Full Version: Weather Underground
(2013-03-19, 01:16)iStranger Wrote: [ -> ]Weather doesn't work for me because I can't change or add location in weather settings. I have tried pushing all the keys of my keyboard when in location settings but XBMC just doen't let me do anything. I have location 1, location 2 and location 3 all empty.
What I need to do to make it work? I have Mac OS X Mountain Lion, and latest stable version of XBMC v12 Frodo and Wunderground app is also updated. I tried the other weather add-ons too but they didn't work either.
since we have to start somewhere.. i'll start with the most obvious question:
did you click on location 1 before you started typing?
if not, please do. a keyboard dialog will pop up and you can start typing there.
(2013-03-19, 01:27)ronie Wrote: [ -> ]
I have click it several times but I don't get any pop up.
(2013-03-19, 19:48)iStranger Wrote: [ -> ]I have click it several times but I don't get any pop up.
k, i'll need a Debug Log then. if you could follow these steps:
1. enable debuglogging in xbmc. (settings > system > debugging)
2. enable logging in the weather addon (settings > weather > - settings > advanced options)
3. restart xbmc and wait a minute
5. go to weather settings and click onthe 'location 1' setting
4. upload the contents of your xbmc.log file to xbmclogs.com and post the url here
(2013-03-19, 21:26)ronie Wrote: [ -> ]
k, i'll need a debug log then. if you could follow these steps:
I hope I succeeded
http://xbmclogs.com/show.php?id=5544
BTW, I have needed to force quit XBMC every time I have tried to quit it during last two or three days. This time was no exception.
(2013-03-19, 22:05)iStranger Wrote: [ -> ]I hope I succeeded
thanx for the log!
the weather addon doesn't seem to be running at all...
could you temporary rename this folder /Users/Eetu/Library/Application Support/XBMC/addons/
restart xbmc and try again?
this will start xbmc with confluence and without any other additional addons,
just to rule out one if your installed addons is causing issues.
(2013-03-19, 22:53)ronie Wrote: [ -> ]
thanx for the log!
I did it, started XBMC and boom - weather app was back and working perfectly Smile
So this is means one of my add-ons is causing this, right? Can you see from the log file which one or do I need to check them one by one?
(2013-03-20, 19:41)iStranger Wrote: [ -> ]I did it, started XBMC and boom - weather app was back and working perfectly Smile
first thing i would do is upgrade to frodo 12.1
we had a bug in one of the rc builds that caused issues like this.
if upgrading doesn't work, please report back.
most likely candidate for your issue: script.randomandlastitems
(2013-03-20, 19:58)ronie Wrote: [ -> ]
I didn't even know 12.1 was out yet Big Grin Anyways, downloading it seems to have fixed the problem with weather and also problem with not quitting properly. Thank you for your help Smile
latest test version:
weather.wunderground-1.0.11.zip
changelog:
v1.0.11
- fix corrupted alert message
v1.0.10
- fix potential crash on invalid json response
- fix api error response check
- added gzip compression support
weather.wunderground-1.0.13.zip
changelog:
v1.0.13
- added localtime and localdate infolabels
v1.0.12
- added yyyy-mm-dd format for regions that use this format
- fixed strip returns in rss infolabel
Hi, is there anyway to completely disable this weather plugin?
I've looked around and can't find the answer..
The disable and uninstall option in Addon are greyed out...
I'm trying to build very light xbmc for a low spec hardware...
thanks
(2013-05-04, 06:13)denywinarto Wrote: [ -> ]Hi, is there anyway to completely disable this weather plugin?
thanks
sure: settings > weather > service for weather information > none
(2013-05-04, 11:26)ronie Wrote: [ -> ]
thanks
Thanks ronnie why didn't i see that before..
I've been coding up a weather screen and can't get Window(Weather).Property(Current.OutlookIcon) to return anything for a number of different locations.
Also, why do the DAY values start from 0 while the DAILY values start from 1?
It makes using them very confusing!
(2013-05-04, 16:50)Hitcher Wrote: [ -> ]I've been coding up a weather screen and can't get Window(Weather).Property(Current.OutlookIcon) to return anything for a number of different locations.
yes, this is very confusing.. and i'm not 100% sure myself what exactly happens.
the addon *does* provide the Current.OutlookIcon property, but XBMC seems to read it, clear it
and then provide it as Current.ConditionIcon to the skin.
so use the latter and it should work.
(2013-05-04, 16:50)Hitcher Wrote: [ -> ]Also, why do the DAY values start from 0 while the DAILY values start from 1?
simple answer: no idea Smile
this is how the weather.com plus addon did it, and i just used that so users
could easily switch between the two addons without the need for skin changes.
