2013-06-07, 10:05
Hi to all I've bought an ATV520, it is my first Android device so I've some difficulty to use it!
The first thing that doesn't impressed me positively was the automatic update, it seemed to not have a lot of success, it rebooted 2 times only to have a strange "Safe Mode" written in the left part of the screen and in the applications XMBC was not present!
I've tried in any way using all the two launchers (but that only with the clock cannot understand really how to use it ) but nothing, in the end I've tried to do an hard reset, that is I disconnected the power cord (there's no reset button, right?) and reconnected the power cord, device rebooted and finally XMBC appeared, so I started it...
Well it reads a lot of files on my network share, but the real bad surprise was when I tried to press FFWD in the OSD, nothing happened and device was freezed
... power cord disconnected again and reboot!
I've tried other times and the result was the same, so I've decided to install the Pivos XMBC version, so I downloaded it and copied in my Sandisk USB key, connected to the device and for the life of me I cannot find where the device mounted it!
In the end I've downloaded XMBC using the same device browser using the horrible remote, really a pain in the a**!
It installed and the things seemed really better now, FFWD works but the big problem remains how force the device to mount USB keys? I wanted to connect an external HDD drive to it to substitute a Western Digital Live Hub that cannot read anything, but if it works so badly... in the end WD Live hub seems better
Rebooting (in that horrendous way) some times USB appeared in /Storage/sda1 and sometime not
Maybe there is some Android addon to resolve this problem?
There is an way to replace that ugly remote? I've a Logitech Harmony Remote if I program it to be a Pivos remote shall I use all the remote keys? I shall for example use FFWD key directly?
Other more cheap remotes work?
