I guess the underlying problem of the message "Depends: vdr-abi-1.7.10-debian" is that there are two packages of vdr-plugin-vnsiserver in each PPA and they currently have exactly the same version name. We have one Karmic PPA for 1.7.10 and one Karmic PPA for 1.7.14. If you have both PPAs in your apt-sources, it seems that apt seems to priotize the 1.7.10 PPA. This problem would not occur if
a) you hadn't both PPAs (vdr-ubuntu-karmic + unstable-plugins) in your apt-sources or
b) we wouldn't use the same package version number for both packages (0.0.2+svn20100428-1yavdr1)
You could remove the PPA vdr-ubuntu-karmic or you could do apt-pinning to priotize the package version which is meant for 1.7.14. Or you can manually download the deb and install it via dpkg -i vdr-plugin-vnsiserver.
Cheers,
hepi
hepi Wrote:I guess the underlying problem of the message "Depends: vdr-abi-1.7.10-debian" is that there are two packages of vdr-plugin-vnsiserver in each PPA and they currently have exactly the same version name. We have one Karmic PPA for 1.7.10 and one Karmic PPA for 1.7.14. If you have both PPAs in your apt-sources, it seems that apt seems to priotize the 1.7.10 PPA. This problem would not occur if
Cheers,
hepi
Thanks a lot. I think I'll do a manual install. I need to have both the repositories, because the "unstable" one lacks some libraries like the xine2 (I still use the xine plugin as a backup when xbmc crashes)
dongioia Wrote:Thanks a lot. I think I'll do a manual install. I need to have both the repositories, because the "unstable" one lacks some libraries like the xine2 (I still use the xine plugin as a backup when xbmc crashes)
i have the same problem.anyone succeed to compile it?
AuXBoX Wrote:what do you mean laggy video.
just change the video settings
who uses teletext anyway
The streamdev plugin has a green screen for a second everytime i change channel aswell
Thanks to Hepi, I managed to install the vnsi plugin.
I found an huge issue: there is no ac3 audio support.
Watching a channel with ac3 5.1 audio, I can only hear 2 tracks.
is anyone using the Hauppauge HVR2200 with vdr?
i've just put in this card for the dual tuners and now vdr will not auto start on boot.
I'm using VNSI aswell
I can get it working with a manual start via terminal.
i also noticed on the xbmc.log an error which i'll have to post later when im home
but i remember it saying this
device 1 has no MPEG decoder
How can i manual open a vdr stream in xbmc?
I can play a vdr stream in VLC just fine, but in XBMC it just open url as an empty folder…
ex:
http://127.0.0.1:3000/TS/S5.0E-86-3-1110
EDIT: Found the solution (silly me): add the url to a text document and save it with .strm extension...
I might want to try stream with VNSI, but I do not know how (vnsi port nr?)
I am streaming to an Apple TV running ubuntu hardy and I don´t think the henningpingel XBMC is available on hardy. That is why I just want to stream it with a simple url
eiki Wrote:How can i manual open a vdr stream in xbmc?
ex: http://127.0.0.1:3000/TS/S5.0E-86-3-1110
You can try this:
http://xbmc.picmania.org/
or switch to tvheadend instead of vdr
this is my xbmc log error msg
10:13:09 T:3022727040 M:4060024832 ERROR: AddOnLog: pvrclient/VDR VNSI Client: Connection refused
10:13:09 T:3022727040 M:4059791360 ERROR: ADDON: Dll VDR VNSI Client - Client returned bad status (1) from Create and is not usable
10:13:09 T:3022727040 M:4059791360 INFO: Called Add-on status handler for '1' of clientName:VDR VNSI Client, clientID:pvr.vdr.vnsi (same Thread=no)
10:13:09 T:3013356400 M:4059791360 DEBUG: thread start, auto delete: 1
10:13:09 T:3022727040 M:4059791360 ERROR: PVR: couldn't load any clients
and my syslog:
Jun 10 13:16:17 mediacenter vdr: [1083] registered source parameters for 'A - ATSC'
Jun 10 13:16:17 mediacenter vdr: [1083] registered source parameters for 'C - DVB-C'
Jun 10 13:16:17 mediacenter vdr: [1083] registered source parameters for 'S - DVB-S'
Jun 10 13:16:17 mediacenter vdr: [1083] registered source parameters for 'T - DVB-T'
Jun 10 13:16:17 mediacenter vdr: [1083] no DVB device found
Jun 10 13:16:17 mediacenter vdr: [1083] initializing plugin: vnsiserver (0.0.1): VDR-Network-Streaming-Interface (VNSI) Server
Jun 10 13:16:17 mediacenter vdr: [1083] ERROR: invalid primary device number: 1
Jun 10 13:16:17 mediacenter vdr: [1083] ERROR: no primary device found - using first device!
Jun 10 13:16:17 mediacenter vdr: [1083] deleting plugin: vnsiserver
I've noticed the same issues, With streamdev everything works fine without dropping any frames, but after some channel switches it sometimes freezes so that I have to restart xbmc the hard way.
With VNSI, on the other hand, I have much faster switching times and not seen such freezes. But VNSI drops frames, at least on HD content. This is with the very same video settings I'm using with streamdev, so I think it's more related to a communication problem
AuXBoX Wrote:who uses teletext anyway
At least I do sometimes. It's not mission critical, but it is a nice to have for me.
With my problem i'm pretty sure my firmware for the tv tuner is being loaded after vdr starts.
I can restart vdr and then in xbmc turn off tv and the addon and then turn them back on and it will work.
Is there a way to get my firmware loaded quicker or delay vdr and xbmc loading
Is there a way for vdr to encode in h.264
AuxBox; How are you loading VDR ?
If it loads through /etc/init.d then you could pre-pend the vdr init script with 99-
eg; /etc/init.d/vdr < changes to > /etc/init.d/99-vdr
This would make VDR run last, hopefully by which time your firmware has loaded for your tuner.
Edit, whoops just noticed Hepi has probably already answered this one.. if so ignore
Swifty Wrote:AuxBox; How are you loading VDR ?
Hi Swifty,
so do i just change /etc/init.d/vdr to /etc/init.d/99-vdr is that right?
