I've created a gitorious project for this script at
http://gitorious.org/xbmc-pandora. Everyone can grab the latest reversion from there packed up as as a tar.gz file so I won't have to pack up a new zip every time I fix something any more.
I've pushed fixes for the album art and crashing on second start, and added a few dialogs to be a little more verbose.
bac522 Wrote:No and right now the script doesn't support a proxy (which would have to be US based).
I also know that CartoonNetwork is another one that's region sensitive, but via Navi-x the stream is a-okay. Thoughts?
Sweet... Updated to the latest version from the repo, then like everyone else realized that the crypt files must be copied and pasted... when direct downloaded they include a bunch of html crap that shouldn't be in the file... like...
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head>
<meta http-equiv="content-type" content="text/html;charset=UTF-8" />
<meta http-equiv="X-UA-Compatible" content="chrome=1">
<title>libpiano/src/crypt_key_input.h at master from PromyLOPh's pianobar - GitHub</title>
<link rel="search" type="application/opensearchdescription+xml" href="/opensearch.xml" title="GitHub" />
<link rel="fluid-icon" href="http://github.com/fluidicon.png" title="GitHub" />
<link href="http://assets0.github.com/stylesheets/bundle_common.css?501ce6bf650b95b753c6fc4e0bf761c1e07d1a1c" media="screen" rel="stylesheet" type="text/css" />
<link href="http://assets3.github.com/stylesheets/bundle_github.css?501ce6bf650b95b753c6fc4e0bf761c1e07d1a1c" media="screen" rel="stylesheet" type="text/css" />
<script type="text/javascript" charset="utf-8">
var GitHub = {}
var github_user = null
</script>
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js" type="text/javascript"></script>
<script src="http://assets2.github.com/javascripts/bundle_common.js?501ce6bf650b95b753c6fc4e0bf761c1e07d1a1c" type="text/javascript"></script>
<script src="http://assets2.github.com/javascripts/bundle_github.js?501ce6bf650b95b753c6fc4e0bf761c1e07d1a1c" type="text/javascript"></script>
GitHub.spy({
repo: "PromyLOPh/pianobar"
</script>
So click through the file and copy and paste the actual text from the raw into files named as such.
Once I had all that squared away the script worked superb! :thumbsup:
You have to use the "raw" link when downloading to get the actual file.
is there away to place the pandora icon on the home page, rather then going into scripts\Pandora.
Im using the Rapier skin
this is fan-effing-tastic. thank you!
I have this up and running on my xbox - looks good. seems like the stream breaks and "skips" to the next song from time to time, but nothing major. I was shopping this evening for a BD player that could do netflix, pandora, and pick up divx/xvid from my computer downstairs and landed on an LG for almost $300... glad I didn't pull the trigger.
First off I just wanted to say thank you so much for putting this together. Its long been something that I've really wanted in XBMC. So much in fact that I finally registered an account here on the forums to let you know how grateful I am.
Secondly on behalf of Pandora I'd like to thank you as well as I've finally moved over to a Pandora One account greatly due to your script allowing to me to access their service on my media pc.
Again, thank you so much!
Swwethip1 Wrote:is there away to place the pandora icon on the home page, rather then going into scripts\Pandora.
While I don't know if there is a way to mod it into the base menu you can always favorite it and access it from the favorites menu instead. Its a little more convenient this way.
Hmm...I followed the instructions, and I go into Pandora and select a station, yet nothing happens. I don't get an error, but nothing plays either... I know I'm logged in b/c my stations show up...please help!
EDIT: Nevermind...Seems I needed to renew my Pandora One account
Any idea when thumbs up/down may function?
PS Amazing work, i love this! Great first step to have Pandora in XBMC
I am sure this is a silly question, but ohh well...
I am using the XBMC Live install (Linux) and it opens up straight to XBMC... How am I supposed to install this when my setup is like that?
Hawk3907 Wrote:I am sure this is a silly question, but ohh well...
SFTP into your machine and copy the pandora script into the scripts folder.
I have followed the installation instructions and when I go to my ATV and click on the script it says it is running and then says "something is wrong with your encryption keys"
What I downloaded was :- crypt_key_input.h and crypt_key_output.h
Are these the correct keys?
I added them to the Pandora script folder.
Thanks for any help, this looks like a great script.
Hey ya Mique, I'm not sure but I also grabbed the crypt.h files as well. In addition to that you might want to toss the files into a text editor and make sure that the files are clean as the first set I downloaded also have a bunch of html in them. In the end I ended up copy and pasting the files to avoid the html issue. Hope this helps out somewhat, gl!
I'm trying to use this script but i keep getting an error:
Failed to authenticate listener
Check username/password and try again.
I'm sure my username and password are correct. I even tried re-entering it but i keep getting the same message.
Any ideas?
I keep getting crypt key errors, anyone else?
