macbook and Q3 Media Box.
Here is link to log file: http://xbmclogs.com/p52x03cy3
From the Kodi log, your Q3 Media Box
ffmpeg player not able to play encrypted stream because it wasn't able to open the key file from
https url which is required by NHL full video stream.
Quote:1611.11:16:16 T:1400508584 DEBUG: ffmpeg[537A10A8]: https protocol not found, recompile with openssl or gnutls enabled.
1612.11:16:16 T:1400508584 ERROR: ffmpeg[537A10A8]: Unable to open key file https://mf.svc.nhl.com/ws/media/mf/v2.3/...d/20108243
There are similar errors people getting for other media play box. As the error suggested, it is required to recompile
ffmpeg with openssl or gnutls enabled so it could get the key file from
https url for your media box.
http://forum.kodi.tv/showthread.php?tid=...pid2245388
I could see from the Kodi log that you have Kodi 14.2 version. If you could install Kodi 15.2 (it already fixed this
ffmpeg https problem) then you will be able to play NHL full video stream.
(2016-02-28, 06:05)TB123 Wrote: [ -> ] (2016-02-27, 18:28)egd27 Wrote: [ -> ]Installed the newest version on Macbook and Q3 Media Box.
From the Kodi log, your Q3 Media Box ffmpeg player not able to play encrypted stream because it wasn't able to open the key file from https url which is required by NHL full video stream.
There are similar errors people getting for other media play box. As the error suggested, it is required to recompile ffmpeg with openssl or gnutls enabled so it could get the key file from https url for your media box.
I could see from the Kodi log that you have Kodi 14.2 version. If you could install Kodi 15.2 (it already fixed this ffmpeg https problem) then you will be able to play NHL full video stream.
Updated Kodi on the Q3 box and it is now working. Thank you so much, it was driving me nuts,
NHL Gamecenter Mod 0.8.0 last version does not work in Russia . Why ? . It does not go into my nhl gamecenter account ( sign in error nhl gamecenter )
Kodi 15.2 Icengard
Why NHL Gamecenter Mod 0.7.9 worked ? Why? TB123
