Yes, working now.
Thank You newatv2user.
im sorry but after reading through page after page and google searched countless times i still hav eno idea how to add this into XBMC.
i cant find the file using file manager
- i placed the file in my add ons folder and still nothing
i have no clue what to do and everything seems to be written in a form for advanced users. can some please help me out id love to have pandora in my xbmc
I just downloaded and installing this addon. It looks like it worked because I can see it log into Pandora and I can see my playlists but I can't get anything to actually play. What am I missing??
Thanks ............. Rob
http://forum.xbmc.org/showthread.php?tid...pid1345283
(2013-03-24, 14:50)cruzstyle Wrote: [ -> ]im sorry but after reading through page after page and google searched countless times i still hav eno idea how to add this into XBMC.
I just realized that when I "Thumbs Down" in XBMC Pandora, it actually registers as a "Thumbs Up" in Pandora. Anyone else have that trouble? It's kinda funny until you start getting Taylor Swifter for an hour at a time.
Nope.
You could log into your pandora account on a computer and verify which tracks are thumbed up or down.
Wow this works so well on my Raspberry Pi running openelec. Thanks!!!
I can connect and play music just fine. But although I have a One account, I can only stream at 65kbps even if I set the Audio Quality to high. Any thoughts?
One thing I have noticed is some of my channels are much louder then others. Kind of like there's no replaygain. Not a big deal though. Works 100% for me with openelec 3. High quality works perfect here.
(2013-04-05, 01:33)JBNY Wrote: [ -> ]I can connect and play music just fine. But although I have a One account, I can only stream at 65kbps even if I set the Audio Quality to high. Any thoughts?
Pandora One isn't supported in the addon yet. I don't think it's too much work to add One support in the addon. If nobody else has done it by the time I am free, I might take a look at it.
I can't get this add-on to work at all. Have also tried two older versions. The two older versions both say, "Failed to authenticate listener. Check username/password and try again." Also tried manually adding my Pandora login into the pandora.py file...then it just says ERROR: script failed.
Error unable to load keys.
I tried search but came up empty, is there a fix for this?
(2013-04-05, 22:19)newatv2user Wrote: [ -> ]Can any One subscriber test this:
https://www.box.com/s/0qheiyh6a6m7qgy6nej3
I don't have One. So not sure if it works or not for One subscribers. Make sure to go to addon settings and enable One.
Works! Awesome! Only playing for a little bit, but so far so good! I've got 190kbps now.
Thanks so much!!
