hi Ronie, btw I relly like weather underground ftw;
I used the version weather underground 3.0.9 for my isengard kodi, how can the map can be viewed? is it disabled? Thanks for this addon.
How do you switch cities? Running MQ7 on Jarvis
(2016-11-09, 04:00)rocko Wrote: [ -> ]How do you switch cities? Running MQ7 on Jarvis
that's a skin thing. you'd need to ask in the mq7 support thread.
I don't know if I am in the right thread, but does anyone know where / how I can change the color of the max temp from red to yellow?
maybe it is something as simple as changing a value in one of the xml files. Any help would be appreciated
you'd need to make those changes in the skin you're using.
(2016-11-13, 15:20)ronie Wrote: [ -> ]you'd need to make those changes in the skin you're using.
Thanks, I found it. I had to change it in 4 places
Is the plugin server down?
Sent from my iPhone
Bug ?
If it is Hazy at Night, the Plugin guides to WeatherFanart 21 (Haze)
there would be 33 (Hazy/Night) witch would fit just right imho.
I did change line 116 in Utilitys.py from 21 to 33, and for me it seeems right.
maybe this change would make sense, not shure if this is the way to go, but for now (cant say how it acts on a Day) it seems O.K..
Regards.
(2016-11-23, 23:54)ronie Wrote: [ -> ]there are no separate night/day icons for haze.
21 is correct for both day and night.
33 is used for the 'fair' condition at night.
see: https://developer.yahoo.com/weather/docu...html#codes
Strange
So, is it right that all is referenced to the Yahoo condition Numbers?
Guess got Just to old Infos then. Here is what i found, and what i use as Information
Link (Post 3)
Quote:32 Clear/Day
33 Hazy/Night
34 Hazy/Day (In Weather Fanart Pack: same as 21)
35 Same as 00 (In Weather Fanart Pack: same as 00)
I did already touth not all is correct there, and touth i ask as soon i finde time. (Not quite shure, but guess Dr.Toxics Weatherfanartpack uses "Haze Night" in 33 to..
By the Way
Did touth i mention this in case it is of any Help:
Not shure if u remember, but i had a while ago some problems with the "Radar Map", some Weeks ago, i again play around with the Mapzoom settings, and found a zoomlevel which loads the Map right (No Black BG) in my case with "Zoomlevel 4" the "Radar Map" works just right.
Regards.
Hi Ronie, I have a problem with the weather stating Unknown could you help me?
(2016-11-24, 01:18)Rantanplan-1 Wrote: [ -> ]i again play around with the Mapzoom settings, and found a zoomlevel which loads the Map right (No Black BG) in my case with "Zoomlevel 4" the "Radar Map" works just right.
wish i could say the same... at level 4 i still get a black background
(2016-11-24, 19:35)Ices Wrote: [ -> ]Hi Ronie, I have a problem with the weather stating Unknown could you help me?
sure, i can recommend you to always read the first post before you ask for help ;-)
