(2016-06-16, 13:38)iMak Wrote: [ -> ]I have a small issue, as you can see from the screenshots, I get readings in all options, except for the 36 Hours screen.
Any hint to solve the issue?
The problem is an error in your skin Aeon MQ6 Spin-Jarvis. The skin is looking for weather underground add-on to set properties 36Hour.1.HighTemperature, 36Hour.1.LowTemperature etc but these properties don't exist. This skin should only show 36Hour.1.Temperature etc (IOW, only one temp for each time period, showing High, Low, High). Contact skin mod author for assistance to make necessary changes to the IncludesWeather.xml file. The file "README.txt" in the add-on's install folder provides the necessary details on properties set by the add-on.
scott s.
Thank you Scott
Sent from my iPhone6s+
I downloaded the addon and installed it. I set the API and my location but for the life of me I cannot find where to enable it in Krypton. There is nowhere in the interface tab or anywhere else that I can find.
How do I enable the WUG addon in this version of Kodi?
RR
Go to My Add-ons, select the add-on from the list, and press it, then hit Use button.
settings > service settings > weather
Ah thanks. I knew it was tucked in somewhere but couldn't find it. I even looked in the service settings but I guess it was with my eyes closed.
Hey there!
I was wondering, is it possible to add personal weather stations to this addon?
I've tried adding the locationg the PWS site says I am in, but it doesn't show the same conditions.
I've also tried adding the ID of the PWS, but the addon is thowing an error. (see url for kodi log)
http://pastebin.com/54RnkV2A
A link to my PWS for reference is here:
https://www.wunderground.com/personal-we...ISKNELNS47
Thanks for any help!
-fuzzynor
Did you try to search this thread?
Do the answers following this post on page 39 help you:
http://forum.kodi.tv/showthread.php?tid=...pid2293256 ?
(2016-03-27, 16:46)jmh2002 Wrote: [ -> ]Did you enter pws:KCABAYWO10 ? (including the pws: ) because I just tried it and it works for me and shows 10 degC (50 something degF), the same as here: https://www.wunderground.com/personal-we...10#history
If you miss the pws: part then it doesn't work.
So for you, entering pws:ISKNELNS47 should work
It works for me and I see the same 17 degrees and WSW wind at 8km/h like on the web link you posted for Felestad PWS in Svalöv Kommune, Sweden.
Hope this helps
(2016-07-10, 11:59)jmh2002 Wrote: [ -> ]Did you try to search this thread?
Do the answers following this post on page 39 help you: http://forum.kodi.tv/showthread.php?tid=...pid2293256 ?
Hope this helps
Ah, yes. Forgive my ignorance. it seems that I did not thoroughly enough search for it.
But yes, I can confirm it working now. Much appreciated!
Over the years I have tried several times to use WU, since it got great reviews, but I always gave up due to their ornate and often confusing requirements (now an API key is required). I tried recently again, with kodi 16.1 using Aeon-Nox, but failed again-- it "runs", but shows all the temperatures to be 0 everywhere.
Yahoo weather here I come again...
This must be user error, I have been using WU for years, across multiple different devices, OS, and versions of Kodi, both before and after the API requirement, all with minimum issues.
With the limited info provided I can perhaps only mention that recent posts where users have had a zero temperature being displayed seemed to have been related to incorrect location information being entered in Kodi.
Also, to double check that it is not a skin issue, switch to Confluence and make a test.
I'm getting emails from weather underground that my 4 boxes are using too many API calls per day. How can I adjust the frequency of the calls to weather underground?
you can't. it's controlled by kodi, not the addon itself.
Thanks,
Information worked great.. got it up and running.
(2016-07-29, 09:01)ronie Wrote: [ -> ]you can't. it's controlled by kodi, not the addon itself.
Well that's unfortunate. No XML setting anywhere I could change?
Would rather not want to manage two different accounts just for API calls.
