(2015-10-10, 10:58)goujam Wrote: [ -> ] (2015-10-10, 10:16)mirror88 Wrote: [ -> ] (2015-10-09, 21:38)hdmkv Wrote: [ -> ]HiMedia's H8 has promise... they apparently have an update coming with 3D ISO & HD audio via Kodi (assuming custom like Zidoo's) w/o wrapper (like Q5 relies on).
This promise based on zidoo open source ,so about 3D same of zidoo x6
And when they release their source code you will be able to see if they have made any improvements that you could use. That's the beauty of open sourer
Then cloud media release their firmware
(2015-10-10, 11:48)couto27 Wrote: [ -> ] (2015-10-10, 10:58)goujam Wrote: [ -> ] (2015-10-10, 10:16)mirror88 Wrote: [ -> ]This promise based on zidoo open source ,so about 3D same of zidoo x6
Exactly if everyone sticks to the rules everyone benefits.
In other news I got my zidoo x6 pro yesterday it's hopefully replacing a j1900 baytrail PC and android stick I use. I'll get it setup later and then start setting my Logitech harmony up to use it. Hoping to have 1 activity to go straight into kodi and another for just android
What's the best way to shut the box down using a harmony remote. To power down you have to press power then select an option.
(2015-10-10, 15:01)goujam Wrote: [ -> ]What's the best way to shut the box down using a harmony remote. To power down you have to press power then select an option.
What harmony are you using?
(2015-10-10, 16:44)movie78 Wrote: [ -> ] (2015-10-10, 15:01)goujam Wrote: [ -> ]What's the best way to shut the box down using a harmony remote. To power down you have to press power then select an option.
A harmony 900, do I need to create a sequence to shutdown ?
If you just press the power button its not going to shutdown
I'm not sure if cancel my zidoo x6 order. But i don't know a good alternative. Hinedia q5 is good, but it's got some problems as samba user-paswords, no Bluetooth and some addons kodi .
(2015-10-10, 17:36)langostino Wrote: [ -> ]I'm not sure if cancel my zidoo x6 order. But i don't know a good alternative. Hinedia q5 is good, but it's got some problems as samba user-paswords, no Bluetooth and some addons kodi .
What are you worried about with the x6?
(2015-10-10, 17:39)goujam Wrote: [ -> ] (2015-10-10, 17:36)langostino Wrote: [ -> ]I'm not sure if cancel my zidoo x6 order. But i don't know a good alternative. Hinedia q5 is good, but it's got some problems as samba user-paswords, no Bluetooth and some addons kodi .
3d output missing
(2015-10-10, 17:50)langostino Wrote: [ -> ] (2015-10-10, 17:39)goujam Wrote: [ -> ] (2015-10-10, 17:36)langostino Wrote: [ -> ]I'm not sure if cancel my zidoo x6 order. But i don't know a good alternative. Hinedia q5 is good, but it's got some problems as samba user-paswords, no Bluetooth and some addons kodi .
3d output missing
My understanding is its outputiing 3d but not framepacked. It's down to if you think they will fix it or not. Looking at the support log from there other boxes it does look like they are supplying fixxes at least once a month
(2015-10-10, 18:22)goujam Wrote: [ -> ] (2015-10-10, 17:50)langostino Wrote: [ -> ] (2015-10-10, 17:39)goujam Wrote: [ -> ]What are you worried about with the x6?
3d output missing
My understanding is its outputiing 3d but not frame packed. It's down to if you think they will fix it or not. Looking at the support log from there other boxes it does look like they are supplying fixxes at least once a month
Every media box in the market has issues with to start ...it's how these mfg update their product and release fixes ... looking at what is stated seems soon they will be releasing an update..
Mirror any news from tech meeting about 3d ISO?
(2015-10-10, 18:49)asshenoy Wrote: [ -> ] (2015-10-10, 18:22)goujam Wrote: [ -> ] (2015-10-10, 17:50)langostino Wrote: [ -> ]3d output missing
I think this bug (3d framepack output) will not fixed. Only Hinedia h8 has got 3d output.beelink and other boxes with same soc haven't got 3d output .
I have a feeling Zidoo will fix 3D output... whether full 3D or HSBS, unknown. Hopefully former.
I posted this in the Xidoo form and thought others here may find useful..
While I am enthusiastic about the X6 I have found the following issues:
Using Kodi as supplied in X6 with the HDHomeRun add-on for cable tv.
1. Using HDMI Bitstreaming sound is unstable in Kodi; sound seems to be out of sync by about 0.500s ahead of video.
2. Also sound has a bit of an echoey characteristic.
Checked PCM sound format and did have some syncing issues although they seemed to correct rather quickly.
Again video is outputted in YCbCr 4:4:4 color format which is not ideal make a somewhat dark picture and should be user adjustable; even Blu-ray players tend to give user adjustments for color format.
A Plus on picture quality, seems very clean
Also playing MKV movies via Emby for Kodi:
Video is very good
Advanced sound formats all seem to work very well this includes:
DTS-HD
TRUE-HD
Dolby ATMOS
Remote controls FF, skip etc tend to be a little iffy but this I think is more Kodi.
My System:
All via HDMI -X6 > Denon AVR-X5200W > Lumagen Radiance XS+ > Benq W1070 projector
Rew
(2015-10-11, 15:38)Rew452 Wrote: [ -> ]My System:
Rew
Can you confirm the X6 clock framerate (23.976) outputs at 24hz.
Go to Lumagen XS menu > info
