there a list of what the buttons do? I'm finding that with my mce remote(mapped to a harmony 880) i can navigate around pandora, but i can't exit it, and i have some issues knowing what to do to show/hide the menu etc
if anyone knows even what the keyboard is mapped to do in this script i could probably figure out what buttons on the remote do, thanks!
Can anybody zip up a working copy and post it ?
working copy of the script from the addons directory?
idlehands Wrote:there a list of what the buttons do? I'm finding that with my mce remote(mapped to a harmony 880) i can navigate around pandora, but i can't exit it, and i have some issues knowing what to do to show/hide the menu etc
the DVD Menu button will exit it on a MCE remote.
HI again! Thanks for the reply. I did get the crypt files downloaded to the correct .txt documents. However I go under settings and use the file manager and try to copy the files. I only see a profile directory->ADDON_DATA->(and in that directory I found my grooveshark addon. So I assume this is the right place. So I created a new folder labeled script.xbmc.pandora and put the zip file and the crypt files in there. Now i can't find it anywhere on the system to initiate the script. I am lost. I also tried the zip file a user posted a few pages back and tried that. It did install from zip and it enabled the addon to the music addons. I can't launch that one because it gives me a failed to authenticate error. Even after following the steps listed in post 243 and after logging in with my account info. It would be much appreciated if someone could just post an up to date copy of the zip file for us noobs that are striking out trying to take advantage of this GREAT script. Any advice is appreciated Thanks in advance!
EDIT: So I found another addons folder /USR/SHARE/XBMC/ADDONS/ now the problem with this is that I keep trying to create a new folder or even just copy the one that I have to that folder and I am not having any luck. No new folder is created or if i try to copy the entire file i get an error copy failed
Failed to copy at least one file
Operation was aborted.
Again thanks in advance for the help
I'm having the same issue as happyendin21. And I did exactly the same things as happyendin21 as well as about 50 variations of it.
The zipfile someone posted has been the only way i could get the addon to show up, but as mentioned I'm unable to login probably due to new revisions in the script.
Maybe it's because I'm new to all this, but being a beginner the instructions are not very clear.
Even downloading the key files was a struggle. Went to "pianobar / libpiano / src /" then found the 2 files, click on raw and it opens the files up in a browser. Wasn't sure if I was to just copy the text into notepad or just what, but eventually right clicked raw and did save link as. Which seemed to work but still not 100% that's correct since I can't get the addon/plugin/script to show up.
I read all 29 pages and I thought somewhere in there would be a clear way of getting it to work, maybe a video, some screen shots, or the add plugin with zip method.:confused2:
Ok i got it working.
My problem was that I only extracted the .tar.gz file once with 7zip. I had to do it twice. It then created a directory with a bunch of files where I then put the 2 key files in and renamed the directory.
EDIT:
Here is my working pandora script folder zipped, This should work by just going to addon by zip or whatever its called and finding the file below and installing it that way.
[url=http://www.sharefile.org/showfile-3606/scriptxbmcpandora.zip" title="download file from Share File]http://www.sharefile.org/showfile-3606/scriptxbmcpandora.zip[/url]
Thank you very much...it's working for me now.
Working for me now too using the zip provided by WannaSpeedCom. Thanks.
Thanks WannaSpeedCom !! Works great
The real thanks goes to the people that wrote the script, but im glad I could help get it working for a few of ya'll. I saw a someone request background play, I think that would be great if it's possible.
I can't tell if the thumb buttons are working or not. Any info on that?
hmm.....do we know if that function will be added soon on not?
Sure.. whenever somebody decides to code it, it will be added
