2013-01-12, 07:37
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135
2013-01-12, 08:21
(2013-01-12, 07:37)eightmm Wrote: [ -> ]What script gets rid of the ads? Loving it
Huh? This addon and the program it's based on, pianobar, aren't supposed to have ads. You're the first person that I've seen that has mentioned having them. Can you give us more info about these ads?
2013-01-12, 19:57
Hi-
When I click on a station, nothing happens. None of the buttons are working for me.
Any suggestions? Thanks!
2013-01-13, 22:39
(2013-01-08, 04:54)k3oni Wrote: [ -> ]Try to use visualization and see if it works ok, should work fine. Use the small down arrow to trigger it.
I hit the down arrow, the visualizer comes up in the background but there are still static images on the screen. It's not a big deal, but it would be really cool if the default screensaver could override or maybe an option for a "floating" cover art / track infor display. Again, no big deal. The fact that this exists, works (for most) and is being maintained is fantastic. Thanks for all your hard work! I'm just going to try to teach ppl to turn the TV off when not actively using the OSD.
2013-01-14, 01:55
(2012-10-27, 23:56)user54 Wrote: [ -> ](2012-10-27, 20:40)cobels Wrote: [ -> ]Sorry for this noob question. Have looked in the forum but have not found the answer.
If you downloadload master.tar.gz from link on first page. How do i install it then in xbmc. Because xbmc expects an add from a zip file. And untaring this file and zipping it does not give a reslult.
The link on the first page gives me a download to a master.tar.gz where i expect a zip.
Please some help on what is most likely obvious to you.
That is a file for a different type of file system. I have uploaded a zip file that will work for you below.
http://www.filedropper.com/xbmc-pandora-...ora-pithos
A way to do this yourself is to download a program like 7-zip, which will read the gz file type. Once you have extracted the files, you can then make a zip file from that.
Thank you for this.. I was finally able to re-install and get Pandora working again!
2013-01-14, 02:38
(2013-01-13, 22:39)TechLife Wrote: [ -> ](2013-01-08, 04:54)k3oni Wrote: [ -> ]Try to use visualization and see if it works ok, should work fine. Use the small down arrow to trigger it.
Hmm, the visualizer should come up in the foreground and not background, do you have any opacity settings set for the visualizer?
2013-01-15, 14:56
I've just downloaded and installed for the first time. I'm using it on openelec / XBMC Frodo RC(1 I think). It only plays a single song then stops.
When I first select a station it sometimes puts me back to xbmc main screen then I go back into Pandora and it reinitialises the screen and loads the playing song, other times it shows the black screen with small pulsing logo. Most buttons don't work except pause.
Is this all known, is there a work around, or do I just wait for a future version?
I was really pleased to se Pandora available. thanks for everyones work.
- hmm I changed stations and its working now. Even the forward button worked, Like still doesn't it seems. I'm wondering if the ZZZ button is 'end after current song'?
-- after around 6 songs the standard xbmc screensaver kicked in, that was then the last song, here is the log error. http://pastebin.com/23MLaXRg
2013-01-15, 18:13
(2013-01-15, 14:56)Bedlore Wrote: [ -> ]I've just downloaded and installed for the first time. I'm using it on openelec / XBMC Frodo RC(1 I think). It only plays a single song then stops.
Which version are you running, where did you downloaded it from? Please go over the last 4-6 pages of this thread as it may answer some of your questions.
2013-01-17, 06:31
Downloaded the latest known working version, a few pages back and Pandora launches fine with my Pandora One account but when I select a station to play, nothing happens Any ideas?
2013-01-17, 07:17
Just wanted to report that I was able to get this plugin working, but I had to manually add my username/password to the pandora/pandora.py script at line 176:
At the top of the file, I set the CDUKES/CDUKESPW vars, like so:
Before I did this, I would add my user/pass via the normal ui, but the xbmc.log would just say:
I hope it helps someone else searching for this error later on
user = self.json_call('auth.userLogin', {'username': CDUKES, 'password': CDUKESPW, 'loginType': 'user'}, https=True)
CDUKES = '[email protected]'
CDUKESPW = 'mypassword'
ERROR: ERROR:root:fault code: 1002 message: An unexpected error occurred
2013-01-17, 21:45
(2013-01-17, 06:31)Govnah Wrote: [ -> ]Downloaded the latest known working version, a few pages back and Pandora launches fine with my Pandora One account but when I select a station to play, nothing happens Any ideas?
What is the audio format set to in your settings?
2013-01-18, 12:06
Did you delete the pandora files from your userdata/addon_data/ directory as well before reinstalling as was suggested just a few pages back? There have been some people that say there are problems with the "hi-fi mp3" mode so also try just "mp3".
2013-01-19, 07:49
(2013-01-18, 12:06)Rayor Wrote: [ -> ](2013-01-17, 06:31)Govnah Wrote: [ -> ]Downloaded the latest known working version, a few pages back and Pandora launches fine with my Pandora One account but when I select a station to play, nothing happens Any ideas?
Yes, that was the problem...switched from h-fi to mp3 and worked fine. Curious what is the diff, less bitrate between the 2 settings?
2013-01-25, 18:48
So I have read through several of these pages and am not finding what I am looking for although it should be common issue. I would like to use multiple loggins for Pandora. At least 2 my wife is insistent on having her channels available. How can I do this in xbmc. Windows 7. Thank you.
2013-01-25, 19:49
Probably a separate xbmc profile is your solution. You should read-up on profiles if you don't already use them. You can create a hotkey for each profile, for easy switching (which is what I do). I seem to recall having trouble years ago finding out how to do that, so here is one of my keymaps, placed under the <global> / <keyboard> section of keyboard.xml: <e>loadprofile(bedroom)</e>
