Firstly: thanks for the great skin, braz!
I've got some questions though.
I'm using Kodi Isengard on Win7, and the repo install of mimic,
I'm trying to arrange the home screen items to my liking.
1) Going into Skin Settings > Setup the main menu > Select Item > Edit Label. The on-screen keyboard appears, immediately followed by a dialog box stating:
"Add-on Required. To use this feature you must download an add-on: ExtendedInfo Script". I select "No" and I can access the OnScreen Keyboard as normal.
I have the "Enable keyboard auto complete" option disabled, as I didn't want it. So I thought that that box shouldn't appear then. Is there any other option relating to the onscreen keyboard that causes that box to show up?
2) I've changed the order of the home screen items around, and then used the "Export Script Settings" feature to copy the same settings to another PC running Kodi. Looking at the exported settings file, I noticed that the labels didn't match the settings options.
Example:
["string", "skin.mimic.MusicHomeItem.Label", "MOVIES"],
["string", "skin.mimic.MusicHomeItem.MultiFanart", ""],
["string", "skin.mimic.MusicHomeItem.Icon", "DefaultMovies.png"],
["string", "skin.mimic.MusicHomeItem.Path", "ActivateWindow(Videos,MovieTitles,return)"],
["string", "skin.mimic.MusicHomeItem.BGType", ""],
["string", "skin.mimic.MusicHomeItem.Widget", ""],
["string", "skin.mimic.MusicHomeItem.WidgetLabel", ""],
["string", "skin.mimic.MusicHomeItem.WidgetType", ""],
["string", "skin.mimic.MusicHomeItem.InfoLine", ""],
["string", "skin.mimic.MusicHomeItem.SubMenu", "x10"],
(line breaks added to code to make it easier to read on the forum)
I'd swapped the positions of the MOVIES and MUSIC labels around in this case. Are the skin.mimic.* items hardcoded to the position of the menu?
~Jondar
