Is this addons incompatible with Kodi 18? Because I get error when I try to install it.
Sent from my iPhone
(2016-12-20, 14:40)superZ Wrote: [ -> ]I had one question: I have set the location id for Location 1 in Advanced Options to "autoip".This works great for fetching the weather based on IP the first time round, but after that the resolved location id appears to be written to the settings,
i can't reproduce it...
if you go back to settings > advanced, does it still say 'autoip' ?
(2016-12-20, 15:15)ronie Wrote: [ -> ] (2016-12-20, 14:40)superZ Wrote: [ -> ]I had one question: I have set the location id for Location 1 in Advanced Options to "autoip".This works great for fetching the weather based on IP the first time round, but after that the resolved location id appears to be written to the settings,
Thanks for looking.
When I go back to Advanced Options (having prior defaulted the settings and then setting location 1's ID to "autoip) it instead gives the co-ordinates of the IP location(i.e. zmw:xxxxx.yyy.zzzzz) for the location ID, and the retrieved display name for the location is now populated.
Obviously should not behave like that. I uninstalled and reinstalled the aaddon also. I will keep an eye on it.
I just replaced YahooWeather with WeatherUnderground and LOVE it. The only problem is I have it configured on 5 devices, and I've exceeded the limit for 500 API calls a day.
Is there a way to change the interval it updates so I don't exceed my API call limit?
nope, the interval is hardcoded in kodi and can't by controlled by the addon.
that will happen when the addon fails to download the weather forecast.
a
Debug Log might provide some info why it fails.
see first the post on how create a
Debug Log for this addon
Hi
I have a issue with this app running on an RPi3 with Kodi 16.1 "Jarvis" installed.
The problem has not much to do with this, it is that the place where to post a log,
http://xbmclogs.com/
tells me upon opening
"Whoops, looks like something went wrong."
Is there an alternative site where to post?
Thanks in advance for your reply.
ronie Thanks for the link.
@all:
A log file is on
http://paste.ubuntu.com/23886733/
Screen shots - as well as log file - are in
https://www.dropbox.com/sh/vy7j58ipyhnhv...gVRQa?dl=0
The problem is as follows. Every half an hour WU refreshes. For about one second it shows the first screenshot with new data, temperature in full accuracy but with former time stamp. Then, the image refreshes as shown in the second screenshot where the temperature is truncated and the new time stamp.
Clearly, what I think should happen is that with the new time stamp also the temperature is shown in full accuracy.
Thanks for the help,
Ger
Thanks again, Ronie
If I understand it well, a bug has been opened by you as
"Merge pull request #9577 from ronie/temperature".
and
"proper rounding of temperature values - fixes trac #16671"
I do not immediately see an option to support it.
Any chance that I can fix this myself on my RPi? I do have some experience, albeit not with Kodi.
Ger
the easiest thing would be to wait for a new openelec release that includes kodi 17.
if you're adventurous, you could try one of their testbuilds.
They just released the latest version with still kodi 16. There seem not to be testbuilds for kodi 17 as yet.
