What exactly is this IP doing that causes this to work? I'm not sure I understand exactly what it's doing that's causing this to work.
(2014-01-26, 03:32)Hyperium Wrote: [ -> ]What exactly is this IP doing that causes this to work? I'm not sure I understand exactly what it's doing that's causing this to work.
I have no friggin' clue - but I'm glad it's doing whatever it's doing. I'm still getting kicked every 5 minutes or so. I've tried different games and it still happens on both my linux box and my Pi. I'm gonna turn on debugging and post a log. Maybe someone who's more proficient with this stuff might be able to see what's going on there.
So far, haven't been able to get it to work for me. I am testing it on a windows box running 8.1. I added the ip address to the host file with notepad in administrative mode. Restarted, but I still can't connect to anything. Not sure why.
maybe this will help someone solve the 4-6 min cut off now
Log File Here
(2014-01-26, 03:54)bramwell Wrote: [ -> ]So far, haven't been able to get it to work for me. I am testing it on a windows box running 8.1. I added the ip address to the host file with notepad in administrative mode. Restarted, but I still can't connect to anything. Not sure why.
Check and make sure you did not save the hosts file as a .txt file, it should have no extension.
(2014-01-26, 04:06)Swiper the Fox Wrote: [ -> ]maybe this will help someone solve the 4-6 min cut off now
Log File Here
Glad you were finally able to get your hosts file edited. Watching a few minutes at a time is frustrating though.
My debug log is
here. Hopefully someone with better eyes than mine can find something in there.
MetalChris, thank you for that suggestion. However, it is not saved as a txt file. I checked it out. I would be glad to listen to any other suggestions. Hopefully, this can all be incorporated in an update so that even us dummies can do it.
thanks
(2014-01-06, 02:53)i007 Wrote: [ -> ]Hello Carb0,
If I use PC browser to watch NHL GameCenter Live for any live Montreal match, there is an extra French/Français feed beside the Home/Away feeds. Is it possible to add another button/feed Français on live game to play French channel feed for Montreal games?
(2014-01-12, 16:36)i007 Wrote: [ -> ] (2014-01-06, 08:02)Carb0 Wrote: [ -> ]Can you watch the streams in one of the official Gamecenter apps?
There is no French stream when watching live Montreal game using Android/iOS GameCenter app.
Another feature you might try to add is the Highlight game feature beside the condensed game as I see it has in the GameCenter app.
Today, I read the reddit.com
http://www.reddit.com/r/hockey/wiki/vlc
For example, today Montreal game Home and Away English streams
http://
nlds138.cdnak.neulion.com/nlds/
nhl/canadiens/as/live/canadiens_hd_3000.m3u8
http://
nlds123.cdnak.neulion.com/nlds/
nhl/capitals/as/live/capitals_hd_3000.m3u8
So I try to use browser to watch the Montreal game in French and check with Fidder2 to see the URL.
There is a similar stream and path having
nhlfr ==> fr = French. Look like it is possible to include a French stream for Montreal live game.
http://
nlds60.cdnak.neulion.com/nlds/
nhlfr/canadiens/as/live/canadiens_hd_4500.m3u8
Game Highlight/Recap has a fixed URL and anyone can watch it without credentials needed. This stream can be open as Network Stream in VLC too...
http://
e1.cdnak.neulion.com/nhl/vod/2014/01/25/777/2_777_wsh_mtl_1314_h_continuous_1_1600K_16x9.mp4
I can also say windows 8.1 host file line added and still not playing live games.
pett
Make sure that you saved the hosts file withou extension and also that the line you added isn't commented out with a #.
I read reddit and played with plugin last night.
On reddit there is a site that posts links to neulion streams which will work in iOS devices(there are also links for embedded vlc which is using AppleTV user-agent)
I've added in your plugin a quick hack to use their link to download m3u8 file instead of neulion and it worked!
Carb0 may be you could use those links instead? Or may be you could understand better what they are doing with m3u8 file to make it work?
(2014-01-26, 05:07)bramwell Wrote: [ -> ]MetalChris, thank you for that suggestion. However, it is not saved as a txt file. I checked it out. I would be glad to listen to any other suggestions. Hopefully, this can all be incorporated in an update so that even us dummies can do it.
thanks
(2014-01-26, 19:53)pett Wrote: [ -> ]I can also say windows 8.1 host file line added and still not playing live games.
Sorry I can't be of much help with windows 8.1 since the only windows system I have access to runs XP and it doesn't even have XBMC on it. I did edit the hosts file on it once and I used Notepad++ to do it. Might be worth trying that if you haven't already. Also, I did find
this article, which says in 8.1 windows defender will automatically replace a modified hosts file, and explains how to keep that from happening.
Well, I checked my hosts file for 8.1 and it still has the ip addition that I made. It still doesn't seem to work. Hmm. weird.
(2014-01-27, 01:49)bramwell Wrote: [ -> ]Well, I checked my hosts file for 8.1 and it still has the ip addition that I made. It still doesn't seem to work. Hmm. weird.
It is very easy to check if you enter it in hosts file correctly or not
Open a DOS cmd prompt and type
ping nlsk.neulion.com . If there is a reply from
192.241.136.149 then you entered it OK.
C:\ping nlsk.neulion.com
Pinging nlsk.neulion.com [192.241.136.149] with 32 bytes of data:
Reply from 192.241.136.149: bytes=32 time=102ms TTL=51
Reply from 192.241.136.149: bytes=32 time=118ms TTL=51
Reply from 192.241.136.149: bytes=32 time=32ms TTL=51
Reply from 192.241.136.149: bytes=32 time=83ms TTL=51
Ping statistics for 192.241.136.149:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 32ms, Maximum = 118ms, Average = 83ms
By default, Windows hide the file extension and you might save it to the hosts.txt instead of hosts file. You can check the box 'File name extensions' of the View menu of File Explorer.
Tried everything posted here.
successful ping, proper permissions and file extensions.
no dice
