Is there anything in this log that shows why Putty/SSH isn't working on my brother's RPi v2? I checked in the OE settings addon that SSH is enabled and deleted the files in .cache/ssh to let it recreate them. I can connect with WinSCP, which I think uses the same SSH key but when I try with Putty it can't connect and I just get an empty black window until I cancel it.
http://pastebin.com/479iWxbr
Using the Harmony Smart Hub/Remote. The Menu key does not open the context menu. (This works on all stable versions of OpenElec.) The workaround is to open the keyboard and use the c key. The keyboard is only accessible on the mobile version of the remote, not the remote hardware.
(2015-10-09, 14:18)doveman2 Wrote: [ -> ]Is there anything in this log that shows why Putty/SSH isn't working on my brother's RPi v2? I checked in the OE settings addon that SSH is enabled and deleted the files in .cache/ssh to let it recreate them. I can connect with WinSCP, which I think uses the same SSH key but when I try with Putty it can't connect and I just get an empty black window until I cancel it.
No. You'll need to enable PuTTY logging to view the communication handshake between PuTTY and OpenELEC to get an idea of why it's not working. RSA keys were recently deprecated by OpenSSH, so you may need to switch to DSA or ECDSA keys (however the latter are only supported in PuTTY when using the "development" build).
(2015-10-09, 16:50)jmerrilljr Wrote: [ -> ]Using the Harmony Smart Hub/Remote. The Menu key does not open the context menu. (This works on all stable versions of OpenElec.) The workaround is to open the keyboard and use the c key. The keyboard is only accessible on the mobile version of the remote, not the remote hardware.
Does it work with 5.95.5? If not you may need to report it upstream.
It works on the Chromebox version of 5.95.5. I have not tried the pi version. I will run that and see what happens. Thanks.
(2015-10-09, 17:35)Milhouse Wrote: [ -> ]No. You'll need to enable PuTTY logging to view the communication handshake between PuTTY and OpenELEC to get an idea of why it's not working. RSA keys were recently deprecated by OpenSSH, so you may need to switch to DSA or ECDSA keys (however the latter are only supported in PuTTY when using the "development" build).
Thanks, I never even noticed the PuTTY logging option! I'll see what the log reveals. I haven't had to change anything on my PC in PuTTY for it to work with my RPi v2 and the latest builds, whilst my brother is still on #825 and I think I checked PuTTY was working when I first sent the RPi v2 to him, to replace his RPI B+. He told me it froze recently and he had to cut the power and after he rebooted all his settings had reset (this seemed to happen to him with his B+ as well but I can't recall this happening with mine on the occasions I've had to cut the power), so it's possible something got screwed up there I guess. He said he tried using the RPi reboot shortcut I created on his desktop, which is just a batch file that uses PuTTY, before cutting the power and that didn't work but I guess that's normal if the RPi/OE had completely crashed, rather than just Kodi.
(2015-10-09, 19:34)bagofcrap24 Wrote: [ -> ]b21ee3425 = Good (Choosing Reboot on main menu doesn't actually restart, all connections stop but reboot doesnt happen)
e55ffaf45 = Bad
I hope these are the results you was expecting
Not quite. Was hoping for b21ee3425=Bad. Could you switch back to that kernel just to be sure.
I found
this bug fix which has gone into mainline kernel tree, but not the stable tree we use.
And that fixes a bug introduced in 0c1122ae6.
(2015-10-09, 20:00)popcornmix Wrote: [ -> ] (2015-10-09, 19:34)bagofcrap24 Wrote: [ -> ]b21ee3425 = Good (Choosing Reboot on main menu doesn't actually restart, all connections stop but reboot doesnt happen)
e55ffaf45 = Bad
I found this bug fix which has gone into mainline kernel tree, but not the stable tree we use.
My apologies, b21ee3425 is in fact Bad.
Must have not been waiting long enough for the lockup to occur when testing.
Definetly got the exact same lockup with b21ee3425. Solid green activity light, no response to SSH
Just trying 0c1122ae6 now
0c1122ae6 = Bad
Last Good Kernel = d36f8434d
(2015-10-09, 20:24)bagofcrap24 Wrote: [ -> ]My apologies, b21ee3425 is in fact Bad.
0c1122ae6 = Bad
Cool. That is what I hoped for.
Tonight's build will be back to 4.1.10 with a fix for the "deadlock" commit.
Hopefully that will be good too.
Thanks to the both of you for the time looking into this one.
New OpenELEC Jarvis build #1009:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.1.10 #1 Fri Oct 9 21:04:30 BST 2015 armv6l GNU/Linux
# vcgencmd version
Oct 4 2015 17:47:18
Copyright (c) 2012 Broadcom
version e7d3d0fe7ae383863dbf177ba62c0807b12df0d5 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151009210341-#1009-ge2b6fef [Build #1009]
# vcdbg log msg 2>&1 | grep DTOK
001738.192: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (e2b6fefc,
changelog) and tip of
XBMC master (783db620,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.1.y_rebase
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (2a9186e3, ahead +34)
- Includes latest kodi-platform master (15edaf78)
- Includes latest libcec master (2c675dac, ahead +31)
- Includes latest libnfs master (82d2a228, ahead +19)
- Includes latest platform master (feafe68e, ahead +4)
- Includes latest addons: adsp.basic (0f624784), adsp.biquad.filters (0c35df74), adsp.freesurround (cf13262d), asplib (39fe0a71), pvr.argustv (2bf67bb7, +29), pvr.demo (659712a0), pvr.dvblink (4d718970, +19), pvr.dvbviewer (0ca01b1a, +17), pvr.filmon (f9fe3bd5, +18), pvr.hts (1a128cd8, +1), pvr.iptvsimple (953477b7), pvr.mediaportal.tvserver (0e12d06c, +30), pvr.mythtv (702bda77), pvr.nextpvr (ef36c940, +20), pvr.njoy (cc2c4a69, +16), pvr.pctv (1494bfc1, +18), pvr.stalker (41fb7c42), pvr.vbox (e92c1236, +32), pvr.vdr.vnsi (8e0d73fb), pvr.vuplus (9ff818a4), pvr.wmc (3e396f5b, +22)
- Exclude [env] kodi-999.99-IMX-increase-render-buffers.patch: Conflict with newclock5/FernetMenta
- Exclude [env] rapidjson-01_native-what.patch: Use Kodi version for now
- Include [env] 2fd666ec: VAAPI: Enable EGL
- Include [env] 5bccbe3e: Kodi: Use Limited Range by default
- Include [env] 43f7e22a: Intel: Implement Passthrough-Range
- Include [env] 77368091: Mesa: Bump to 11.0.2
- Include [env] compare: Kodi 16 updates
- Include [env] patch: Enable RapidJSON, drop YASL
- Include [env] patch: Enable pvr addons, disable PVR updates
- Include [env] patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include [env] patch: Add experimental splash video
- Include [env] patch: Disable Realtek WiFi Power Save (RTL8192CU/RTL8192DU/RTL8812AU)
- Include [env] PR:4370: [linux] add patch from upstream to fix rtl28xxu
- Include [pkg] patch: Fix xcode after videoplayer before PR8008
- Include [pkg] PR:125: Fix for holding buttons on remotes of Philips TVs (libcec)
- Include [pkg] PR:8008: JSON: replace YAJL with RapidJSON
- Include [pkg] PR:8133: [videodb] Fix TV shows cleaning after 5755573981ca706a82a7ecbbdf5de112a570377a.
- Include [pkg] PR:8147: Stereoscopic depth for Confluence
- Revert [pkg] b5e3cc4b: sync cmake project (Reason: Breaks build on RPi1) (kodi)
- Revert [pkg] linux-999.20-mt7601u-support.patch: Reverted as patching order conflicts with rpi-4.1.y commits - continue using rpi-4.1.y equivalent (linux)
Build Highlights:
- New kernel 4.1.10, hopefully without lockup (thanks @bagofcrap24 & @popcornmix)
- New videodb schema v99
Build Details:
- XBMC:
- [guilib][gif] Make animated gifs loadable for any kind of textures, e… (PR:8188, 1 commit, 1 file changed)
- add functionality to set custom names for tvshow seasons (PR:6041, 2 commits, 6 files changed)
- Add idSeason to episode table (PR:8096, 2 commits, 4 files changed)
- Align video and music sort types on file listings to each other (PR:8184, 1 commit, 1 file changed)
- remove "Settings" context menu button from music and pictures views (PR:8190, 1 commit, 2 files changed)
- pvr.hts:
- add Coverity scan badge to README.md (fixes #108) (PR:110, 1 commit, 1 file changed)
- newclock5:
- New commits in this build:
- squash refactor sync (0517bd57)
- xcode crappy merge (8a47eaa3)
- VideoPlayer: allow speed up to 1.5 (faa47e99)
- VideoPlayer: flag and handle realtime streams (d1862c28)
- [videoplayer] Hacky scheme to enable accelerated playback as first ff step (ecdb6502)
- [Screensaver] Allow Dim screensaver to animate when closing (e1a3bd38)
- [videoplayer] Hacky scheme to enable accelerated playback as first ff step (0d7dbf5c)
- Commits no longer in build:
- XCode: update after refactoring of renderers (a84d2864)
- [osx/ios/atv2] - sync xcode project (03619543)
- Merge pull request #302 from wsnipex/fernet-master (b2daecf1)
- Merge pull request #303 from popcornmix/omxupdate (785c1186)
- Merge pull request #304 from popcornmix/mmalrenderbypass (72f7cdf6)
- [screensaver] Avoid getting stuck in dim state when skin is reloaded (b2b63a3e)
- [videoplayer] Candidate fix for stuck pause after buffering (6045e2b0)
- kernel 4.1.y_rebase:
- When replacing del_timer() with del_timer_sync(), I introduced (d820001a)
