(2014-10-20, 18:01)nashtndeac06 Wrote: [ -> ]So after all of this, what is the addon i should download to watch NHL games?
Also, im not a programer, so if i am on a rasp pi how do i edit the addon code when there are problems/fixes?
I was having the "Check your login credentials" problem on Carbos.
thanks
You can use either version. I run on a RPI as well. All addons get installed into ~/.xbmc/addons so it would be in there.
As for your issue, are you using rogers or no? Which version of carb0 are you using? Latest?
(2014-10-20, 18:37)ellisd Wrote: [ -> ] (2014-10-20, 18:01)nashtndeac06 Wrote: [ -> ]So after all of this, what is the addon i should download to watch NHL games?
thanks
Ok, ill look at that when i get home. Im running the latest version of carb0, and no Rogers, im not in Canada.
(2014-10-18, 03:05)HocEman Wrote: [ -> ] (2014-10-16, 19:21)Carb0 Wrote: [ -> ]You can replace lines 53 to 56 of userinterface.py
try:
open(os.path.join(ADDON_PATH_PROFILE, 'cookies.lwp'))
except IOError:
login()
with
This forces the add-on to login on everytime you start it. It doesn't really fix the actual problem but this way you won't have to reenter your login credentials each time. Make sure that login() has the same indentation as the try and except or it won't work.
This tweak seems to have worked for me, have not had issues for 2 nights now.
Thanks Carb0!!
(2014-10-20, 21:00)nashtndeac06 Wrote: [ -> ] (2014-10-20, 18:37)ellisd Wrote: [ -> ] (2014-10-20, 18:01)nashtndeac06 Wrote: [ -> ]So after all of this, what is the addon i should download to watch NHL games?
thanks
I've incorporated Carb0's suggestion from above as it helped me and a few others. Here is the new ZIP (Sorry it's not as easy as installing from ZIP for the addon yet).
https://github.com/dannyellis/xbmc-nhl-g....7.2.1.zip
Just download this and extra to your .xbmc/addon folder.
Can you send me the repository please
the installable zip worked liked a charm. just overwrite the old installation of 0.7.1 and it preserves your login and pass too. the interface isn't as detailed bit the only important links are there.
Will we continue using this thread for NHL Gamecenter addon? If not, can someone recommend the right forum or thread? I am liking what we have so far. Watching NY vs NJ right now with Carb0's last version and am enjoying it. But if there are improvements being made this big fan wishes to be updated on it. Thanks.
Is there a way to get this add-on thru xbmc/kodi without having to install it thru ssh or some other manner
My programing skills are horrible and i can't seem to connect to my rasp pi thru ssh using filezilla or cyberduck. I've only ever added add-ons thru repositories straight on the RPI.
thanks.
Hey all.
New to XMBC and this app. Was trying this because my PS3 was lagging/chopping/freezing. Watch the EDM vs TB game last night without issue. Flawless. Tried to watch hockey tonight and got some script errors. Updated to 7.2.1 and was able to login. Trying to watch the Leafs vs Isles tonight and it's freezing. Anyone else? Just need to figure out if the problem is me somehow, the feeds, or maybe the new version? Yesterday, when there was a problem it would stop and buffer. Today, it's just booting me out.
(2014-10-22, 02:06)h0ckeyfan Wrote: [ -> ]Hey all.
I am watching games tonight and consistently getting booted after about 3 minutes of watching. I'm using Carb0s newest app. I'm not complaining, just letting anyone working on this app know of any problems. Still great quality!
I'm still on 7.1 and Jets Hurricanes game is working fine. Had to change my login name to a wrong one and back but other than that it's fine.
(2014-10-21, 02:55)Brenda.Barton Wrote: [ -> ]Can you send me the repository please
Unfortunately, the repository has been closed. You can download the .zip from the post above yours and extract it to your xbmc/addons/ directory.
(2014-10-22, 03:07)BigPappaSmurf Wrote: [ -> ] (2014-10-22, 02:06)h0ckeyfan Wrote: [ -> ]Hey all.
I'm watching Rangers @ Devils - no problems at all. Are you running Gotham? Getting booted after a couple of minutes was a problem with the addon running under Frodo.
Edit - it just buffered for about a second now that OT has started, but that's the first time tonight.
(2014-10-22, 03:38)MetalChris Wrote: [ -> ] (2014-10-21, 02:55)Brenda.Barton Wrote: [ -> ]Can you send me the repository please
I am running Gotham on a Boxee Box (Linux). Ever since the 3rd period started in the red wings game I've had no problems. I'm glad it's working again!
MetalChris - how exactly do i get the zip file into the .xbmc/addons directory? Using samba i was able to get the unzip file into the .xbmc/userdata/add_on folder. But i don't know how to get the file into the right directory apparently. Running Openelec on RPI and using samba thru a mac.
thanks.
Why can't you just download the zip, go to settings, addons, install from zip and locate the zip file?
(2014-10-22, 13:46)bobb0 Wrote: [ -> ]Why can't you just download the zip, go to settings, addons, install from zip and locate the zip file?
Because I'm not 100% sure how to set that up yet with Github. I think I may have to rearrange the repo a bit and add a few things. If anyone wants to help, they are more than welcome to work on the git repo and do a pull request with your changes. This is why I moved it to github, so that everyone can help out.
If I get some time this weekend I'll do my best to get a zip that is installable through the interface but first time working with addons on XBMC (I have python knowledge).
