D-m-x
1) The blue text is the tagline and the rest is the plot outline iirc. Not sure if there's anything I can do about the translations.
2) Not currently possible and most likely won't add multiple widgets for each menu item.
braz
Thank you for your help. Alright, at least I know why it is that way. Nothing I can't live with
Why doesn't this skin work with Extended Info Mod? It always loads the same movie when I wanna see any info for a movie.
Titan skin works fine, so it must be something 'wrong' in this one.
(2016-01-09, 16:40)brunodragic Wrote: [ -> ]Why doesn't this skin work with Extended Info Mod? It always loads the same movie when I wanna see any info for a movie.
First of all I'm not sure what you mean by "Extended Info Mod" as Extended Info is supported by the skin, there is no need for any mods.
I just did a fresh install of Kodi 15.2 and Mimic from the repo. Extended Info is working fine here and not showing info for a single movie every time. By your logic the problem 'must' be with your system. We won't know for sure until you upload a debug log.
http://kodi.wiki/view/Log_file
I made a custom build
Installed the extendedinfo script, and everytime I wanna see info on, lets say, The Martian, it opens the info for Hunger games.
Weird.
Here's the log
http://xbmclogs.com/pem39rba0#line-7
MOD edit to remove reference to banned addon
(2016-01-09, 18:32)brunodragic Wrote: [ -> ]I made a custom build, using mostly XXXXX as my main addon.
Weird.
Here's the log
You posted in the Mimic 2.x for Kodi Isengard thread. Yet your log shows you are running Kodi 16 Jarvis. You've got Extended Info script errors in your log, it doesn't appear to be a skin issue.
Also, please see the forum rules regarding banned addons. I've removed the reference to banned addons in your post and recommend that you try Mimic again from a fresh install of Kodi that you download from kodi.tv/download.
http://kodi.wiki/view/Official:Forum_rul...ed_add-ons
(2016-01-09, 19:09)brunodragic Wrote: [ -> ]Here is a new log; i installed Isengard, same story. http://xbmclogs.com/pu0glyvph#line-22
I don't see anything related to Extended Info in that log, did you try to show info on a couple of movies before uploading the log file? If you're having problems related to your local media, I can try to help. If it's still just streaming sources, I'm afraid you won't find much support here.
I did, it always opens the same movie info, no matter what movie i pick.
Anyone Can help me out im trying to set up custom widgets fromy favorites but when I go to custom widgets and click the favorite I want to add in the path the field still empty nothing happens..Im on kodi 15.2 anyone could help would appreciate it.
I'm using Kodi on Apple TV. Mostly I watch IPTV and I'm using this skin because it is one of the most beautiful and simplest skins out there for Kodi. At this case a big thank you to the developer (@braz).
My problem:
It is impossible to minimize the channel I'm watching so I can get back to the main channel list. Neither in 3.2.0 nor in 2.3.0. In "Confluens" there is an "x" to get there or by tapping the screen on the remote. When I tap on the screen in "Mimic" it opens automatically the guide window. There is no way to minimize what I'm watching and get back to the main channel list without breaking or stop watching the current channel.
I would really appreciate it if you (@braz) could fix this in the next version.
Has anyone found this skin to run a bit slow on the Rpi2? Is this a config error or simply down to the fact the Rpi2 is now pretty slow compared to some modern devices?
It is definitely the rp2 I think cause I use mimic with a nuc and a rp2 and the performance on a nuc is much better
(2016-02-01, 23:10)ugotit Wrote: [ -> ]It is definitely the rp2 I think cause I use mimic with a nuc and a rp2 and the performance on a nuc is much better
I see, not a huge deal for me. Still works well, just a bit laggy that's all.
Hi braz,
I have a problem with when palying TV Episodes and I don´t now if this happens since the new update for openelec 6.0.1 or before.
When I try to play more than one episode normaly a window pops up if I want to watch the next episode sometimes it works but most of the time not at the moment and sometimes after the episode comes to the end so it can flip to the next one it stops and throws me back into the main menü like it would be trying to restart the hole system.
I put the kodi log here so maybe you can check it out why this happens because before everything works perfect
Kodi Log
