I am on Jarvis 16.1
Windows 10
Weather Underworld 5.0.2
Using Transparency
This is on two Windows 10 machines. All Icons have disappeared.
Log is forthcoming.
The log you provided shows a plethora of
banned add-ons (wiki).
As such, no help can be provided on this site per
forum rules (wiki).
(2016-05-12, 01:09)RavRob Wrote: [ -> ]I am on Jarvis 16.1
Windows 10
Using Transparency
Log is forthcoming.
you're missing the animated weather icons addon:
Quote:19:55:52 T:4688 ERROR: XFILE::CDirectory::GetDirectory - Error getting resource://resource.images.weathericons.animated/
it should've been auto-installed when you installed the transparency skin...
you can download it (and install from zip) here:
resource.images.weathericons.animated-0.0.6.zip
Thanks a ton Ronie. It's weird that I lost it on both machines. I know it was there at some point. Maybe some glitch happened when I updated Kodi to 16.1 from 16.0. I never really took note of when I lost it. Thanks for the link. I will give it a whirl tonight.
(2016-05-12, 08:48)ronie Wrote: [ -> ] (2016-05-12, 01:09)RavRob Wrote: [ -> ]I am on Jarvis 16.1
Windows 10
Using Transparency
Log is forthcoming.
That worked perfectly. Thanks a ton.
I was able to install Weather Underground on Jarvis Confluence on my computer but on Aeon mq6 on my Minix the zip says dependencies not met and won't install.
I tried changing the skin to confluence on Minix and install but still wouldn't work.
Any way to get it to work on Aeon MQ6 on Minix.
None of the other weather addons work rite.
Ok, I successfully installed it on the latest SPMC, entered the free API key and my location, but with no data!
I'm on Aeon MQ6 and Nvidia Shield.
Can somebody help?
Sent from my iPhone6s+
(2016-03-27, 10:38)jmh2002 Wrote: [ -> ]In the advanced settings of the Weather Underground addon I have always put the 4 digit codes for the exact station and this has always worked (for years).
If you go to https://www.wunderground.com, find your station, and then click 'Change Station' you will see this code.
Here you will also see a list of stations nearby including Personal Weather Stations from private people.
The Personal Weather Station codes are in a different format but work in the same way. I tested this morning with a couple close to me:
Nice Airport: LFMN
Rue Sa da: pws:INICE161
Everything works as it should. In the display name you can enter whatever you want to personalise the name that appears in Kodi.
Oh, autoip works too if you are travelling (but you are at the mercy of wherever the network ip address is of course).
Is this what you were looking for? Hope this helps
I followed the above and everything seems working flawlessly.
Awesome. If I have helped you or increased your knowledge please click the 'Thank User' button to show your appreciation
jmh2002
I was on Tapatalk that's why there was no Thank You button. I did it on the PC, thanks mate.
Happy that you got it all working
What Kodi version and skin version (specific numbers) are you using?
scott s.
Hello Ronie
Noticed since a while that there is no underlaying map if "Radar" is selected as "map" (there is only a black Background underneath the Radar "data"). Also tested with Confluence.
Is this how it is supposed to be?
