(2012-08-22, 16:32)JBarr Wrote: [ -> ]Anyway to view the radar map instead of the satellite? Toggling between them would also be a great option.
radar images are nice indeed, but they are only available for US locations.
that's the one and only reason the script does not support them.
(2012-07-24, 12:03)ronie Wrote: [ -> ]there's a few things i need to double-check before i can push this one to the repo.
A gently bump for this
P.S. Since i made it for testing purposes
here is the mod for preFrodo Confluence, based on pkscuot's mod.
Cheers
Nessus
(2012-08-31, 18:40)vijayk416 Wrote: [ -> ]is there a way to input the location of a specific weather station via the advanced options? I'm trying to find a way to use this one:
http://www.wunderground.com/weatherstati...&year=2012
yes you can :-)
in advanced settings, choose whatever display name you'd like to use for the location
and in the location id field, enter
pws:IONTARIO418
i'll add some more documentation on this when it's released, but for the time being here's a short list of available id codes (and their meaning):
CA/San_Francisco - US state/city
60290 - US zipcode
Australia/Sydney - country/city
37.8,-122.4 - latitude,longitude
KJFK - airport code
pws:KCASANFR70 - Personal Weather Station id
autoip - AutoIP address location
autoip.json?geo_ip=38.102.136.138 - specific IP address location
Did I mention lately that you rock? Cause you really do.
(2012-08-23, 23:30)ronie Wrote: [ -> ] (2012-08-22, 16:32)JBarr Wrote: [ -> ]Anyway to view the radar map instead of the satellite? Toggling between them would also be a great option.
Are you interested in adding code for other regions is supplied? E.g. I have working radar code for Aus data in my OzWeather addon. I'd be happy to help integrate or whatever...but given the source in not WU, I guess it's not really in the plan for this add on?
Is there a repo of the WU code about? I based my weather addon off yours a long time ago, am wondering if I can merge my work with the WU work for an add on that offers a bit more...
(2012-09-04, 04:58)bossanova808 Wrote: [ -> ]Are you interested in adding code for other regions is supplied? E.g. I have working radar code for Aus data in my OzWeather addon. I'd be happy to help integrate or whatever...but given the source in not WU, I guess it's not really in the plan for this add on?
that's indeed correct, the wunderground addon will only use weather underground sources.
(2012-09-04, 04:58)bossanova808 Wrote: [ -> ]Is there a repo of the WU code about? I based my weather addon off yours a long time ago, am wondering if I can merge my work with the WU work for an add on that offers a bit more...
there's a repo here:
https://code.google.com/p/ronie/source/b...nderground
but please don't merge any of my code!
why? you don't have to:
you can use the wunderground addon as a script module, it allows other addons to fetch wunderground info through it.
see /weather.wunderground/resources/lib/wunderground/wunderground.py
send me a PM and we'll work something out ;-)
ok well a module is even better of course....great!
Let me have a poke around and get back to you...not really sure what the Wunderground offers, have been concentrating on local weather stuff, but my father in law has a PWS and I might try hooking that up to Wunderground and then seeing what cool stuff I can pull in while maintaining the offical local radar stuff I currently have....I would like satellite etc, if possible...
(2012-07-21, 02:09)phil65 Wrote: [ -> ]very nice addon
thx, tried to make use of it as much as possible.
Hi guys im having trouble getting this to work properly
I would like my screen to look like the one above but it currently looks like this
Can anyone help me out?
(2012-09-09, 15:22)boppyman Wrote: [ -> ]Can anyone help me out?
best ask for help in the subforum of the skin you're using.
Oh sorry i didn't know it was a skin problem, i'm using Aeon MQ3
Should it look like the first pic i posted or is some tweaking involved to get it to look like that?
Any idea why the humidity for my area (US zip: 21613) always shows up as 999%? Is that a skin issue?
(2012-09-11, 03:49)GrendelJapan Wrote: [ -> ]Any idea why the humidity for my area (US zip: 21613) always shows up as 999%? Is that a skin issue?
nope, script issue. i'll fix that.
cheers for reporting it. :-)
