2010-04-25, 00:24
Quote:Would it be possible to add the HDHomeRun plug-in to the VDR repos?
lucid:
https://launchpad.net/~yavdr/+archive/testing-vdr
http://ppa.launchpad.net/yavdr/testing-v...hdhomerun/
untested
May 15 18:56:29 mythserver vdr: [2263] plugin 'streamdev-client' called obsolete function RegisterI18n()
May 15 18:56:29 mythserver vdr: [2263] starting plugin: streamdev-server
May 15 18:56:29 mythserver vdr: [2263] plugin 'streamdev-server' called obsolete function RegisterI18n()
May 15 18:56:29 mythserver vdr: [2263] loading /var/lib/vdr/plugins/streamdevhosts.conf
May 15 18:56:29 mythserver vdr: [2272] streamdev server thread started (pid=2263, tid=2272)
May 15 18:56:29 mythserver vdr: [2272] Streamdev: Listening (VTP) on port 2004
May 15 18:56:29 mythserver vdr: [2272] Streamdev: Listening (HTTP) on port 3000
May 15 18:56:58 mythserver vdr: [2272] Streamdev: Accepted new client (VTP) 192.168.1.4:42266
May 15 18:57:39 mythserver vdr: [2267] frontend 0 timed out while tuning to channel 46, tp 177
May 15 18:57:39 mythserver vdr: [2270] frontend 1 timed out while tuning to channel 50, tp 191
May 15 18:58:00 mythserver vdr: [2267] frontend 0 timed out while tuning to channel 102, tp 198
May 15 18:58:00 mythserver vdr: [2270] frontend 1 timed out while tuning to channel 13, tp 481
May 15 18:58:21 mythserver vdr: [2267] frontend 0 timed out while tuning to channel 73, tp 490
# svdrphosts This file describes a number of host addresses that
# are allowed to connect to the SVDRP port of the Video
# Disk Recorder (VDR) running on this system.
# Syntax:
# IP-Address[/Netmask]
127.0.0.1 # always accept localhost
192.168.1.0/24 # any host on the local net
#204.152.189.113 # a specific host
#0.0.0.0/0 # any host on any net (USE THIS WITH CARE!)
# streamdevhosts This file describes a number of host addresses that
# are allowed to connect to the streamdev server running
# with the Video Disk Recorder (VDR) on this system.
# Syntax:
# /etc/default/vdr
# See also /usr/share/doc/vdr/README.Debian.gz
# Change to 1 to enable vdr's init-script
ENABLED=1
# Change this to 1 if you want vdr to be able to shutdown the
# computer
ENABLE_SHUTDOWN=1
# Options that will be passed to vdr's commandline
# for example: OPTIONS="-w 15"
OPTIONS="-w 60"
VIDEO_DIR="/media/media/vdr"
netcat 192.168.1.7 2004
220 Welcome to Video Disk Recorder (VTP)
mythserver vdr: [2263] device 1 has no MPEG decoder
dchurch24 Wrote:Code:#
# Syntax:
Code:127.0.0.1 # always accept localhost
Code:netcat 192.168.1.7 2004
dubstar_04 Wrote:check your local network settings:
192.168.1.0/24
for me this is:
192.168.2.1/24
Is the address of your router 192.168.1.0 or 192.168.1.1 ?
I use the hauppauge nova-t cards with no problems so you can safely rule that out.
dchurch24 Wrote:Just tried it in any case, and sadly it's the same story :-(
Mario22 Wrote:I had the same kind of trouble, went for 0.0.0.0/0 ...
My network is pretty safe (I hope).
May 16 06:06:22 mythserver vdr: [3995] switching to channel 1
May 16 06:06:22 mythserver vdr: [3995] setting watchdog timer to 60 seconds
May 16 06:06:22 mythserver vdr: [3995] ERROR: no OSD provider available - using dummy OSD!
May 16 06:06:24 mythserver vdr: [4004] Streamdev: Accepted new client (VTP) 192.168.1.4:34116
May 16 06:06:24 mythserver vdr: [4004] streamdev: closing streamdev connection to 192.168.1.4:34116
May 16 06:06:28 mythserver vdr: [4004] Streamdev: Accepted new client (VTP) 192.168.1.4:49119
vdr --ver
vdr (1.6.0-2/1.6.0) - The Video Disk Recorder
streamdev-server (0.3.4-CVS) - VDR Streaming Server
Quote: sudo scan -o vdr -a 0 /usr/share/dvb/dvb-s/Hotbird-13.0E > /etc/vdr/channels.conf
-bash: /etc/vdr/channels.conf: Permission denied
Anastrophe Wrote:I followed the first post word for word (new install of OS and VDR + XBMC), but I'm getting a really silly error why trying to pipe the output of scan to channels.conf
Any ideas?
dchurch24 Wrote:Is there a way to change the order of the channel list without using the GUI?
Quote: - the on-screen keyboard seems to be broken for me and using a mouse (from a pad on a remote control) is really difficult ;-)
Quote:Are the music visualizations broken in this PPA version of XBMC?
Quote:EDIT: Actually, it has information for about 15 channels, and can play 4 or 5. I have done a scan into channels.conf, so am becoming a bit stumped ;-) Most that won't play seem to be ITV channels.
dchurch24 Wrote:Change the permissions. I simply did "chmod 777 channels.conf" just to be sure.
Mario22 Wrote:You can manually edit the channels.conf and change the order. Make sur VDR is not running while editing this file though.
Then under xbmc you can reset your channel information so the list will be updated and the new ordered list will be taken into account.
Quote:I bought myself a pretty expensive but very nice bluetooth keybord: logitech dinovo mini.
Woks out of the box under linux, all the keys are directly recognized by XBMC.
Quote:Same here. Only one visualization working here. No pb to me.
Quote:Which satellite are you trying to use ? Are you positive your antenna is pointing in the right direction ? How many lines do you have in channels.conf ? Did you create the file yourself ?
scan -x 0 -o vdr -a 0 /usr/share/dvb/dvb-t/uk-Dover > /etc/vdr/channels.conf
scan -x 0 -o vdr -a 1 /usr/share/dvb/dvb-t/uk-Dover > /etc/vdr/channels.conf
