An AMLogic S905X is a HDMI 2.0 device which means:
H.265 4K@60fps
H.264 4K@30fps
There is very very little 4K video content encoded as H.264 anyway because its an older inefficient video compression standard that would result in really large video file sizes if it were used these days. 4K UHD Blurays for example all use H.265 aka HEVC.
The H.264 combo for 4K can be considered irrelevant.
Google are using 4K VP9 Profile 2 for 4K Youtube which various AML S905X boxes support with the correct Android Firmware mods.
AVS+ I believe is the HD video standard used in TV Broadcasting in China.
BTW: Geekbuying are cheaper than Gearbest.
I have just ordered this from Geekbuying.
In my NUC i use OpenElec with a BT dongle for my PS3 BT remote, which works brilliantly. I take it it's not as easy as plugging in a BT dongle in this box with LibreElec to make BT work?
(2017-08-22, 19:06)TommyL Wrote: [ -> ]I have just ordered this from Geekbuying.
My Odroid c2 using libreelec works fine with this device:
Bus 001 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
(2017-08-22, 15:49)wrxtasy Wrote: [ -> ]An AMLogic S905X is a HDMI 2.0 device which means:
H.265 4K@60fps
H.264 4K@30fps
Can you please tell me which is better to buy? the mecool m8s pro s905x or the s912 one? Can you also tell me the differences between them?
ty
(2017-08-22, 22:05)nickr Wrote: [ -> ] (2017-08-22, 19:06)TommyL Wrote: [ -> ]I have just ordered this from Geekbuying.
Thanks nickr! So there is hope...I'll look into it when i get my box
(2017-08-22, 22:16)dadaii Wrote: [ -> ]Can you please tell me which is better to buy? the mecool m8s pro s905x or the s912 one? Can you also tell me the differences between them?
ty
(2017-08-21, 15:20)wrxtasy Wrote: [ -> ]Cheap Chinese sourced AMLogic devices:
AML S912 devices running Marshmallow Firmware are the worst devices on the market you can buy. Bugs galore.
However the S912 MM Firmware equipped MINIX U9-H, that has bug busted MM Firmware works well.
AML S912 devices running Nought Firmware have some bug fixes but they cannot run LibreELEC Kodi Krypton properly.
AML S905x device running Marshmallow Firmware are the second worst devices you can buy. Good for LibreELEC tho.
AML S905x Nougat are a tiny bit slower than AML S912 and have no problems running LibreELEC. AML Nougat has bug fixes.
If you do not need Android HDR & VP9 - AML S905 devices are the ones to buy - especially for LibreELEC.
Personally I would not bother with AML S912's. They are one trick pony devices so far as stable working Kodi is concerned. Android only.
S905x = VP9 Profile 2 & HDR10 & 100M only Ethernet
S905 = no VP9 Profile 2 & no HDR10 but Gigabit Ethernet
S912 = VP9 Profile 2, HDR10, Gigabit Ethernet & Dolbyvision (however still needs proper Firmware support for DV first)
Amlogic S905 vs Amlogic S912 Benchmarks Comparison
Amlogic S905 vs AMlogic S905X Benchmarks Comparison
Hi, not sure whether this has been discussed before here not. I cant find any thread related to this , when searching cheaper player for KODI (preferably clean), i came to know about S905W chip, which is very new to market it seems
http://www.geekbuying.com/item/TANIX-TX3...84467.html
Specs seems a bit inferior to S905.
I am tech noob.. can somebody shred more light on this compared to S905/S905X.
Is it rebranded S905X?
TIA
S905W = a S905 minus the Gigabit Ethernet and limited to 4K@30fps only. There is no HDR or VP9 Profile 2 hardware decoding.
Looks pretty useless.
(2017-08-23, 13:47)wrxtasy Wrote: [ -> ]S905W = a S905 minus the Gigabit Ethernet and limited to 4K@30fps only. There is no HDR or VP9 Profile 2 hardware decoding.
Thanks for the info
So technically inferior than S905X also?
M8S Pro+ is still best value for dual boot?
thanks
(2017-08-24, 10:29)saran008 Wrote: [ -> ] (2017-08-23, 13:47)wrxtasy Wrote: [ -> ]S905W = a S905 minus the Gigabit Ethernet and limited to 4K@30fps only. There is no HDR or VP9 Profile 2 hardware decoding.
Thanks for the info
Inferior to both S905 and S905X.
S905 has GigE and 2160p (aka 4K) support up to 60Hz support.
S905X has 2160p support up to 60Hz and HDR and VP9 Profile 2 hardware decode.
You might want to look at a S905D for Gigabit Ethernet + DVB Support and VP9 + HDR 10 (same as a S905X) .
Hi everyone, just registered to this forum. I'd kindly ask if anyone has a Vorke Z1 TV box (android 7.1.1, S912) so as to help me: YouTube and Kodi aren't at 4K and I don't know why. YouTube gives me 1080p option at best, Kodi runs entirely at 1920x1080. Maybe the standard HDMI cable sold in the box with the Vorke isn't capable of 4K? Please help
Please start a new thread and provide a
debug log (wiki)
(2017-08-25, 20:59)spino94 Wrote: [ -> ]Hi everyone, just registered to this forum. I'd kindly ask if anyone has a Vorke Z1 TV box (android 7.1.1, S912) so as to help me: YouTube and Kodi aren't at 4K and I don't know why. YouTube gives me 1080p option at best, Kodi runs entirely at 1920x1080. Maybe the standard HDMI cable sold in the box with the Vorke isn't capable of 4K? Please help
For 4K anything on Android devices the Android Settings > Display > Screen Resolution > needs to be set
First to 4k2k60hz
HDMI 2.0 must of course also be used.
4K Youtube needs proper a Android Firmware build.prop, and I doubt the required mods have been done to a cheap Android Box to allow this.
See the Freaktab Website for bug busted Alternate Firmware.
The Kodi forum cannot help you with Android Firmware issues.
