Yeah - it was me, that had to debug that "4.2 latest and greatest mess" - cost me 3 hours last Friday :-)
(2014-10-08, 14:15)fritsch Wrote: [ -> ]Yeah - it was me, that had to debug that "4.2 latest and greatest mess" - cost me 3 hours last Friday :-)
Oh really :-) didn't know that, i'm one of the lucky ones with a Intel GPU, so thanks for resolving the issue :-), the current installed version works great.
Yeah, we should all be thankful for fritsch's and FernetMenta's work on vaapi and intel fixes. It does make NUC's a quite promising platform.
(2014-10-07, 21:38)fritsch Wrote: [ -> ]- xf86-video-intel 2.99.916 <- remove that.
Thanks for the hint, xbmc was working well during the last two days using .911
Thanks for reporting. Sadly not a debug log.
When it happens next time, please also include: dmesg | pastebinit
You can also run xbmc in debug mode without the Debug OSD on screen. The wiki has more info on that.
Retry with tomorrow's nightly.
From a short look the backend sends pure shit :-) and copy fails cause only half of the data announced is there.
Thanks for the reply, anyway to make xbmc restart automatically when it crash while using a window manager? I'm using openbox.
start it in a while loop via a bashscript.
fritsch is OpenELEC-Generic.x86_64-devel-20141007030758-r19340-g1be502f.tar from here
http://snapshots.openelec.tv/ a good build to test your lates work on a Intel nuc ?
No idea - we cannot really track what is currently in there.
As of now - as VAAPI is constantly changing, because of the driver bugs - I highly suggest to keep using the fernetmenta master ppa.
Ok thanks, guess i`ll just test it
One setting i can´t see you talked about is
System->video->accelaration->render method:
Auto detect or Software or advanced shaders or basic shaders ?
I tried to start from the scretch by using ubuntu server...
but I get the following error
xbmc@mediacenter:~$ sudo apt-get install ssh python-software-properties software-properties-common udisks upower xorg alsa-utils mesa-utils git-core librtmp0 lirc libmad0 lm-sensors libmpeg2-4 avahi-daemon libnfs1 consolekit pm-utils libva1 vainfo libva-intel-vaapi-driver linux-firmware
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
Hinweis: »i965-va-driver« wird an Stelle von »libva-intel-vaapi-driver« gewählt.
Paket libnfs1 ist nicht verfügbar, wird aber von einem anderen Paket
referenziert. Das kann heißen, dass das Paket fehlt, dass es abgelöst
wurde oder nur aus einer anderen Quelle verfügbar ist.
Doch die folgenden Pakete ersetzen es:
libnfs4:i386 libnfs4
E: Paket librtmp0 kann nicht gefunden werden.
E: Für Paket »libnfs1« existiert kein Installationskandidat.
xbmc@mediacenter:~$
Broadcast message from root@mediacenter
(unknown) at 12:17 ...
