Can anyone explain to me what is the differences between the branches pvr-testing and unified-pvr ?
Btw, I really love the movies posted in this thread, looks awesome.
The Trac ticket points to the changelog of pvr-testing -> pvr-testing2. The difference between unified-pvr and pvr-testing is that the unified-pvr branch is the first to support the new addon architecture, whereas pvr-testing's goal is to have a working TV frontend.
However, given pvr-testing's progress, I assume that is what's going to make it into the trunk since it uses the addon architecture as well.
freezy Wrote:The Trac ticket points to the changelog of pvr-testing -> pvr-testing2. The difference between unified-pvr and pvr-testing is that the unified-pvr branch is the first to support the new addon architecture, whereas pvr-testing's goal is to have a working TV frontend.
When I prefer to be most up-to-date (i.e. confluence skin updates) with my xbmc pvr setup, what branche can I use best?
Because of encrypted channels (canaldigitaal NL) I really need to use a camserver/client setup to watch TV. Currently I use cccam, server is a dreambox 7020 with cccam, and I've installed cccam as client on ubuntu.
I now use:
deb
http://ppa.launchpad.net/henningpingel/xbmc/ubuntu karmic main
deb-src
Thnx!
could any one set it up and make iso file for download
with working xbmc pvr to watch tv from dreambox cccam serwer
if any one would help would be wow couse i love xbmc its awsome but dont know much about linux if any one
plz pm me ( i have very very good ccam serwer dm800 )
best regards
irol Wrote:could any one set it up and make iso file for download
with working xbmc pvr to watch tv from dreambox cccam serwer ?
best regards
this is not an option in my opinion, better take a look at a liveCD for mythtv
http://www.mythdora.com/?q=download
or liveCD for XBMC
http://xbmc.org/download/
firstly excellent guide, easy to install
and working on Ubuntu 9.10 64bit.
The only problem im having is lack of channels, using a HVR-1200 im only get 12 from freeview.
On the hvr-1200 wiki they mention scanning with and offset of +166Hz +167hz, but can't seem to figure out how todo this.
If I do a scan with Kaffine set to all frequencies then it works fine and it finds everything, but you can't export easily from it?
Any suggestions?
Gorlist Wrote:firstly excellent guide, easy to install and working on Ubuntu 9.10 64bit.
Any suggestions?
Where are you located?
what software are you using to scan?
Southwest UK (Caradon Hill), and ive tried dvbscan and wscan with various settings, no luck
Its just a shame you can't export over from Kaffine.
Gorlist Wrote:Southwest UK (Caradon Hill), and ive tried dvbscan and wscan with various settings, no luck
Strange! Could you try these:
w_scan -ft -c GB -o7 >> channels.conf
scan -o vdr -u /usr/share/dvb/dvb-t/uk-CaradonHill > channels.conf
you should get good results from one of them. I haven't used Kaffine however if the above don't work i will have a look to see if i can help you any further.
you may need to install dvb-apps for scan to work:
sudo apt-get install dvb-apps
thank you for the help
Done as suggest below with no improvement.
scan brings back a total of 12 channels/radio stations, however with w-scan nothing at all.
I was wondering whether I could manually edit the uk-CaradonHill to include +166 and +167hz frequency.
Gorlist Wrote:thank you for the help
There is no harm in trying to edit the dvb-apps file.
Do you have good signal?
yes good signal, everything seems to check out fine. In Windows MCE I have no problems scanning, and Linux/Kaffine again no problems when its set to all frequencies within the program
okay after adjusting my Caradonhill file im now getting 62 services! im still missing a good few including the BBC, but progress none the less. Unsure what todo next to try and improve the number of channels.
# UK, Caradon Hill
# Auto-generated from http://www.dtg.org.uk/retailer/dtt_channels.html
# and http://www.ofcom.org.uk/static/reception_advice/index.asp.html
# T freq bw fec_hi fec_lo mod transmission-mode guard-interval hierarchy
T 578000000 8MHz 3/4 NONE QAM16 2k 1/32 NONE
T 553833000 8MHz 2/3 NONE QAM64 2k 1/32 NONE
T 690000000 8MHz 2/3 NONE QAM64 2k 1/32 NONE
T 474000000 8MHz 3/4 NONE QAM16 2k 1/32 NONE
T 497833000 8MHz 3/4 NONE QAM16 2k 1/32 NONE
T 522000000 8MHz 3/4 NONE QAM16 2k 1/32 NONE
T 578167000 8MHz 3/4 NONE QAM16 2k 1/32 NONE
T 554000000 8MHz 2/3 NONE QAM64 2k 1/32 NONE
T 690167000 8MHz 2/3 NONE QAM64 2k 1/32 NONE
T 474167000 8MHz 3/4 NONE QAM16 2k 1/32 NONE
T 498000000 8MHz 3/4 NONE QAM16 2k 1/32 NONE
T 522167000 8MHz 3/4 NONE QAM16 2k 1/32 NONE
T 578166000 8MHz 3/4 NONE QAM16 2k 1/32 NONE
T 553999000 8MHz 2/3 NONE QAM64 2k 1/32 NONE
T 690166000 8MHz 2/3 NONE QAM64 2k 1/32 NONE
T 474166000 8MHz 3/4 NONE QAM16 2k 1/32 NONE
T 497999000 8MHz 3/4 NONE QAM16 2k 1/32 NONE
T 522166000 8MHz 3/4 NONE QAM16 2k 1/32 NONE
Hi
uk-CaradonHill file has not been updated following the digital switchover that took place in the south west of England on 9th September 2009. Changes that occurred included new transmitter frequencies and
all multiplexes now using QAM64. (Previously BBC used QAM16, hence your loss of those channels).
Here is an updated uk-CharadonHill file that (should) work.
T 474167000 8MHz 2/3 NONE QAM64 2k 1/32 NONE #Mux SDN
T 482167000 8MHz 2/3 NONE QAM64 2k 1/32 NONE #Mux BBCB
T 497833000 8MHz 2/3 NONE QAM64 2k 1/32 NONE #Mux ArqA
T 506167000 8MHz 2/3 NONE QAM64 2k 1/32 NONE #Mux D3+4
T 521833000 8MHz 2/3 NONE QAM64 2k 1/32 NONE #Mux ArqB
T 530167000 8MHz 2/3 NONE QAM64 2k 1/32 NONE #Mux BBCA
T 546000000 8MHz 2/3 NONE QAM64 2k 1/32 NONE #Mux NEW7
Regards
Walt
