(2015-10-20, 11:47)Skank Wrote: [ -> ]There are 2 bugs seriously concerning me:
- artefacts/macroblocks in picture
- 3d iso played as 2d in kodi, stops in middle of movie at some point
Have never seen artifacts or macroblocking like you are seeing, what is your video source and video format?
What are you using for a display?
These could be the problem areas. But you need to supply the above info to figure it out.
And what about temperature? I read in this thread zidoo x6 is hot when you're watching films.
(2015-10-20, 12:48)Rew452 Wrote: [ -> ] (2015-10-20, 11:47)Skank Wrote: [ -> ]There are 2 bugs seriously concerning me:
It is already confirmed by several people seeing it too
so..
Happening with all kind of videos
Display doesnt matter (all displays)
(2015-10-20, 07:58)wesk05 Wrote: [ -> ]Here is what I found:
Blu-ray 3D iso output is indeed frame packing. I checked it on Epson 5020UBe, Samsung JS8500 and Sony W900, W802A TVs.
Edit: It looks like this is not consistent. See my update 3 posts below.
Now the problems:
1) 3D playback freezes after a few minutes. I checked 3 movies and it happened on all four displays. It didn't matter whether the playback was from local hard disk or NAS.
2) Refresh rate doesn't seem to switch correctly. I have enabled both "Adjust display refresh rate" and "Refresh rate switch". "Allow hardware 23976 optimize RockchipCodec" is also enabled. With 23.976fps content, I could see refresh rate switching, but it is not 23.976Hz, It switches to 24.000Hz (from Lumagen Radiance Video Processor). This was the same for 2D and 3D content.
3) I am still getting no audio (7.1 DTS-HD Master Audio). Just noise. This is with Onkyo TX-NR928 AVR and Sony CT-780 soundbar.
4) As movie78 has mentioned, Kodi menu is all messed up in 3D mode.
wesk05, thanks, will test again today. I forgot to enable the 23.976 setting as mirror88 had suggested (my bad there).
Dont forget to tag 1080p 24 too in general android setting
(2015-10-20, 13:08)Skank Wrote: [ -> ] (2015-10-20, 12:48)Rew452 Wrote: [ -> ] (2015-10-20, 11:47)Skank Wrote: [ -> ]There are 2 bugs seriously concerning me:
so..
Ok, so you experience this in 3D but not in 2D and you are using HDMI, right?
(2015-10-20, 08:30)Skank Wrote: [ -> ]I didnt have time to test the 3d framepacking
I did test other stuff :
- still artifacts (come on, get rid of them or the player is useless)
- 3d played in 2d still stops somewhere in middle of movie
- will test the 3d iso tonight for sure
- audio out of sync
the player needs really much improvement
I am not seeing any artifacts or pixelations in 3D.
More Testing in Kodi
Working
3D BDMV playback in Framepacking
3D MVC MKV
3D.ISO
Not Working
Audio playback is out of sync ( Switching Audio format resolve the sync issue)
TrueHD Audio is having hard time playing in Kodi
FAUX K( If anybody know the terminology, if means FAKE 4K)
I call the 3D playback in the Zidoo X6 FAUX 3D,even though the player is player is playing in 3D Framepacking,there is not enough DEPTH in the 3D compare to my other media players,the 3D looks FLAT.
STILL TESTING
(2015-10-20, 15:14)Skank Wrote: [ -> ] (2015-10-20, 15:12)movie78 Wrote: [ -> ] (2015-10-20, 08:30)Skank Wrote: [ -> ]I didnt have time to test the 3d framepacking
- audio out of sync
Hdmkv did
I will suggest doing a factory reset on your device.
(2015-10-20, 15:25)movie78 Wrote: [ -> ] (2015-10-20, 15:14)Skank Wrote: [ -> ] (2015-10-20, 15:12)movie78 Wrote: [ -> ]I am not seeing any artifacts or pixelations in 3D.
Hdmkv did
Lol that aint changing anything
reviews confirmed artefacts too
Will do more thorough testing later today. @
movie78, nice to see 3D MVC MKV is supported; didn't expect that.
Let me ask the crazy question for troubleshooting; Have changed your HDMI cable some of this sounds like a bad cable?
