Full Version: VAAPI: Nuc, Chromebox, HSW, IVB, Baytrail with Ubuntu 14.04
(2015-06-27, 08:28)fritsch Wrote: [ -> ]
(2015-06-27, 08:21)Devil-Strike Wrote: [ -> ]Nice work indeed, also on j1800 is working without a problem, only baytrail users don't have uhd output hdmi support.
Yeah - but this we cannot change :-) Btw. I do those "decoding" tests all with a 1080p display. I don't have 4k hw either.
I know heheh but again thanks for all the hard work.
(2015-06-27, 08:24)gurabli Wrote: [ -> ]Amazing, so you say that j1800 also does everything properly, 1080i50 with hw deinterlacing, and 720p/576 lancoz3 upscaling? I don't have a j1800 to test atm.
Testing now 1080i 50Hz(25fps) 13mbit mpeg4 mbaff and no skips no drops(vaapi motion with lancros3) don't use upscale here(uhdtv is allot better in this than baytrail)
But just ask and 1 will test it for you.
(2015-06-27, 08:40)Devil-Strike Wrote: [ -> ]
Do you use vdr for live tv 1080i50Hz?
(2015-06-27, 08:43)gurabli Wrote: [ -> ]
No don't use vdr but dvbviewer rec services and local recordings from dvb-c pc card.
if some1 need ts streams just ask and I will upload samples.
Streams are here: http://solidrun.maltegrosse.de/~fritsch/
Mind testing the 720p50 and the 576i50 with Deinterlace=Auto and Deinterlace-Method=MADI and Lanczos3 Optimized? Upscaled to 1080p?
The others 1080i50 and 1080p50 please test with same setting but Scaling = Bilinear. There is no need to upscale 1080 to 1080 with lanczos3.
(2015-06-27, 08:51)fritsch Wrote: [ -> ]The others 1080i50 and 1080p50 please test with same setting but Scaling = Bilinear. There is no need to upscale 1080 to 1080 with lanczos3.
Do we actually need any upscaling in case of 1080 to 1080?
(2015-06-27, 08:54)gurabli Wrote: [ -> ]
Nope, that's why I say it. But sometimes one or two pixels are missing on left / right / top / bottom and the scalers start to run.
Exactly therefore we have: Use HQ Scaling when scaling above: 20%.
@Devil-Strike: And if you are at it:
Please also try those two:
http://distribution.bbb3d.renderfarming....normal.mp4 ( 30 fps)
http://distribution.bbb3d.renderfarming....normal.mp4 ( 60 fps)
on your Baytrail.
First run: Lanczos3 Optimized (most likely too much for the BYT)
Second run: Bilinear
I really hope that we get at least the 4k@30p with bilinear working on the Baytrail.
Ok will test it downloading the files now, will post results here, also screenshots?
Btw that scaling test was just to see if it skips frames, like it did with the normal openelec versions.
@fritsch
Ok tested the stream files, and all seems perfect with the setting, scaling 20% deinter=auto deinterlacer=vaapi-adaptive scaler= Lanczos3 Optimized
About the 4k 30 and 60 mixed results, 4k30 works perfect with Bilinear and even Lanczos3 Optimized, 60fps version skips allot in the first 10sec already 300+ skips with Lanczos3 Optimized, but only 2 skips with Bilinear in 5min.
Think this is very good for a cutted down 4eu gpu.
If you need screenshots or other things just ask Smile
Cool :-) That's nice. I will upload another build in some minutes, that reverts a commit and adds Lauri's work on Dithering (currently building).
Nice, let me know and I will test again Smile
btw, seems to me that you also have fixed -175 audio delay bug that I have here with 25fps(50hz) content, all openelec build have this problem but the egl builds not.
Will all the optimisations etc from here etc end up in the main openelec main releases?...even if its not the next main release...
Though the answer is obvious, but: Yes of course.
Here is a minor update:
We got something wrong last night and Lanczos3 was bypassed. Here is a new build which also includes the work of Lauri, color dithering. You can enable / disable it under Video Settings right above the Limited Range setting.
Updated stats from my Braswell:
4k @ 60 works with bilinear and linear neighbour, lanczos3 optimized is a bit too heavy
4k @ 30 works with lanczos3 optimized, no single skip / drop
All other stuff works the way we are used to it.
Please give this new version a test and also state what you think about the "color" management.
New build is here: https://dl.dropboxusercontent.com/u/5572...d7d8c1.tar
Thanks much for testing. To organize that stuff a bit, please do it like the following:
General settings:
Video -> Acceleration: Use HSQ scalers, when scaling above 20 %
Deinterlacing: Auto
Deinterlacing-Method: MADI / MCDI (on hsw+ MCDI should be usable)
Scaling-Algorithm: Lanczos 3 Optimized (if something drops / skips heavily -> choose bilinear instead).
Testsamples: http://solidrun.maltegrosse.de/~fritsch/
4kp30: http://distribution.bbb3d.renderfarming....normal.mp4
4kp60: http://distribution.bbb3d.renderfarming....normal.mp4
Result A:
Hardware: Intel Braswell 3150N
1080i50 with MADI / MCDI deinterlacing on a 1080p display: perfect
576i50 with MADI / MCDI deinterlacing and Lanczos 3 optimized scaling to 1080p: perfect
720p50 with Lanczos 3 Optimized scaling to 1080p: perfect
4kp30 with lanczos 3 optimized scaling to 1080p: perfect
4kp60 with lanczos3 optimized scaling to 1080p: drops and skips (roughly 35 fps)
4kp60 witz bilinear scaling to 1080p: perfect
Colors: All fine, quite impressive.
Result B:
Hardware: Intel Haswell i3-4020Y (zotac CI520)
4kp60 with lanczos3 optimized scaling to 1080p: 1 skip a second (with codec screen - non without)
4kp60 with bilinear scaling to 1080p: perfect
Colors: All fine, quite impressive. Here I am using GPU: fullrange and kodi settings: Use Limited Range, as I only have a Limited Range TV.
Something concerning official OpenELEC: I am VAAPI maintainer since ~ 2 years and Fernetmenta is producing the outstanding code behind the OpenELEC special additions since even longer. So you can fully be sure, that I will create a build, based on the final version of OpenELEC 6.0 with these additions.
Downloading build now, let you know the results.
Hardware: Intel Baytrail Celeron j1800
1080i50 with MADI on 1080p display: perfect
576i50 with MADI and Lanczos 3 optimized scaling to 1080p: constant skips
720p50 with Lanczos 3 Optimized scaling to 1080p: constant skips
4kp30 with lanczos 3 optimized scaling to 1080p: constant skips
4kp30 with bilinear scaling to 1080p: perfect
4kp60 with lanczos3 optimized scaling to 1080p: 1drop 100+ skips
4kp60 witz bilinear scaling to 1080p: from time to time skip.
Will do some more tests whene I am back home.
