Jezz_X Wrote:If you want all the pretty live tv stuff yeah you should. because the main xbmc (Camelot) comes from the svn trunk and has no tv stuff aside from a file list in it. You need the Unified-pvr2 branch of xbmc to use all the pretty live tv stuff properly
Jezz, as i am totally noob in xbmc can you give me a hint where i can get latest files for this pvr2 ?
Do y reffering to:
http://gitorious.org/xbmc/xbmc/commits/9...melot-Live
You also mentioned about already compiled files - where i can find them?
This pvr is i assuming some kind of plugin to xbmc ?
Don't know for sure, but I'm pretty sure it's not possible to just compile a plugin. If you want the pvr-branch, it's a package deal. You have to compile from source or install from the hepi-ppa. You cannot run the pvr-branch with the ordinary xbmc build... As stated by Jezz_X above "because the main xbmc (Camelot) comes from the svn trunk and has no tv stuff aside from a file list in it"
Biggles, but as it is as you wrote how possible is this topic ?
In it i cannot find any infos about recompiling whole xbmc ?
Or maby the "issue" is only in live version ?
M.
You have to choices:
1. Compile from source
2. Install from the ppa
provided in the first post of this thread.
No matter which method you choose, you replace your current build (Camelot, Live or whatever) with the pvr-testing2 branch.
biggles Wrote:2. Install from the ppa provided in the first post of this thread.
Ok, i did like you mentioned but with no resoult. XBMC was reloaded (started as it was turned off during driver compilation, instalation, and packacges installation) and ... nothing - i could not find tv options in settings.
Check your logs (~/.xbmc/temp/xbmc.log) to see which version you are running. You obviously haven't installed the pvr-version, you are still running the old one... If that it the case, uninstall the old one, remove the xbmc-ppa from you sources and just keep the ones mentioned in the first post (or if you mean you have compiled your own, you probably haven't installed to the right directory. Check which directory your xbmc.bin is running from)
biggles Wrote:Check your logs (~/.xbmc/temp/xbmc.log) to see which version you are running. You obviously haven't installed the pvr-version, you are still running the old one... If that it the case, uninstall the old one, remove the xbmc-ppa from you sources and just keep the ones mentioned in the first post (or if you mean you have compiled your own, you probably haven't installed to the right directory. Check which directory your xbmc.bin is running from)
Biggles,
I have standard live beta edition:
12:14:10 T:3078080400 M:970891264 NOTICE: -----------------------------------------------------------------------
12:14:10 T:3078080400 M:970891264 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Dec 9 2009 (SVN:25484)
12:14:10 T:3078080400 M:970891264 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
With sources below:
root@noname:~# cat /etc/apt/sources.list
deb http://it.archive.ubuntu.com/ubuntu/ karmic main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu/ karmic-security main restricted universe multiverse
# Custom repositories
deb http://it.archive.ubuntu.com/ubuntu/ karmic-backports main restricted universe multiverse
deb http://www.lonelycoder.com/debian hts main
deb http://it.archive.ubuntu.com/ubuntu/ karmic-updates main restricted universe multiverse
deb http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/ karmic main
deb-src http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/ karmic main
deb http://ppa.launchpad.net/the-vdr-team/vdr-ubuntu-karmic/ubuntu karmic main
deb http://ppa.launchpad.net/henningpingel/xbmc/ubuntu karmic main
So also standard ones.
Could you tell me what exacly should i uninstall and install ?
So is this now working with the new default skin ? i cant find any TV option on my new setup (live)
biggles Wrote:I would start to comment out the ordinary repository (deb http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/ karmic main) do an apt-get update and apt-get upgrade and see if you get the pvr-version. If that doesn't work, I would uninstall xbmc and then try to reinstall it (with http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/ disabled).
Biggles,
Now (before upgrade) i have following packages avialable:
elisa-plugins-bad - Elisa plugins from the "bad" set
elisa-plugins-good - Elisa plugins from the "good" set
elisa-plugins-ugly - Elisa plugins from the "ugly" set
get-iplayer - download/stream available BBC iPlayer TV and radio programmes
libtvanytimeapi-java - Java API for parsing, manipulating and creating TV-Anytime metadata
python-elisa - media center solution - Python library
ivtv-utils - utilities for use with the ivtv kernel driver
mythtv - A personal video recorder application (client and server)
xserver-xorg-video-ivtv - X.Org X server -- IVTV display driver
xserver-xorg-video-ivtv-dbg - X.Org X server -- IVTV display driver (debug symbols)
vdr-plugin-wirbelscan - Channelscan plugin for VDR
vdr-plugin-analogtv - Plugin to vdr that connects analog-tv sources
vdr-plugin-lcdproc - Plugin to vdr that connects to lcdproc
vdr-plugin-pvr350 - VDR-Plugin that uses a PVR350 as output device
vdr-plugin-pvrinput - VDR plugin allowing to use a Hauppauge PVR card as input device
So i cannot find package y mentioned...
apt-get upgrade gave me:
root@noname:~# apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages have been kept back:
linux-image-2.6.31-16-generic
The following packages will be upgraded:
fuse-utils libfuse2 libglib2.0-0 libglib2.0-data libpython2.6
linux-headers-2.6.31-16 linux-headers-2.6.31-16-generic linux-libc-dev
python2.6 python2.6-minimal rsyslog upstart
12 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 17.5MB of archives.
After this operation, 12.3kB of additional disk space will be used.
Do you want to continue [Y/n]? y
After disabling
No luck... after remove and next install:
root@noname:~# apt-get install xbmc
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
xbmc: Depends: xbmc-data (= pvr-testing-17~hepi-karmic25817) but 1:9.11~beta2-karmic1 is to be installed
Depends: xbmc-skin-confluence (= pvr-testing-17~hepi-karmic25817) but 1:9.11~beta2-karmic1 is to be installed or
xbmc-skin-pm3-hd (= pvr-testing-17~hepi-karmic25817) but it is not going to be installed
Depends: xbmc-web-pm3 (= pvr-testing-17~hepi-karmic25817) but 1:9.11~beta2-karmic1 is to be installed
E: Broken packages
I will try with 9.11 live version
@Jakolim, As you already have the live version installed you will need to remove some packages and reinstall from Hepi's ppa, before running 'apt-get install xbmc-live' do;
apt-get remove xbmc-*
If that doesn't work you may need to explicitly do each package name eg;
apt-get remove xbmc-data xbmc-skin-confluence etc..
Then ensure Hepi ppa is enabled and XBMC PPA isn't and do apt-get update, apt-get install xbmc-live
catrix, Yes but you need a package with PVR support enabled it doesn't work right off the bat with the live CD.
You can replace the packages with PVR supporting versions by going through the first post (you will need to remove the XBMC PPA from sources.list if you have installed from Live).
Swifty Wrote:@catrix, Yes but you need a package with PVR support enabled it doesn't work right off the bat with the live CD.
Swifty, maby this is the solution for me too?
To remove "remove the XBMC PPA from sources.list" ?
jalokim: I already told you to remove XBMC PPA several posts ago...
