(2015-09-11, 15:08)popcornmix Wrote: [ -> ] (2015-09-10, 20:53)polo_joe Wrote: [ -> ]anything else I could try to debug my playback problem?
Can you try this test firmware.
Copy start_x.elf and fixup_x.dat and replace start.elf and fixup.dat from the boot partition of OE sdcard.
and add:
hvs_priority=0x100000
I wonder if reducing the sdram priority of the deinterlacer may help.
Tried latest build, less artefacts but still there. also tvheadend discontinuity counter slowly increasing.
Hi great work on the official RPI touchscreen support
Can I ask if there will be further adjustments to how screen taps are processed
I am referring to latest build is smooth on the pointer to finger but selection requires double tap can this or will this be changed to one click selection to simulate android or ios touchscreen
Thanks again and I hope I'm not over stepping the mark by asking
Tested 3D ISO playback, works just as well as MVC MKV. Think I'll stick to latter though as smaller footprint and quicker playback.
Re: ISO's, chapter skips aren't enabled yet it appears? I only tried in 3D mode.
(2015-09-17, 15:14)popcornmix Wrote: [ -> ] (2015-09-17, 14:58)woronczak Wrote: [ -> ]HDMKV - I'm not entirely sure that's exactly the same issue. This happens 100% of the time if the GUI resolution is 1080 / 23.98 on any 3d movie and it doesn't say "no signal" - W1070 the projector stays on 1080 / 24 / Frame packing and the GUI shows up with the L half of the screen overlapping the right one (so Kodi is not sending or the Projector is not receiving the message to turn back to the GUI resolution of 1080/23.98 without frame packing).
Can you ssh in and report output of:
when you have the overlapping gui.
state 0x12000a [HDMI CEA (32) RGB lim 16:9], 1920*1080 @ 23.98Hz, progressive
Hope that helps
New OpenELEC Jarvis build #0917:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.1.7 #1 Thu Sep 17 22:22:18 BST 2015 armv6l GNU/Linux
# vcgencmd version
Sep 17 2015 19:44:51
Copyright (c) 2012 Broadcom
version bf3605ae6ee50c1fb2f0ce5f3e75a38d12a53c7d (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150917222016-#0917-g2eec924 [Build #0917]
# vcdbg log msg 2>&1 | grep DTOK
001735.947: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (2eec9240,
changelog) and tip of
XBMC master (1971f023,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.1.y_rebase
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (2a9186e3, ahead +34)
- Includes latest kodi-platform master (15edaf78)
- Includes latest libcec master (e8506b3d, ahead +29)
- Includes latest libnfs master (e453431d, ahead +43)
- Includes latest platform master (feafe68e, ahead +4)
- Includes latest addons: adsp.basic (da6ee5dd), adsp.biquad.filters (d940a0d1, +1), adsp.freesurround (0bc31e26, +1), asplib (ab13a4fa, +26), pvr.argustv (77c12d90), pvr.demo (d222579f), pvr.dvblink (5ca213d0), pvr.dvbviewer (97743726), pvr.filmon (e3ae2385), pvr.hts (0e08a168), pvr.iptvsimple (e2cd8ee3), pvr.mediaportal.tvserver (3f49cde8), pvr.mythtv (ee57d911, +3), pvr.nextpvr (87c378dc), pvr.njoy (0a49bfc0), pvr.pctv (4b166b12), pvr.stalker (c07e2bf0), pvr.vbox (84aa6969), pvr.vdr.vnsi (a26f5c9b, +1), pvr.vuplus (f933e8e0), pvr.wmc (8b4182f2)
- Exclude kodi-999.99-IMX-increase-render-buffers.patch: Conflict with newclock5
- Include e85044c6: mesa: Bump to 10.6.6 (add r8 and GR88 transfer methods)
- Include f2932a88: VAAPI: Bump driver and lib to 1.6.1 (enable EGL)
- Include 6d895e39: ffmpeg: Add hevc fix
- Include 65305aa7: mesa: Bump to 11.0.0 (delete r8 and GR88 transfer methods)
- Include compare: Kodi 16 updates
- Include patch: Add kernel SDIO support
- Include patch: Fix for PR:113 (libcec)
- Include patch: linux: update to linux-4.1.7
- Include patch: Enable RPi and some other touchscreens (similar to Raspbian)
- Include patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include patch: Add experimental splash video
- Include patch: Enable pvr addons (x86: disable pvr.vdr.vnsi), disable PVR updates
- Include PR:125: Fix for holding buttons on remotes of Philips TVs (libcec)
- Include PR:4266: [systemd] update to systemd-224
- Include PR:4284: [Python] update to 2.7.10
- Revert d0f7dba3: Reason: Not bumping mesa 10.6.7 yet
- Revert 06e44c38: Reason: mesa 10.6.7 makes a mistake when reverting an i965 patch
- Revert linux-999.20-mt7601u-support.patch: Reverted as patching order conflicts with rpi-4.1.y commits - continue using rpi-4.1.y equivalent (linux)
- Revert PR:8031: AdjustRefreshrate: Switch to higher resolution depending on source dims
Build Highlights:
- New firmware
- Drop RapidJSON due to PVR.GetChannels problem
Build Details:
- Firmware (Sep 17):
- firmware: video codec: Cleanup of fix for regression from refactor userdata release mechanics in categoriser commit
- OpenELEC:
- sqlite: update links to secure (e39ca595)
- libmicrohttp: update to libmicrohttp-0.9.23, update licence and links(secure) (2eec9240)
- XBMC:
- FIX: [droid;storage] check readability last (PR:8066, 1 commit, 1 file changed)
- [appmessenger] Fix broken python addons after #7800 (PR:8065, 1 commit, 1 file changed)
- [Fix]CMusicInfoTag: Remove duplicated setters added in #8012 (PR:8071, 1 commit, 1 file changed)
- AdjustRefreshrate: Switch to higher resolution depending on source dims (PR:8031, 1 commit, 1 file changed)
- [osx/ios] - add support for compiling with Xcode7 MacOSX SDK 10.11 and iOS SDK 9.0 (PR:8072, 11 commits, 12 files changed)
- pvr.vdr.vnsi:
- epg: fill episodeName with short text (PR:29, 1 commit, 2 files changed)
- Reverted: PR:8031: AdjustRefreshrate: Switch to higher resolution depending on source dims
Periodically while watching recorded TV and skipping commercials, I'll skip too far forward and start skipping 10 seconds backward. After a few one or more skips backward, the video stops and freezes but the audio continues. I'll see this in the log:
20:15:11 84823.281250 T:1632084992 ERROR: CDVDMsgGeneralSynchronize - timeout
20:15:12 84824.187500 T:1632084992 ERROR: Previous line repeats 12 times.
The recorded TV is mpeg2 at 1080i60 and I'm using advanced deinterlacing.
It finally occurred to me to try disconnecting stuff to try and fix my "stutter every 9s with Live TV and recordings" problem and I traced the problem down to....my remote receiver!
It's an Emprex 3000ARF, whilst my brother's is the slightly different URF model so it's possible he doesn't have the same problem but I expect they're not that different and he probably will have.
With the dongle disconnected, I tried playing back my earlier recordings and even with MMAL-Advanced deinterlace there was no stutter. Then I tried LiveTV and that was smooth too.
Saying that, I then got some major audio pitch fluctuating with the signature music on Sky News. Bringing up the overlay showed around 68ms err on the P line, which dropped to about 9ms once the problem settled down.
I've uploaded the relevant extract from the (52MB) log here:
https://drive.google.com/file/d/0B1fDI89...sp=sharing
I do need to fix the problem with the IR receiver as well, as whilst I can use CEC (most of the time at least, sometimes the RPi won't come out of screensaver Dim mode unless I use the Emprex remote but I've disabled the Screensaver now, so hopefully that will fix that) my brother can't and has to use the remote. It's much nicer than using the TV's one anyway, as it has loads of dedicated buttons for playback controls and jumping to specific features like Music, EPG, Pictures, etc. So if anyone can advise how to stop it causing this problem, that'd be much appreciated.
I'm having a problem with video addons, starting with rpi2 build 907 (906 is great!).
When using a very popular video plugin, and this happens on at least one other popular plugin that I know of, and browsing though file lists, I've noticed that the display list is now forced to refresh every ~13 seconds. This results in being thrown back to the top of the list every 13 seconds--highly annoying when you're trying to figure out what to watch. Other times, if the refresh hits at some point during the processing of a file selected for play, I'll have to select "full screen" to get to the video right. And one time the refresh kicked me from one addon back to a previous one I'd been using.
I tested builds 917, 914, 911, 907, 906, 904, 901, and 823 in regards to this problem. The problem started with 907.
Thanks to all the devs, especially Milhouse, for your work. You've been rocking my 'box since 2002.
@dlxmax: Are you able to reproduce this using an add-on that can be discussed on the forum, eg. YouTube? Nothing in #0907 leaps out at me that might be causing this odd behaviour, and I haven't noticed it myself so far. Anything in a
debug log (wiki)?
PR:7874 is the only possibility I can see from #0907, but it's not immediately obvious how a repo updating is affecting an add-ons file list (but it's not completely implausible).
(2015-09-18, 00:43)hdmkv Wrote: [ -> ]Tested 3D ISO playback, works just as well as MVC MKV. Think I'll stick to latter though as smaller footprint and quicker playback.
No. I don't currently know enough about about how this works for iso files to know if this is simple or hard to implement.
I'll add it to the list of things that would be nice to support.
(2015-09-18, 00:17)shaunhoop1981 Wrote: [ -> ]Can I ask if there will be further adjustments to how screen taps are processed
I have had a look through the code and I don't think there is any touchscreen support in kodi apart form in Android/iOS specific code.
I had hoped that this was supported directly from kodi through the linux touch driver, but I don't think it is.
While making a tap cause a click may be simple, that's probably not enough to make kodi usable.
You really need context menu, and back and other controls, which iOS/Android support through two finger gestures and double taps.
It's something I'd like to improve, but it's not high on the priority list.
I'd welcome patches from anyone who'd like to have a go at this.
(2015-09-17, 18:29)polo_joe Wrote: [ -> ]Tried latest build, less artefacts but still there. also tvheadend discontinuity counter slowly increasing.
Can you try this test firmware:
https://dl.dropboxusercontent.com/u/3669...e_main.zip
Remove hvs_priority and report if there's any change in behaviour.
fixup_x.dat and start_x.elf and rename as last time or
fixup.dat and start.elf?
