2015-10-06, 17:27
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
2015-10-06, 17:46
A question, can internal player (no kodi) play full 3d iso?
2015-10-06, 17:59
(2015-10-06, 17:21)Skank Wrote: [ -> ](2015-10-06, 16:36)mirror88 Wrote: [ -> ](2015-10-06, 15:59)langostino Wrote: [ -> ]So, now it hasn't 3d signal out, isn't it? It can't play 3d iso.I can't promise you anything now,It's need a technical meeting,But dued to our National Day, we are having a 7-day holiday from Otc.1st to Otc.7th.I write this post in my home It's my holiday So I said there will be an answer in a week.
I think I'll cancel my order.
when i said
Quote:Now Completed the two way 1080P decoding, but because of the reasons for HDMI EDID. The custom KODI does not send 3D signals to the tv. So it looks like SBS, we're in the check this problem.You can change your TV's 3D model to left/right temporaryIt means you need manual switch 3D model on TV now.HDMKV is right!
He cant promise it will do 3d iso? Their source code already help RPi2 to play 3D.ISO
But it was their marketing !!!
Saying "cant promise" doesnt fit, they are obliged to.
I think we have a give them a little time for them to figure it out.
2015-10-06, 18:01
(2015-10-06, 17:46)langostino Wrote: [ -> ]A question, can internal player (no kodi) play full 3d iso?
https://youtu.be/ZQ7EDeGPX4Y
2015-10-06, 18:01
Yeah, true
2015-10-06, 18:18
But, does tv turn on 3d when you play a 3d mvc file or you must to force on tv 3d sbs mode?
2015-10-06, 18:23
(2015-10-06, 18:18)langostino Wrote: [ -> ]But, does tv turn on 3d when you play a 3d mvc file or you must to force on tv 3d sbs mode?
3D framepacked playback is not working as for now.
2015-10-06, 18:25
I think it's a hardware limitation from rockchip sdk. Other box with same soc can't work with mvc framepacked files.
What do you think?
What do you think?
2015-10-06, 18:27
just in kodi now,internal player not need to force on tv 3D sbs mode
and in kodi,We will fix it
2015-10-06, 18:30
(2015-10-06, 18:27)mirror88 Wrote: [ -> ](2015-10-06, 18:18)langostino Wrote: [ -> ]But, does tv turn on 3d when you play a 3d mvc file or you must to force on tv 3d sbs mode?
With explorer and using the internal player 3D.ISO framepacked didn't work for me.
Video: https://youtu.be/ZQ7EDeGPX4Y
2015-10-06, 18:33
(2015-10-06, 18:30)movie78 Wrote: [ -> ](2015-10-06, 18:27)mirror88 Wrote: [ -> ](2015-10-06, 18:18)langostino Wrote: [ -> ]But, does tv turn on 3d when you play a 3d mvc file or you must to force on tv 3d sbs mode?
i'm not that sure they will fix it
Mirror88 , why did you say 3d iso worked, but now it doesnt. Havent you guys tested this before shouting it worked?
2015-10-06, 19:10
I'm confused, does it play 3d iso but you have to manually switch your TV to 3d mode.
Or does it just not play the 3d iso at all.
Also what new product released is already perfect, none! All products need firmware upgrades.
I still have hope the x6 will come good.
2015-10-06, 19:31
I'm thinking about buy himedia q5. I think it's more sure.
2015-10-06, 19:55
Okay, here's the deal with full, frame-packed 3D... nothing is playing in 3D mode for now, whether 3D ISO or MVC MKV. Latter I'm not expecting, but thought I'd check anyway...
I had an error here originally, which I've crossed-out and revised now.
MVC MKV:
- No 3D via Kodi; plays back in 2D mode
- No 3D via native player (using file explorer); plays back in 2D mode
3D ISO:
- Via Kodi and native player, plays back in SBS mode. Forcing projector to SBS doesn't display in 3D, rather 2D
- Via native player, plays back in 3D, but as HSBS. PQ is poor, with lots of pixellation, stutters (shaky video)
With native player, there are options to force MVC track and MVC playback, but neither has any effect; playback remains 2D or SBS. Also, playback is poor; jerky and not as sharp.
With Kodi, pressing 'OK' and bringing up the on-screen controls to go into 3D options, 'Enabled' only shows selected if you move over it, but move away, and it's deselected. Trying to select it doesn't work. Forcing to SBS also doesn't give you 3D. The 3D option in Kodi menu is only showing up I think as I have ".3D" in the filename of all my 3D files (3D ISO and MVC MKV). Via Zidoo Kodi, it really seems to not be working.
MVC MKV:
3D ISO:
2015-10-06, 20:27
Not so good then, that was the big selling point from zidoo (3d playback).
Seriously considering canceling my order and getting nvidia shield. (although 3d not great with it either)
