(2015-10-16, 05:52)Milhouse Wrote: [ -> ] (2015-10-14, 20:13)Milhouse Wrote: [ -> ] (2015-10-14, 18:55)Leopold Wrote: [ -> ]Here's a libnfs crash with debug enabled.
http://sprunge.us/eHYG
Not obviously reproducible unfortunately.
Thanks. I've added your log and @doveman2's log to the open issue #124. @doveman2 if you can obtain a debug-enabled crash log that would be most helpful.
@Leopold/@doveman2: The libnfs developer has commented on issue #124 and is asking for a build of libnfs without compiler optimisations. I've uploaded debug-enabled build #1015x which has libnfs built using -O0 instead of -Os (ie. without optimisation). Could you both provide updated crashlogs with this build? Many thanks.
I've been using #1015x for the past week but have not experienced any crashes yet.
(2015-10-23, 12:21)movie78 Wrote: [ -> ]IMAX DEEP SEA 3D.
Right from the beginning of the movie green pixellation.
Is this a raw BluRay 3D MVC ISO file? Can you post size/md5sum/mediainfo of the file?
(2015-10-22, 23:14)woronczak Wrote: [ -> ]@BubbleBobble
Sorry - I put my response in the wrong area.
That is what happens to me if the GUI is set to 23.976 or 24hz. Try setting the GUI to 50Hz
Thanks but like you I am running GUI at 50hz. Try to play a 3D movie in 2D mode.
(2015-10-23, 13:21)movie78 Wrote: [ -> ]Quote:Format : BDAV
Format/Info : Blu-ray Video
That all looks fine. Can you check if an mkv conversion has the same pixellation?
If so can you produce a two minute sample file and upload to a hosting site (e.g. dropbox/google drive).
(2015-10-23, 12:13)popcornmix Wrote: [ -> ] (2015-10-23, 01:36)movie78 Wrote: [ -> ]Can Play 3D be added to the Video playback default settings?
SETTINGS-->VIDEO-->DISC-->BLU-RAY PLAYBACK MODE---PLAY 3D
Yes, that's something I'd like to do. I'd prefer a global setting to the "play using 3d" currently added to the BluRay playback menu (which isn't available when resuming).
Isn't "play using 3d" just a ugly hack for SSIF (or however it's called) support? I don't think we should add extra logic for this hack. Bluray playback should use the very same 3D settings than any other movie. So the correct approach would be to change the way bluray playback is handled. Create a wrapper function/logic that checks if for the to be played bluray item a SSIF playlist exists, and if so follow the 3D playback settings. If this requires more fundamental changes to how playback is handled, so be it, but if this should ever make it's way into mainline it has to be done properly.
(2015-10-23, 13:45)da-anda Wrote: [ -> ]Isn't "play using 3d" just a ugly hack for SSIF (or however it's called) support? I don't think we should add extra logic for this hack. Bluray playback should use the very same 3D settings than any other movie. So the correct approach would be to change the way bluray playback is handled. Create a wrapper function/logic that checks if for the to be played bluray item a SSIF playlist exists, and if so follow the 3D playback settings. If this requires more fundamental changes to how playback is handled, so be it, but I if this should ever make it's way into mainline it has to be done properly.
Yes, this patch came from Zidoo and I agree it's a hack, but I haven't worked out where the best place to change the filename given to player (form .iso to .ssif). Suggestions are welcome.
I think player should fire off a signal on before playback start/initialization and components observe it to do random manipulation upfront. But better ask FernetMenta.
Wouldn't be easy just to add Play 3D mode in the default Simple Menu Settings,the option is already there.
Just my 2 cents.
(2015-10-23, 13:49)popcornmix Wrote: [ -> ]Yes, this patch came from Zidoo and I agree it's a hack, but I haven't worked out where the best place to change the filename given to player (form .iso to .ssif). Suggestions are welcome.
Aren't we doing the same already for 2D ISOs? .iso -> .m2ts?
(Not implying we do - I ask because I just don't know.)
(2015-10-23, 17:09)menakite Wrote: [ -> ]]
It seems to vary. When you resume an ISO VideoPlayer gets "video.iso" as the filename.
When you start from beginning you get the simple bluray menu (GUIDialogSimpleMenu.cpp) and filename is mangled to start with bluray:// which means libbluray is used to read it. I believe that extracts the .m2ts internal file. The different menu options produce "BDMV/PLAYLIST/00000.mpls" or "BDMV/MovieObject.bdmv" filenames within the iso.
I've made a change to tonight's build. I no longer use the Zidoo scheme, so no "play as 3d" in the BluRay menu.
If "MVC" is enabled in video acceleration settings then it will play the 3d stream. If disabled it will play the 2D stream.
This seems to avoid the problem with resuming in 3d mode not being possible and allows "Play main movie" to be enabled without losing the 3D option.
(2015-10-23, 09:49)Milhouse Wrote: [ -> ]They're not matched, as such - you can update the tvheadend addon whenever you want, and use pretty much any version you like. Although unless you've got a specific reason to use an older tvheadend addon, you should just use the latest tvheadend version when updating the addon.
Now that the OpenELEC FTP server shows the date/time for each file it does tend to make the build reference (ie. #1022) that I'm adding to the filename somewhat redundant, as the main reason for adding it was simply to determine which file is most recent (as it wasn't always obvious).
OK thanks, I'll test the newer versions then, I can always revert back to #1015 if I have any problems.
(2015-10-23, 20:56)popcornmix Wrote: [ -> ] (2015-10-23, 17:09)menakite Wrote: [ -> ]]
This is great, will test as soon as it release.
New OpenELEC Jarvis build #1023:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.1.10 #1 Fri Oct 23 23:57:27 BST 2015 armv6l GNU/Linux
# vcgencmd version
Oct 23 2015 16:28:38
Copyright (c) 2012 Broadcom
version c1a8b643677011791abeea1f5dc3a4738349ea55 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151023235633-#1023-g94f7804 [Build #1023]
# vcdbg log msg 2>&1 | grep DTOK
001738.029: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (94f78041,
changelog) and tip of
XBMC master (9a517d9c,
- Includes newclock5 patches
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.1.y_rebase
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (2a9186e3, ahead +34)
- Includes latest kodi-platform master (45d6ad19, ahead +1)
- Includes latest libcec master (2c675dac, ahead +31)
- Includes latest libnfs master (dc8d8662, ahead +22)
- Includes latest platform master (feafe68e, ahead +4)
- Includes latest addons: adsp.basic (89015163), adsp.biquad.filters (1746fe46, +2), adsp.freesurround (f0c6bf00), asplib (39fe0a71), pvr.argustv (2bf67bb7), pvr.demo (659712a0), pvr.dvblink (4d718970), pvr.dvbviewer (0ca01b1a), pvr.filmon (bea2509b), pvr.hts (a7fa1d65), pvr.iptvsimple (953477b7), pvr.mediaportal.tvserver (0e12d06c), pvr.mythtv (702bda77), pvr.nextpvr (ef36c940), pvr.njoy (cc2c4a69), pvr.pctv (1494bfc1), pvr.stalker (41fb7c42), pvr.vbox (e92c1236), pvr.vdr.vnsi (8e0d73fb), pvr.vuplus (9ff818a4), pvr.wmc (ec514227)
- Exclude [env] kodi-999.51-nonX11-mousewheel-support.patch: Merged upstream
- Exclude [env] kodi-999.52-multitouch-support.patch: Merged upstream
- Exclude [env] kodi-999.99-IMX-increase-render-buffers.patch: Conflict with newclock5/FernetMenta
- Include [env] acb886fb: Intel: Automatically switch to full range
- Include [env] eda74857: Intel: Implement Passthrough-Range
- Include [env] 1c7eef23: Intel: Passthrough Mode - little workaround
- Include [env] 5c84fb29: Mesa: Bump to 11.0.3
- Include [env] 87eaaa2f: Python: update to Python-2.7.10
- Include [env] 92db150e: systemd: update to systemd-227
- Include [env] 340b867c: Kodi: Use Limited Range by default
- Include [env] 55671197: VAAPI: Enable EGL
- Include [env] patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Add experimental splash video
- Include [env] patch: Disable Realtek WiFi Power Save (RTL8192CU/RTL8192DU/RTL8812AU)
- Include [env] PR:4378: RFC: Disable libaacs, causes GUI hangs on some BD ISOs
- Include [env] PR:4384: Kodi 16.0 Jarvis
- Include [pkg] PR:125: Fix for holding buttons on remotes of Philips TVs (libcec)
- Include [pkg] PR:8133: [videodb] Fix TV shows cleaning after 5755573981ca706a82a7ecbbdf5de112a570377a.
- Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
- Include [pkg] PR:8266: Revert to process action without unicode.
- Revert [pkg] linux-999.20-mt7601u-support.patch: Reverted as patching order conflicts with rpi-4.1.y commits - continue using rpi-4.1.y equivalent (linux)
- Revert [pkg] PR:8277: ADD: [droid] surface rendering mediacodec (Reason: Needs newclock5/FernetMenta rebase)
Build Highlights:
- New firmware
- Fix BD 3D resume in 3D
- Drop RapidJSON and revert to YAJL, as RapidJSON now targetting Kodi 17
Build Details:
- Firmware (Oct 23):
- firmware: arm_loader: enable backlight overlay automatically. See: link
- licence: Add Raspberry Pi copyright
- OpenELEC:
- projects/imx6/patches/linux: udoo dt - serial console on ttymxc0 (PR:4392, 1 commit, 2 files changed)
- projects/imx6: add serial console service (PR:4391, 1 commit, 1 file changed)
- buildsys: do poor man's md5deep (PR:4393, 1 commit, 4 files changed)
- Build mkfs.(v)fat from dosfstools for the host (PR:4394, 1 commit, 2 files changed)
- XBMC:
- [guilib] fix hitrect visualization (PR:8272, 1 commit, 2 files changed)
- [videos] fix default select action after #8169 (thanks anaconda) (PR:8273, 1 commit, 1 file changed)
- ADD: [droid] surface rendering mediacodec (PR:8277, 3 commits, 33 files changed)
- [confluence] fix music OSD alignment and improve visible conditions on OSD (PR:7789, 1 commit, 2 files changed)
- [strings] DTS -DTS-HD settings description, include relationship to DCADEC setting. (PR:7984, 1 commit, 1 file changed)
- [Conluence] fix 2D radiobutton state - trac #16335 (PR:8275, 1 commit, 1 file changed)
- adsp.biquad.filters:
- Fix segmentation fault during filter coefficient transfer (PR:5, 2 commits, 8 files changed)
- newclock5:
- New commits in this build:
- switch libuuid implementation to e2fsprogs (f5332b4a)
- crossguid: use libuuid on droid (eacbbdc7)
- Revert "ADD: [demux] ssif patches from rk3368 platform" (7ef89014)
- [ssif] Add missing packet free (6b23cd60)
- [VideoPlayer] Support filename mangling for MVC files (b7d6fcdb)
- Commits no longer in build:
- Merge pull request #311 from lkosmid/EGL_refactoring (a89cfa45)
- hack: Fix build due to missing HAS_EGL (ed993cdd)
- Reverted: [pkg] PR:8277: ADD: [droid] surface rendering mediacodec (Reason: Needs newclock5/FernetMenta rebase)
