2015-11-10, 20:40
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168
2015-11-10, 20:43
Something must be wrong with your setup, I'm watching live tv atm, rpi2, milhouse build, vdr vnsi. Perfect, HD channels too. Strange.
2015-11-10, 20:47
(2015-11-10, 20:39)gara93 Wrote: [ -> ]There is a stable OE 6 with jarvis 16? i try the stable version with isengaardand I have Always problems with pvr..
however i'm using a Milhouse build. and this is my log
No, stable OE6 is Isengard.
Trying a nightly/jarvis build is not likely to make things more stable. These builds are experimental and really only for testers.
If you just want a stable build then you will be better off trying to get your pvr working with OE6/Isengard
(post on the OE forum if you are having trouble).
2015-11-10, 20:50
(2015-11-10, 20:47)popcornmix Wrote: [ -> ](2015-11-10, 20:39)gara93 Wrote: [ -> ]There is a stable OE 6 with jarvis 16? i try the stable version with isengaardand I have Always problems with pvr..
Isengard is a problem...because the version of iptv simple client have a bug: channel switching is very slow (15sec)..with the new version of iptv simple client added in jarvis the problem dissapered..
then I can't installa isengard if i want a fast pvr client
2015-11-10, 20:53
I guess something must be wrong with the dvb-x tuner or the signal, or both. VDR is working perfect on Isengard and Jarvis OE versions running rpi2. Test your signal strength with tv or box, if good troubleshoot the dvb device. But this is off topic here.
2015-11-10, 21:20
This build accepts dolby hd and true hd making passtrought using raspb pi2? thanks
2015-11-10, 22:16
For VDR it's importand to to change default value of priority in VDR VNSI Client from "-1" to "0"
2015-11-10, 23:31
@popcornmix,
currently play a 3D MVC file(makemkv), then takescreenshot:
Result:
3DTAB. Why?
GUI is in 3DSBS Mode.
.bismarck
kodi-send --action="TakeScreenshot"
Result:
3DTAB. Why?
tvservice -s
state 0x12000a [HDMI CEA (32) 3D FP RGB lim 16:9], 1920x1080 @ 23.98Hz, progressive
Format-Profil: Stereo [email protected] / [email protected]
.bismarck
2015-11-10, 23:48
2015-11-11, 01:56
New OpenELEC Jarvis build #1110: RPi / RPi2
(Supercedes previous build)
Based on tip of OpenELEC master (2a7db0dc, changelog) and tip of XBMC master (aa42e1b8, changelog) with the following modifications:
# uname -a
Linux rpi512 4.3.0 #1 Tue Nov 10 21:46:48 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Nov 6 2015 21:55:08
Copyright (c) 2012 Broadcom
version 40eee6c6d44edb1db4302217927a66a8dffd9374 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151110214556-#1110-g2a7db0d [Build #1110]
# vcdbg log msg 2>&1 | grep DTOK
001711.735: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.3.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (a9888b67, ahead +40)
- Includes latest kodi-platform master (45d6ad19, ahead +1)
- Includes latest libcec master (2c675dac, ahead +31)
- Includes latest libnfs master (dc8d8662, ahead +22)
- Includes latest platform master (feafe68e, ahead +4)
- Includes latest addons: adsp.basic (89015163), adsp.biquad.filters (1746fe46, +2), adsp.freesurround (f0c6bf00), asplib (df5c386d, +1), pvr.argustv (2bf67bb7), pvr.demo (659712a0), pvr.dvblink (4d718970), pvr.dvbviewer (0ca01b1a), pvr.filmon (bea2509b), pvr.hts (f9de7ee9, +3), pvr.iptvsimple (953477b7), pvr.mediaportal.tvserver (0e12d06c), pvr.mythtv (e088636e), pvr.nextpvr (b902321f), pvr.njoy (cc2c4a69), pvr.pctv (1494bfc1), pvr.stalker (6a305122, +4), pvr.vbox (e92c1236), pvr.vdr.vnsi (21deb7ec, +27), pvr.vuplus (9ff818a4), pvr.wmc (ec514227)
- Includes commits from xbmc/json-profile-directory_2, ahead +2 (anaconda)
- Includes commits from service.openelec.settings/bluetooth_pulseaudio, ahead +2 (lrusak)
- Exclude [env] kodi-999.22-PR8254.patch: Already using VideoPlayer version
- Exclude [env] kodi-999.60-udevprovider-fix-mounting-raw-filesystems.patch: Already merged upstream
- Exclude [env] kodi-999.99-IMX-increase-render-buffers.patch: Conflict with newclock5/FernetMenta
- Exclude [env] libnfs-master.patch: Already merged upstream
- Include [env] compare: pulseaudio and kodi
- Include [env] compare: xf86-video-intel: Bump to 627ef68 fixes refreshrates missing after startup; linux cleanup
- Include [env] compare: EGL/4K/HEVC, mesa, Use Limited Range by default
- Include [env] patch: Build pulseaudio for all projects
- Include [env] patch: Build fix
- Include [env] patch: Enable DMA_BCM2835, needed by i2s audio cards in 4.3 kernel
- Include [env] patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Add experimental splash video
- Include [env] PR:4378: RFC: Disable libaacs, causes GUI hangs on some BD ISOs
- Include [pkg] PR:125: Fix for holding buttons on remotes of Philips TVs (libcec)
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8282: [python] Fixed getRegion dateshort format without leading zero
- Include [pkg] PR:8356: Fix inversion of export library dialogs, fix #16317, fix #16358
- Use ALSA-to-PulseAudio bridge
- OpenELEC:
- bcm_sta: update to 6.30.223.271 (PR:4435, 1 commit, 14 files changed)
- XBMC:
- Minor keyboard.xml improvements (PR:8338, 1 commit, 1 file changed)
- [gui] Sort include files on GUIWindowLoginScreen.* alphabetical (PR:8343, 1 commit, 2 files changed)
- Fix missing artist names in legacy Python music interface (PR:8354, 1 commit, 3 files changed)
- [PVR] Fix for recording associations (PR:8141, 1 commit, 1 file changed)
- [events] fix crash when attempting to install an addon not in a repository from the event list (aa42e1b8)
- pvr.hts:
- Added support for oneshot timer enable/disable (HTSP v23 feature), closes #131 (PR:133, 1 commit, 4 files changed)
- xbmc/json-profile-directory_2 (anaconda):
- newclock5:
- New commits in this build:
- Commits no longer in build:
- ffmpeg: bump to 2.8-pre (38b7efd6)
- x11: use the standard hint for disabling compositing (97041eba)
- Compositors: Only disable them if actually in use (24b07229)
- paplayer: wait for eof if no crossfading or cue sheet (dac5d66d)
- Merge pull request #313 from philipl/fernetmenta (79142168)
- Skip frames with an illegal dimension rather than abort. (0578eac4)
- Check frame dimensions. (f39124fe)
- Check if there's a frame, before accessing it. This prevents a possible access violation. (3d36674a)
- Add width and height of the texture/buffer to the interface method Decode(...). (8069b240)
- Crop too large image/frame in Decode. This fixes a possible access violation. (8a3c4ea4)
- Crop too large image/frame in Decode. This fixes a theoretically possible access violation. (a9dcc15c)
- Crop too large image/frame in Decode. This fixes a theoretically possible access violation. (647723f9)
2015-11-11, 12:23
2015-11-11, 12:36
(2015-11-11, 12:23)parcel Wrote: [ -> ]In video Addons list I click 'more...' button clicked, Kodi crashes,
http://xbmclogs.com/pelfff3an
Do you mean the Video -> Addons -> "Get more..." button, as this is working for me with build #1110 (ie. not crashing).
Can you try with a clean .kodi?
Based on the crashlog, it doesn't look like the crash has anything to do with the addons... at least nothing to do with you clicking the "Get more..." button, however the log does mention:
16:35:16 128.451538 T:1965400064 ERROR: exception in CApplication::FrameMove()
It seems that once this CApplication::FrameMove() error occurs - which I suspect is causing some internal screw up - it's only a matter of time before Kodi eventually falls over.
2015-11-11, 12:55
(2015-11-11, 12:36)Milhouse Wrote: [ -> ](2015-11-11, 12:23)parcel Wrote: [ -> ]In video Addons list I click 'more...' button clicked, Kodi crashes,
which has been implicated in previous crashes.Code:16:35:16 128.451538 T:1965400064 ERROR: exception in CApplication::FrameMove()
Yes, 'Get more...' button.
I'm try to delete related cache file or something
(edit) delete all '.fi' files in temp folder, problem is gone. Thank you!
2015-11-11, 14:19
(2015-11-11, 12:55)parcel Wrote: [ -> ](edit) delete all '.fi' files in temp folder, problem is gone. Thank you!
Actually I've seen that has been needed a few times with nightly builds.
They are cache files which I think can become invalid when a PR gets modified (as often happens when they are pulled into these builds before merging).
I wonder how much cost you'd suffer from deleting them on each boot? If it's negligible it might be worth doing this on each boot (or each update).
2015-11-11, 15:00
I'll add a quick fix that cleans the *.fi every time kodi is started. It's probably overkill (I'm assuming there's a benefit from having old cache files lying around, until that is they break the current build) but cleaning the cache files from init isn't ideal either.
If the cache files cause problems with different builds then perhaps the cache files need to be versioned...
