I searched the thread for HDMI Passthrough and tried some of the fixes but still experiencing the same problems.
When I run the Public 6.0.0 on the RPI2 using my Yamaha amp. The amp says DTS or Dolby Digital with passthrough enabled.
When I run the Chris Swan devel builds I run Jarvis and the amp behaves the same.
On the millhouse builds even with Passthrough enabled the amp says PCM.
Am I doing something wrong with my setup?
Here is the debug log
http://sprunge.us/WPMe
I tried with the movie Trainwreck
Thanks for the help in advance
@bill_orange: Thanks, have added a comment on
PR:4442 - let's see what happens...
(2015-12-01, 00:38)Tsyko Wrote: [ -> ]Am I doing something wrong with my setup?
With VideoPlayer you need to disable "sync playback to display" if you want passthrough.
New OpenELEC Jarvis build #1130:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.3.0 #1 Mon Nov 30 21:02:50 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Nov 25 2015 17:54:26
Copyright (c) 2012 Broadcom
version fda23007cfd89bf42af864b57701b39e1ac8c552 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151130210202-#1130-gc5875ae [Build #1130]
# vcdbg log msg 2>&1 | grep DTOK
001691.018: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (c5875ae6,
changelog) and tip of
XBMC master (558a8f18,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.3.y_rebase
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (b35fdcf6, ahead +73)
- Includes latest kodi-platform master (45d6ad19, ahead +1)
- Includes latest libcec master (4905a709, ahead +23)
- Includes latest libnfs master (dc8d8662, ahead +22)
- Includes latest platform master (2c8d36ef, ahead +7)
- Includes latest addons: adsp.basic (cb56e0eb, +4), adsp.biquad.filters (d63d8ac6, +6), adsp.freesurround (08b691d3, +1), asplib (2fac1bf3, +2), pvr.argustv (2bf67bb7), pvr.demo (659712a0), pvr.dvblink (58f7beba, +5), pvr.dvbviewer (0ca01b1a), pvr.filmon (bea2509b), pvr.hdhomerun (070aca3b), pvr.hts (0774d6fd), pvr.iptvsimple (953477b7), pvr.mediaportal.tvserver (5cd3d5a4, +2), pvr.mythtv (b1f5764f), pvr.nextpvr (b902321f), pvr.njoy (cc2c4a69), pvr.pctv (1494bfc1), pvr.stalker (9a6d06e2), pvr.vbox (e92c1236), pvr.vdr.vnsi (92d452f2, +7), pvr.vuplus (9ff818a4), pvr.wmc (ec514227)
- Exclude [env] bcm2708-rng.conf: No longer required
- Exclude [env] kodi-999.22-PR8254.patch: Already using VideoPlayer version
- Exclude [env] kodi-999.23-PR8411.patch: Merged upstream
- Exclude [env] kodi-999.99-IMX-increase-render-buffers.patch: Conflict with newclock5/FernetMenta
- Exclude [env] libcec-01-add-repeating-keypress.patch: Already merged upstream
- Exclude [env] libcec-02-fix-crash-on-some-systems.patch: Already merged upstream
- Exclude [env] libnfs-master.patch: Already merged upstream
- Include [env] 058cd657: Intel: Add tearfree to default config - fixes framedrops (handle with care)
- Include [env] 76afdb47: ffmpeg: Bump to 2.8.3
- Include [env] compare: EGL/4K/HEVC, mesa, Use Limited Range by default, bump xf86-video-intel; linux cleanup
- Include [env] patch: Clean Kodi view cache on startup
- Include [env] patch: ARCH_BCM270X: Drop ATAGS support, https://github.com/raspberrypi/linux/pull/1178
- Include [env] patch: Enable DMA_BCM2835, needed by i2s audio cards in 4.3 kernel
- Include [env] patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include [env] patch: Add experimental splash video
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] PR:4378: RFC: Disable libaacs, causes GUI hangs on some BD ISOs
- Include [pkg] PR:7030: CNetwork - implement IPv6
- Include [pkg] PR:8196: jsonrpc: expose profile directory in Profiles.GetCurrentProfile/GetProfiles.
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8282: [python] Fixed getRegion dateshort format without leading zero
- Include [pkg] PR:8419: add InstallAddon builtin
- Revert [pkg] b671fe50: LinuxInputDevice: add support for multi-touch devices (Reason: See if helps jackiass)
Build Highlights:
- Some VideoPlayer updates
Build Details:
- XBMC:
- ffmpeg: Bump to 2.8.3-Jarvis-beta3 (PR:8455, 1 commit, 1 file changed)
- [gui] drop video/music overlay dialogs leftover part III (PR:8453, 1 commit, 1 file changed)
- remove broken musicvideos scraper (PR:8398, 1 commit, 55 files changed)
- [strings] fix incorrect setting description (4835ee41)
- [string] fix c/p mistake (558a8f18)
- dcadec:
- Use defines instead of magic numbers for IDCT calculations (bdcdf30a)
- Use more defines for IDCT calculations. (b35fdcf6)
- libcec:
- Use a single number as major SO version like others (PR:161, 1 commit, 3 files changed)
- added: Sharp uses vendor id 0x534850 too. issue #36 (4905a709)
- platform:
- fixed: compilation with vs2015. issue #19 (2c8d36ef)
- newclock5:
- New commits in this build:
- VideoPlayer: rework HandlePlayspeed (2da06c2a)
- VideoPlayer: trash method OpenStreamPlayer - enables detection if stream was actually opened or not (097a209a)
- [videoplayer] Add logging of message queue levels (2817b61b)
- Commits no longer in build:
(2015-11-29, 21:21)Milhouse Wrote: [ -> ]I've uploaded a new openvpn addon to the addons folder.
Thanks, that fixes the issue
Had an issue just now with #1128 when I tried to play a file an mkv. It got stuck on the busy spinner for about a minute before it eventually gave up and said it couldn't play the file. I then tested by playing a smaller mp4 version of the same episode and then the mkv again, both of which worked fine this time.
The log shows I pressed Select at 01:02:18 and the error message came up at 01:03:40
http://xbmclogs.com/p60uhwfjc
Incidentally, I keep the 1280x720 versions in the series folder and smaller versions in a sub-folder "Spare" to put on portable devices or share with friends who don't much care about quality but Kodi shows both, so I have two copies of each episode listed and no idea which is which. Is there a way to stop Kodi scanning past the first folder (i.e. Media/Videos/Series/x/) to avoid this?
(2015-11-29, 15:24)Milhouse Wrote: [ -> ]Just unzip vdr-addon manually at the command line into /storage/.kodi/addons. If you try installing from inside Kodi, Kodi will validate against online dependencies (which are out of date) rather than against the bundled (and up-to-date) pvr.vdr.vnsi client.
Thanks, that was an easy workaround.
(2015-11-29, 12:06)doveman2 Wrote: [ -> ]Bit of a weird one this. My brother reports that on his RPi2 (#1015) Tvheadend keeps randomly uninstalling itself (he says he sees a message popup that it's been uninstalled) and he has to reinstall it to get it working again.
He's not very tech-minded but at least I managed to teach him how to send me the log and he says that it uninstalled again shortly before sending me this one: http://xbmclogs.com/p6baakdvf
I'm using the same USB tuner and was on #1015 for a while (I'm on #1022 at the moment) and didn't have this problem, although the tuner does still randomly disappear and I think I have to power-cycle the RPi to get it working again, certainly a reboot doesn't do the trick.
Bit more information from my brother. He says the message he sees is "'successfully removed device", so it doesn't actually sound like Tvheadend is being uninstalled. It may be just a coincidence that he sees this and finds TVh isn't working until he re-installs it and maybe he's running into the same problem as I have with the tuner randomly disappearing, at least as far as TVh is concerned. Any ideas what that message might be about though? I searched the log and the only mention of 'removed' I found was near the end where it says 'UDev: Removed (null)'.
I'll try updating him to #1128, the same as I'm on now, to see if that improves things for him anyway.
(2015-12-01, 01:42)popcornmix Wrote: [ -> ] (2015-12-01, 00:38)Tsyko Wrote: [ -> ]Am I doing something wrong with my setup?
Thanks... Worked like a charm
in #1130: RPi / RPi2 also DVD Menu did not work, sorry (#1001 work fine)
I still having problems when switching back to 2D mode on my Phillips TV
#1001 bad 3D picture, but switching back is working
#1016 working
#1104 working
#1105 working
#1106 working
#1107 working
#1108 working
#1109 working
#1110 fails
#1111b fails
#1112 fails
#1113 fails
#1114 fails
#1115 fails
#1116 fails
#1117 fails
#1118 fails
#1119 fails
#1120 fails
#1121 fails
#1122 fails
#1123 fails
#1124 fails
#1125 fails
#1126 fails
#1127 fails to boot
#1128 fails
#1129 fails
#1130 fails
here the Debug-Logs:
B1109:
http://pastebin.com/vrYNmRfh
B1110:
http://pastebin.com/vNAYwv7p
^Now that's how you report an issue
#1130: Can't play next chapter in ISO file by select from remote
Btw, when select Video first time: show modal dialog "Loading directory" with content source://video (Music the same): not necessary
in build #1001 iso file works fine
