Thanks for the links. Some great reading there.
how to channel scan dvbs2 and diseq conf ?
thanks hepi how to install wscan ?
mahmutuslu Wrote:thanks hepi how to install wscan ?
You can also use scan-s2 by the following;
hg clone
http://mercurial.intuxication.org/hg/scan-s2
cd scan-s2
make
make install
Then run scan-s2 with the arguments required (-h will probably give you a list) but it's something like -o vdr /dvb-s/Astra28.2 > channels.conf
Swifty Wrote:You can also use scan-s2 by the following;
hg clone http://mercurial.intuxication.org/hg/scan-s2
cd scan-s2
make
make install
error scan-s2 requires Linux DVB driver API version 5.0!
im from dvb card technotrend s2 3200
Have you compiled updated Linux DVB driver from the liplianin repo ?
Afaik you will need those to get the S2-3200 working..
Coming from the broadcast channel is currently only installed how I do not know where addresses are required, please help
There are currently broadcast rtl I'm watching the channel scan can 'ASTRA 19.2 problem
nice find decaturguy - I will add these to the OP.
Is it possible to install plugins that is not available in the ppa?
For instance I am interested in trying the plugin vdradmin-am.
