As previously mentioned, the error in log is:
06:43:24 T:139730199734032 M:948727808 NOTICE: Error:
06:43:24 T:139730199734032 M:948727808 NOTICE: org.apache.xmlrpc.XmlRpcException: Content is not allowed in prolog.
06:43:24 T:139730199734032 M:948727808 NOTICE: Code:
06:43:24 T:139730199734032 M:948727808 NOTICE: 0
06:43:24 T:139730199734032 M:948727808 INFO: Loading skin file: DialogYesNo.xml
Looks like we need to fetch the new crypt keys (input, output). That then causes some parsing failure in pianoparser.py:
09:14:08 T:139730314204944 M:974127104 ERROR: Error Type: exceptions.ValueError
09:14:08 T:139730314204944 M:974127104 ERROR: Error Contents: invalid literal for long(): }
09:14:08 T:139730314204944 M:974151680 ERROR: Traceback (most recent call last):
File "/home/eric/.xbmc/addons/script.xbmc.pandora/default.py", line 9, in ?
from libpandora.pandora import Pandora
File "/home/eric/.xbmc/addons/script.xbmc.pandora/libpandora/pandora.py", line 5, in ?
import crypt
File "/home/eric/.xbmc/addons/script.xbmc.pandora/libpandora/crypt.py", line 2, in ?
import keys
File "/home/eric/.xbmc/addons/script.xbmc.pandora/libpandora/keys.py", line 14, in ?
key_out = KeyFile( "crypt_key_output.h" )
File "/home/eric/.xbmc/addons/script.xbmc.pandora/libpandora/keys.py", line 6, in __init__
( n, p, s ) = pianoparser.parse_file( fname )
File "/home/eric/.xbmc/addons/script.xbmc.pandora/libpandora/pianoparser.py", line 32, in parse_file
d = [ long( x, 0 ) for x in d ]
ValueError: invalid literal for long(): }
09:14:08 T:139730314204944 M:974151680 INFO: -->End of Python script error report<--
I guess a few more changes are required.
Okay.. I got it working.
3 things needed:
1) Upgrade the version to 28 as previously mentioned.
2) Copy in the newer crypt keys
3) Modify pianoparser.py and change line 28 from: b = a.split( "}, {" ) to b = a.split( "},{" ) Notice the removal of a space (due to removal of space in the new crypt keys).
Those three changes allows it to work again.
Enjoy.
Those changes worked for XBOX. THANKS!
tslayer Wrote:Okay.. I got it working.
3 things needed:
Enjoy.
Thanks for this. Your instructions got it working for me as well.
tslayer
Thank you for taking the time to track that down
. I've pushed the parser change to gitorious.
@all
Don't have much time to spend on this currently, so if someone wants to step up and work on/maintain it feel free. If you make any changes and want me to merge them back into my main repo just send a merge request. I may grant commit access as well if changes look good.
3 things needed:
Enjoy.
Huge thanks!!
I updated to the newest repo file and crypt keys. That gets me into the script, I can see the my stations, but I can't get anything to actually play. the sound effects for selection, play, skip, minimize etc. play but nothing happens.
Any ideas?
Works fine here. What does the xbmc.log tell you?
14:55:02 M: 57339904 NOTICE: -----------------------------------------------------------------------
14:55:02 M: 57319424 NOTICE: Starting XBMC4Xbox. Built on Sep 16 2010 (SVN:30635, compiler 1310)
14:55:02 M: 57319424 NOTICE: special://xbmc/ is mapped to: Q:\
14:55:02 M: 57319424 NOTICE: special://masterprofile/ is mapped to: q:\UserData
14:55:02 M: 57319424 NOTICE: special://home/ is mapped to: Q:\
14:55:02 M: 57319424 NOTICE: special://temp/ is mapped to: Z:\
14:55:02 M: 57319424 NOTICE: The executable running is: E:\dash\default.xbe
14:55:02 M: 57319424 NOTICE: Log File is located: Q:\xbmc.log
14:55:02 M: 57319424 NOTICE: -----------------------------------------------------------------------
# lots of mounting and such..... #
14:55:10 M: 27086848 ERROR: PICTURE: Error loading image special://skin/backgrounds/scripts.jpg
14:55:12 M: 21413888 NOTICE: -->Python Initialized<--
14:55:13 M: 20574208 ERROR: Error Type: exceptions.ImportError
14:55:13 M: 24948736 ERROR: Error Contents: No module named xbmcaddon
14:55:13 M: 24399872 ERROR: Traceback (most recent call last):
File "Q:\scripts\script.xbmc.pandora\default.py", line 6, in ?
import xbmcaddon
ImportError: No module named xbmcaddon
So how do I go about fixing this one? Or am I just screwed?
- Greg C.
gcurtis79 Wrote:Code:
import xbmcaddon
- Greg C.
I am having the same problem, is there any solution? I saw a similar problem on page 16 with no result.
You are putting it in scripts. It is an addon.
Though, not sure whether/how this works on xbox. We don't support Xbox here. Please goto the proper forums.
No, I also put it in Programs, Music Plugins, and even for a shot in the dark; Video Plugins. I am running Ubuntu 10 (not an Xbox) and I have other Plugins working, just not Pandora
Ok, sorry about that, I was just reading the end of his log. I am getting this:
13:05:50 T:2839473008 M:1641517056 NOTICE: File "/home/xbmc/.xbmc/plugins/music/SCRIPT.XBMC.PANDORA/default.py", line 6, in ?
13:05:50 T:2839473008 M:1641517056 NOTICE: import xbmcaddon
13:05:50 T:2839473008 M:1641517056 NOTICE: ImportError
13:05:50 T:2839473008 M:1641517056 NOTICE: :
13:05:50 T:2839473008 M:1641517056 NOTICE: No module named xbmcaddon
13:05:50 T:2839473008 M:1641517056 ERROR: Scriptresult: Error
13:05:50 T:3079358352 M:1641701376 ERROR: GetDirectory - Error getting plugin://music/SCRIPT.XBMC.PANDORA/
13:05:50 T:3079358352 M:1641701376 ERROR: CGUIMediaWindow::GetDirectory(plugin://music/SCRIPT.XBMC.PANDORA/) failed
I keep getting the "No module named xbmcaddon"
It is there, I don't know why it wont work....
It is not a plugin!! It is an addon!
Upgrade XBMC to Dharma and install as an addon.
