2014-12-24, 14:17
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
2014-12-27, 01:38
I updated to Kodi Helix and its working fine,no prob so far.
VFD win8.1 64
VFD win8.1 64
2014-12-27, 19:38
great to hear, though i have lcd. also the parsley version?
2014-12-27, 23:47
(2014-12-27, 19:38)ShinobiX9X Wrote: [ -> ]great to hear, though i have lcd. also the parsley version?I'm using parslej version with my imon ultrabay (LCD) and it works with Kodi 14 (not perfectly but it works).
But be aware that it seems to be some bug with the webserver service which may cause some random crashes (and XbmcOnImon needs webserver activated).
2014-12-28, 07:21
2014-12-28, 10:14
(2014-12-27, 23:47)Pretoriano80 Wrote: [ -> ](2014-12-27, 19:38)ShinobiX9X Wrote: [ -> ]great to hear, though i have lcd. also the parsley version?I'm using parslej version with my imon ultrabay (LCD) and it works with Kodi 14 (not perfectly but it works).
Just upgraded, seems to work. no crashes yet.
2014-12-29, 14:47
Hello!
New user of KODI i'm trying to enable VFD of my Imon.
Install XBMX ON IMON and configure KODI.
I've got an error when trying to connect: cannot connect to XBMC at 127.0.0.1:8080.
I've tried to connect by iexplorer without problems, all is working directly by ie, where is the problem?
Why is there a port 8080 and tcp 9090? help needed
Please
Please
2014-12-29, 16:36
(2014-12-29, 14:47)nobru26 Wrote: [ -> ]Hello!You need to enable "webserver" in Settings - Services - Webserver. Also make sure you set the correct port, username and password in XbmcOnImon too.
Please
2015-01-02, 19:14
I used parsleg version and finally woks.
Others problems and questions but i'm having others tests to make a full demand...
Thnaks
Thnaks
2015-01-10, 15:34
Hi!
finally with kodi and parslei - i had success, too.
An update from 12.3 to kodi worked, and display worked immeadi.... BUT running any kind of media brought me a crahs in the next 30 to 60 seconds. So i decided to reinstall, media worked fine, but display had problems.
I noticed: in the advancendsettings xml i had an error, which kodi does not like. XML error.
I needed to deactivate the firewall on the windows system.
I had to rename the device to XBMC (instead of kodi)
password etc. i do not use.
I installed the developerversion (including the libs) of the project (MS Visal C++)
hope this hint helps anybody who still has problems. At the moment i will not investigate further - because i it works and i do not have any kind of crashes
kind regards from bavaria
2015-01-16, 19:21
Has anyone got this working with Kodi 14.0 “Helix”, i had this working great with Gotham but the other week i upgraded by installing Helix over Gotham but had crashes so had to uninstall Kodi and do a fresh install but since then i can't get it to work.
I use Imon-on-xbmc-by-Parslej and set the same settings that there was before the upgrade to Kodi but no go.
2015-01-16, 21:48
(2015-01-16, 19:21)voyagerxp Wrote: [ -> ]Has anyone got this working with Kodi 14.0 “Helix”, i had this working great with Gotham but the other week i upgraded by installing Helix over Gotham but had crashes so had to uninstall Kodi and do a fresh install but since then i can't get it to work.Check Webserver service settings (e.g Username and Password) in Kodi and make sure you are using the same settings in XbmcOnImon.
2015-01-16, 22:25
I've checked, can you see where i'm going wrong?
Quote:XbmcOniMon.exe Information: 0 : 01/16/2015 20:11:51 [GUI] Asynchronous starting to connect with XBMC[/quote]
XbmcOniMon.exe Information: 0 : 01/16/2015 20:11:51 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:11:52 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:11:57 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:11:57 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:11:57 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:11:57 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:11:57 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:11:58 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:03 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:03 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:03 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:03 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:03 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:04 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:09 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:09 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:09 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:09 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:09 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:10 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:12 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:12 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:12 [GUI] Settings saved
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:12 [GUI] Setting up XBMC connection to 127.0.0.1:80
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:12 [GUI] Auto-connecting to XBMC at startup
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:12 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:12 [XBMC Handler] Update
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:12 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:13 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:15 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:15 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:15 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:15 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:15 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:16 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:21 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:21 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:21 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:21 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:21 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:22 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:22 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:22 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:22 [GUI] Settings saved
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:22 [GUI] Setting up XBMC connection to 127.0.0.1:80
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:22 [GUI] Auto-connecting to XBMC at startup
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:22 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:22 [XBMC Handler] Update
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:22 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:23 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:27 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:27 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:27 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:27 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:27 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:28 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:33 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:33 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:33 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:33 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:33 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:34 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:39 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:39 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:39 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:39 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:39 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:40 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:45 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:45 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:45 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:45 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:45 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:46 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:51 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:51 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:51 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:51 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:51 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:52 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:57 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:57 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:57 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:57 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:57 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:12:58 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:03 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:03 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:03 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:03 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:03 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:04 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:09 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:09 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:09 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:09 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:09 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:10 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:15 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:15 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:15 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:15 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:15 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:16 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:17 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:17 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:17 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:17 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:18 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:21 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:21 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:21 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:21 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:21 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:22 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:27 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:27 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:27 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:27 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:27 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:28 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:33 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:33 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:33 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:33 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:33 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:34 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:39 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:39 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:39 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:39 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:39 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:40 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:45 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:45 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:45 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:45 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:45 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:46 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:51 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:51 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:51 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:51 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:51 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:52 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:57 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:57 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:57 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:57 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:57 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:13:58 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:03 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:03 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:03 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:03 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:03 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:04 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:09 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:09 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:09 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:09 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:09 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:10 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:15 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:15 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:15 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:15 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:15 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:16 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:21 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:21 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:21 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:21 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:21 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/16/2015 20:14:22 [GUI] Connection with XBMC failed[/php]
2015-01-17, 11:27
Your Username is empty in XbmcOnImon - - > XBMC configuration
2015-01-17, 14:05
(2015-01-17, 11:27)Pretoriano80 Wrote: [ -> ]Your Username is empty in XbmcOnImon - - > XBMC configuration
Ha ha it still does it with xbmc or kodi in the username.
Quote:XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:30 [GUI] Application path: D:\Imon-on-xbmc-by-Parslej
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:31 [GUI] Current version of XbmcOniMon: 0.1.9.5
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:31 [GUI] Settings successfully applied to the GUI
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:31 [GUI] Setting up iMON
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:31 [GUI] Setting up XBMC connection to 127.0.0.1:8080
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:31 [GUI] Auto-connecting to XBMC at startup
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:31 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:31 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:31 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:31 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:31 [GUI] Minimizing application to tray at startup
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:32 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:37 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:37 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:37 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:37 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:37 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:38 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:43 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:43 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:43 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:43 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:43 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:44 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:44 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:44 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:44 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:44 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:45 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:47 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:47 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:47 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:47 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:48 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:49 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:49 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:49 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:49 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:49 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:50 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:55 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:55 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:55 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:55 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:55 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:52:56 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:01 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:01 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:01 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:01 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:01 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:02 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:07 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:07 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:07 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:07 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:07 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:08 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:13 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:13 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:13 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:13 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:13 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:14 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:19 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:19 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:19 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:19 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:19 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:20 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:25 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:25 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:25 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:25 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:25 [XBMC] Opening a connection to XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:26 [GUI] Connection with XBMC failed
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:31 [GUI] Trying to auto-connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:31 [XBMC] XbmcJsonRpcConnection.IsAlive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:31 [XBMC] Result: Not alive
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:31 [GUI] Asynchronous starting to connect with XBMC
XbmcOniMon.exe Information: 0 : 01/17/2015 11:53:31 [XBMC] Opening a connection to XBMC
