(2014-05-19, 06:23)shuvro Wrote: [ -> ] (2014-05-19, 06:09)RedPenguin Wrote: [ -> ] (2014-05-19, 04:35)shuvro Wrote: [ -> ]Hi! How to install ur APK
Coz its not installing .
thanks /shuvro
Just make sure you don't have the official XBMC APK installed as my signature is not the same. That's the only thing I can think of off hand.
Also make sure you have "Third-Party Software" enabled in Android Settings.
I tryed in my Measy B4K TV BOX its not instolling . If i do it manully then how i will install RTMPDDUMP
http://wiki.xbmc.org/index.php?title=HOW...te_librtmp
That Wiki page tells you where to put the file on Android.
Also just so you don't get confused, it's librtmp you need for XBMC, not the entire RTMPDUMP project.
The other files/programs are just for recording and allowing other media players that don't have RTMP support built-in for example.
thanks /shuvro
I tryed in my Measy B4K TV BOX its not installing . If i do it manully then how i will install RTMPDDUMP
allso tried on my samsung Galaxy tab 3 7"
(2014-05-19, 06:36)shuvro Wrote: [ -> ] (2014-05-19, 06:23)shuvro Wrote: [ -> ] (2014-05-19, 06:09)RedPenguin Wrote: [ -> ]Just make sure you don't have the official XBMC APK installed as my signature is not the same. That's the only thing I can think of off hand.
Did it give a message at all? AFAIK it should work. I don't have a ready Android to test it though.
(2014-05-19, 06:37)RedPenguin Wrote: [ -> ] (2014-05-19, 06:36)shuvro Wrote: [ -> ] (2014-05-19, 06:23)shuvro Wrote: [ -> ]I tryed in my Measy B4K TV BOX its not installing . If i do it manully then how i will install RTMPDDUMP
I tried in my Measy B4K TV BOX & Samsung Galaxy Tab 3 7.0, its not installing .
I am gatting Parsing error " There is a problem parsing the package "
Where to download the files ?
Following links does not work
http://is.gd/kBaTzY
http://is.gd/yQUqNm
http://is.gd/GJdaEY
FYI is.gd is currently experiencing a DDoS attack and temporarily offline. Look back a few posts for alternative links. Please remove the quoted post, it doesn't need to be quoted in full every bloody time.
Thank you. I got it from your dropbox link.
I heard that is.gd is being moved to new
http://v.gd
(2014-05-20, 10:35)jkcool Wrote: [ -> ]I heard that is.gd is being moved to new http://v.gd
v.gd is a separate service from is.gd (operated by the same people/company). It's just is.gd that is being DDoS'd at the moment.
(2014-05-19, 00:51)RedPenguin Wrote: [ -> ] (2014-05-17, 21:51)iriki Wrote: [ -> ]I'm having issues with streams on the Android version that don't happen in the Windows version, and I found out that there is no librtmp.so version 5.14.4 for Android, it seems the latest is 4.9.14 that is contained in the xbmc-13.0-Gotham_beta4-armeabi-v7a-RP.apk file.
So my best guess is to wait, right?
Thanks in advance.
I just released yesterday a 13.0 and 13.1 final APK with my very latest librtmp with the redirect+streamify fix (5-14-14).
Thank you very very much my friend, the streams are now working great on Android!!! Many thanks and best regards !
Hi RedPenguin
I've been wanting to update XBMC on my Android box to one of your versions. I've tried the Fodo 12.3, Beyond XBMC 3.4 Beta, and Gotham 13.0 but the first two don't seem to give me hardware acceleration and Gotham doesn't play my test file at all. I have a generic G18REF g-box which came with a hardware accelerated Frodo 12.0. Playback on the original version is great, but I get quite a few streams that don't work now so I just wanted to try a version with a newer librtmp. Could you take a look at my log file to see if you can spot a problem please? I can't see one but I'm no expert
http://xbmclogs.com/show.php?id=209658
(2014-05-25, 02:04)AlBundy Wrote: [ -> ]Hi RedPenguin
Well to give you some info off the bat.
Frodo and Beyond 3.4 Beta (I believe also based off Frodo) didn't have Android hardware acceleration it was introduced in 13 Gotham.
Also that log is from 12.3 not 13. Also I recommend trying 13.1 Beta 2.
Hi RP,
Can I use the streamify fix for all windows (RP version), as most up to date?
What is the difference between KSV and RP, or is RP simply better?
(2014-05-25, 02:55)RedPenguin Wrote: [ -> ] (2014-05-25, 02:04)AlBundy Wrote: [ -> ]Hi RedPenguin
Hi, thanks for the reply.
Yes the log is from 12.3, that was the version I was running when I posted it. I'm sorry, I don't know where I got the idea that your apk's were hardware accelerated. I've been looking through so many threads trying to find a version with a newer librtmp than mine, I must have had a brain malfunction.
(2014-05-25, 11:06)sattekop Wrote: [ -> ]Hi RP,
"My Streamify" fix is simply KSV's patch with the Streamify patch added as he sometimes gets busy and can't add every fix folks recommend.
(2014-05-25, 12:37)AlBundy Wrote: [ -> ] (2014-05-25, 02:55)RedPenguin Wrote: [ -> ] (2014-05-25, 02:04)AlBundy Wrote: [ -> ]Hi RedPenguin
My 13.0 Gotham APKs have Hardware Accel just not the 12.3 Frodos because they were created before Hardware Accel for Android was put in.
I have a problem and this may not be the place to put it, but a couple of streams have no sound at all. N*Lnetwork & E*PN, I've updated the rtpm which is mentioned here and still no sound. Now I know these streams have sound I can play and hear them on my atv2. I just don't know what to docan someone give me a hand. I'm working with a Raspberry Pi XBMC Gotham. If log is needed l will provide, but i'm not sure what part of the log you want or how deep you want to dig. Thanks in advance.
