2015-11-29, 10:07
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168
2015-11-29, 11:52
DVD pop-up menu isn't working in #1128: RPi2
Starts without sound and selectable Options (play/Track/sound).
last god is #1001
last god is #1001
2015-11-29, 12:06
Bit of a weird one this. My brother reports that on his RPi2 (#1015) Tvheadend keeps randomly uninstalling itself (he says he sees a message popup that it's been uninstalled) and he has to reinstall it to get it working again.
He's not very tech-minded but at least I managed to teach him how to send me the log and he says that it uninstalled again shortly before sending me this one: http://xbmclogs.com/p6baakdvf
I'm using the same USB tuner and was on #1015 for a while (I'm on #1022 at the moment) and didn't have this problem, although the tuner does still randomly disappear and I think I have to power-cycle the RPi to get it working again, certainly a reboot doesn't do the trick.
2015-11-29, 12:32
(2015-11-29, 09:11)Milhouse Wrote: [ -> ]Switched from build #1127 to #1128 this morning and tvheadend client indicated that Tvheadened backend was lost(2015-11-29, 07:40)gendo Wrote: [ -> ]getting this error when starting tvheadend.
tvheadend: error while loading shared libraries: libssl.so.32: cannot open shared object file: No such file or directory
Use the latest #1128 tvheadend from the addons folder. The last #1128 build bumped libressl and now includes libssl.so.35 so any add-ons linking against a shared libssl will need to be updated.
(as mentioned by others in thread)
Manually Installed latest tvheadend backend zip aligned with build #1128 from link above and instantly tvheadend backend was up and running. (no need to reboot openelec and Rpi2)
Thanks @Milhouse and @gendo
2015-11-29, 12:39
Can't seem to install the vdr #1128 zip with #1128.
10:36:56 405.272827 T:1965342720 DEBUG: CAddonInstaller: installing from zip '/storage/downloads/service.multimedia.vdr-addon-6.0.1-#1128-milhouse.zip'
10:36:56 405.294525 T:1650168736 DEBUG: CAddonInstallJob[pvr.vdr.vnsi]: requires xbmc.pvr version 1.9.6 which is not available
10:36:56 405.295715 T:1650168736 ERROR: CAddonInstallJob[service.multimedia.vdr-addon]: The dependency on pvr.vdr.vnsi version 1.9.6 could not be satisfied.
I have v1.11.8 of the VDR VNSI Client installed.
2015-11-29, 13:38
thanks.
(2015-11-29, 09:11)Milhouse Wrote: [ -> ](2015-11-29, 07:40)gendo Wrote: [ -> ]getting this error when starting tvheadend.
2015-11-29, 15:24
(2015-11-29, 12:39)doveman2 Wrote: [ -> ]Can't seem to install the vdr #1128 zip with #1128.
Just unzip vdr-addon manually at the command line into /storage/.kodi/addons. If you try installing from inside Kodi, Kodi will validate against online dependencies (which are out of date) rather than against the bundled (and up-to-date) pvr.vdr.vnsi client.
2015-11-29, 17:29
(2015-11-26, 12:27)bagofcrap24 Wrote: [ -> ]1125 does reboot reliably
#1124y Fail to reboot - http://pastebin.com/bTYTizSy
#1125 reboot works - http://pastebin.com/4dmwTz7N
connman-1.30 will be restored in the next test build, #1129, as it is has now merged upstream (sorry, I completely forgot about this issue having removed it from the RPi test builds, but left it in the x86 test builds - so far yours is only negative report).
Can you re-test #1129 and see if the reboot issue remains? I'm hoping it's fixed now that the garbage services added by systemd-228 in #1121 have been removed - perhaps connman-1.30 was more sensitive to these extra bogus services than connman-1.23.
2015-11-29, 18:10
I'll try again once I'm home.
2015-11-29, 20:23
Seems there is a Problem with libssl.so.32 and openvpn ? (#1128)
With #1126 it works.
OpenELEC:~ # openvpn /storage/.kodi/addons/network.openvpn/bin/openvpn/ovpn-open
elec/openelec.ovpn
openvpn: error while loading shared libraries: libssl.so.32: cannot open shared object file: No such file or directory
2015-11-29, 21:21
I've uploaded a new openvpn addon to the addons folder.
2015-11-29, 21:28
I discovered a strange thing:
I have many 23.976 and 24 fps movie.
I setted up change refresh rate to movie fps, gui to 1808p 50hz
When i start the movie it randomly played at 24 or 25 fps, when i see in tv the input frequency.
When i start, and play the 23.976 movie at 25hz, little bit jerky the picture. Then i stop the movie, and start again, then play it the good 24 (i think 23.976) fps.
How can once 24, once 25 fps playing the same movie?
I use 60' lg plasma (2013), and onkyo tx-nr3008 avr.
2015-11-29, 23:28
(2015-11-16, 13:58)popcornmix Wrote: [ -> ](2015-11-16, 00:00)nalor Wrote: [ -> ]I'm trying to play encrypted iso files in 2D (this worked in the past without problems) and 3D if possible.
But just for interest I could really try to play discs also directly from optical drive
Is this currently working on OE 6.0? That does have libaacs.
Is it slower to start playback of encrypted ISOs?
Logically it would make more sense to remove the encryption when ripping the ISO rather than trying to remove it every time you play the ISO (potentially needing decryption support on multiple devices).
I would be interested if you can play straight from an optical BlueRay drive (either locally attached or from a network share). Don't think I've heard of that working (except from a network share from a PC running anydvd or similar to remove the encryption).
I'm sorry it took longer than expected to try those things - but today I've managed to execute the tests today
I've connected my external usb bluray drive to the pi2 and also prepared a iso of the bluray 'Battleship' with AACS protection left untouched and a 2nd iso with AACS removed.
All test performed with default OpenELEC 6.0 installation on pi2 and I took the times until the playback started with a stopwatch on my smartphone.
Test 1: insert battleship-bluray into drive (when it is recognized the 'play disc' item is added to the main toolbar) and start playback - it takes about 5-6 seconds until the playback starts.
Test 2: start playback of AACS protected iso of the same disc: it takes about 5-6 seconds until the playback starts.
Test 3: start playback of unprotected iso of the same disc: it takes about 5-6 seconds until the playback starts.
The bottom line is I didn't notice any difference between playback-start-times from AACS protected or unprotected iso and directly from optical drive.
Can you tell what kind of problems appeared with libaacs? I couldn't find anything here in this thread nor in the RaspberryPi section here in the forum - I only noticed that libaacs got removed beginning with build #1010 and the comment 'disable libaacs as this seems to be responsible for BD ISO crashes' - but couldn't find details about this issue.
Is it possible to active libaacs in recent builds? Or has it to be activated already during compilation? Would it be possible to create eventually a single build with enabled libaacs? Thanks!
2015-11-29, 23:56
(2015-11-29, 23:28)nalor Wrote: [ -> ]Can you tell what kind of problems appeared with libaacs? I couldn't find anything here in this thread nor in the RaspberryPi section here in the forum - I only noticed that libaacs got removed beginning with build #1010 and the comment 'disable libaacs as this seems to be responsible for BD ISO crashes' - but couldn't find details about this issue.
https://github.com/OpenELEC/OpenELEC.tv/pull/4378
(2015-11-29, 23:28)nalor Wrote: [ -> ]Is it possible to active libaacs in recent builds? Or has it to be activated already during compilation? Would it be possible to create eventually a single build with enabled libaacs? Thanks!
It has to be activated during compilation and so far there seems to be little benefit in doing so, as hardly anyone appears to be using encrypted ISOs (based on almost total lack of complaints now that libaacs is disabled in these builds). Ideally of course we will get to the bottom of the problem so that libaacs can be re-enabled, but while it causes problems with unencrypted ISOs - which are used way more often than encrypted optical - it seems more sensible to leave it disabled, at least for these test builds.
2015-11-30, 00:39
New OpenELEC Jarvis build #1129: RPi / RPi2
(Supercedes previous build)
Based on tip of OpenELEC master (c5875ae6, changelog) and tip of XBMC master (dc270bcd, changelog) with the following modifications:
# uname -a
Linux rpi512 4.3.0 #1 Sun Nov 29 21:35:26 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Nov 25 2015 17:54:26
Copyright (c) 2012 Broadcom
version fda23007cfd89bf42af864b57701b39e1ac8c552 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151129213436-#1129-gc5875ae [Build #1129]
# vcdbg log msg 2>&1 | grep DTOK
001707.922: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.3.y_rebase
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (41d36b1a, ahead +71)
- Includes latest kodi-platform master (45d6ad19, ahead +1)
- Includes latest libcec master (ff86c07a, ahead +21)
- Includes latest libnfs master (dc8d8662, ahead +22)
- Includes latest platform master (2dac5ac7, ahead +6)
- Includes latest addons: adsp.basic (cb56e0eb, +4), adsp.biquad.filters (d63d8ac6, +6), adsp.freesurround (08b691d3, +1), asplib (2fac1bf3, +2), pvr.argustv (2bf67bb7), pvr.demo (659712a0), pvr.dvblink (58f7beba, +5), pvr.dvbviewer (0ca01b1a), pvr.filmon (bea2509b), pvr.hdhomerun (070aca3b), pvr.hts (0774d6fd), pvr.iptvsimple (953477b7), pvr.mediaportal.tvserver (5cd3d5a4, +2), pvr.mythtv (b1f5764f), pvr.nextpvr (b902321f), pvr.njoy (cc2c4a69), pvr.pctv (1494bfc1), pvr.stalker (9a6d06e2), pvr.vbox (e92c1236), pvr.vdr.vnsi (92d452f2, +7), pvr.vuplus (9ff818a4), pvr.wmc (ec514227)
- Exclude [env] bcm2708-rng.conf: No longer required
- Exclude [env] kodi-999.22-PR8254.patch: Already using VideoPlayer version
- Exclude [env] kodi-999.23-PR8411.patch: Merged upstream
- Exclude [env] kodi-999.99-IMX-increase-render-buffers.patch: Conflict with newclock5/FernetMenta
- Exclude [env] libcec-01-add-repeating-keypress.patch: Already merged upstream
- Exclude [env] libcec-02-fix-crash-on-some-systems.patch: Already merged upstream
- Exclude [env] libnfs-master.patch: Already merged upstream
- Include [env] 058cd657: Intel: Add tearfree to default config - fixes framedrops (handle with care)
- Include [env] 76afdb47: ffmpeg: Bump to 2.8.3
- Include [env] compare: EGL/4K/HEVC, mesa, Use Limited Range by default, bump xf86-video-intel; linux cleanup
- Include [env] patch: Clean Kodi view cache on startup
- Include [env] patch: ARCH_BCM270X: Drop ATAGS support, https://github.com/raspberrypi/linux/pull/1178
- Include [env] patch: Enable DMA_BCM2835, needed by i2s audio cards in 4.3 kernel
- Include [env] patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include [env] patch: Add experimental splash video
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] PR:4378: RFC: Disable libaacs, causes GUI hangs on some BD ISOs
- Include [pkg] PR:7030: CNetwork - implement IPv6
- Include [pkg] PR:8196: jsonrpc: expose profile directory in Profiles.GetCurrentProfile/GetProfiles.
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8282: [python] Fixed getRegion dateshort format without leading zero
- Include [pkg] PR:8419: add InstallAddon builtin
- Revert [pkg] b671fe50: LinuxInputDevice: add support for multi-touch devices (Reason: See if helps jackiass)
- connman-1.30 (@bagofcrap24: please re-test rebooting, thanks)
- OpenELEC:
- XBMC:
- dcadec:
- adsp.biquad.filters:
- adsp.freesurround:
- change xml save way (08b691d3)
- asplib:
- newclock5:
- New commits in this build:
- [win32] Sync VS project. (d2349c7e)
- Commits no longer in build:
- [HwRendererVTB] - add to CMakeLists.txt and Makefile buildsys (4d2711dd)
- [rbp] Add ntsc version of 48Hz mode (5bd7f413)
- [rbp] Extract the correct resolution with Pi LCD (5afde465)
- [rpb] Change order or CEA and DMT mode probing so CEA modes are preferred (ed637319)
- [pisink] testing: Reduce audio output latency to 50ms (e6a7cdc1)
- squash: rbp: Allow interlaced resolutions into supported hdmi mode list 2 (928a1d52)
- squash: rbp: Frame-packing modes muct be <= 30Hz) (01891100)
- [PiSink] squash: Also clear passthrough streamTypes (ba5edb73)
- fixup! AE: update omx audio (4a4f4d95)
- squash: add 3d hdmi mode to log (18fe5c2d)
