Thank you!
Which source did you use to check the color accuracy btw? TED calibration disk or AVSHD disc?
(2015-10-15, 19:01)wesk05 Wrote: [ -> ] (2015-10-15, 12:17)freebits Wrote: [ -> ]Hi Wesk05,
I own Lumagen Mini3D and DVDO TPG signal generator too. How to check the color accuracy and create such reports with them?
Thanks in advance,
freebits.
Firmware 1.03 is the one that introduced Color Checker function. You will put DVDO AVLab TPG in passthrough mode and enable the Color Checker function. You can then play reference test patterns on the device under test and move the Color Checker cursor with the remote to the image location that you need to measure.
(2015-10-16, 03:52)freebits Wrote: [ -> ]Thank you!
I use Ted's digital files.
(2015-10-16, 03:03)wrxtasy Wrote: [ -> ]What they usually fail to consider is do they actually have decent quality speakers to even hear the sounds frequencies output from the Lossless HD Audio fed into their AVR ?
Quite true!
Something else to be kept in mind is human auditory system aging. If you are 25+ more than 80% of the population won't hear above 17kHz, 40+ it is 14kHz and thus it goes.... until one day you hardly hear anything
Yep confirmed, I have my hearing tested every year for my profession and this is definitely the case with age.
A lot of people I think want those loverly bling blinken True HD and DTS MA lights to wink at them on their AVR and reassure them with smug satisfaction their AVR purchase was worth the $$ payed.
(2015-10-16, 04:50)wrxtasy Wrote: [ -> ]Yep confirmed, I have my hearing tested every year for my profession and this is definitely the case with age.
There are a few others reasons as well some people like to run "night mode/DRC" pretty sure they only work on bitstream and not PCM. In a double blind test I would not be able to tell the difference between a PCM stream and a bistream but it is nice seeing the Lights on the AVR and knowing everything is working as it should.
I did simple color checker test of Mede8er MED800X3D with DVDO TPG generator & TED patterns and found MED800X3D is color perfect!
Will do some more test with other players later. But how do you check the Delta E? Do we have any equation?
Thanks for the help
(2015-10-16, 04:17)wesk05 Wrote: [ -> ] (2015-10-16, 03:52)freebits Wrote: [ -> ]Thank you!
(2015-10-16, 01:26)movie78 Wrote: [ -> ] (2015-10-16, 01:19)langostino Wrote: [ -> ] (2015-10-15, 21:43)movie78 Wrote: [ -> ]Onkyo SR501E Doesn't even have HDMI input/output, unless you upgrade your AV Receiver,none of the things you are looking for in a media player will work with your system.
Dts and Dolby by optical spdif, no hdmi.i need optical audio out. May be I'll upgrade to a Yamaha v47x on next months.
You are looking a media player with all that features,you need replace your AVR first.
1-3D.ISO and MVC files will not work with your receiver
2-HD Audio not work
Etc...
I don't need HD Audio passthroght. I always said "DTS sound passthrogt". I just bought a Xtramer Prodigy 3d and I've got 3d. I connected it to Smart TV (LG FullHD) by HDMI entry. And to get dts soud I connected optical audio out from Prodigy to AVR optical audio entry. If I see a film with HD Audio, I listen core Audio. I'm looking for an AVR better, as Yamaha RX-V475/7/9.
(2015-10-16, 05:42)freebits Wrote: [ -> ]I did simple color checker test of Mede8er MED800X3D with DVDO TPG generator & TED patterns and found MED800X3D is color perfect!
Thanks for the help
Can Med800X3d play back mts files (mvc coded) as full 3d? Prodigy 3d has the same chipset but it playback mts files as 2d files.
I've played only full 3D ISO files on Mede8er so no idea how it'll play with single mts.
And let's focus on the players related to the topic.
(2015-10-16, 08:41)langostino Wrote: [ -> ]Can Med800X3d play back mts files (mvc coded) as full 3d? Prodigy 3d has the same chipset but it playback mts files as 2d files.
Can we please stay focus on Zidoo.
This is Zidoo thread!!!
Thank you!!
(2015-10-16, 01:23)movie78 Wrote: [ -> ] (2015-10-16, 00:22)couto27 Wrote: [ -> ] (2015-10-15, 23:17)movie78 Wrote: [ -> ]Oppo products are overpriced!!!
You can build a PC/Kodi less than the cost of their cheapest BD player.
I built a expensive HTPC a few years back, fanless power supply etc etc Sold it with a great Loss....the HTPC at the time it cost me the same money has the Oppo...
Please name one PC/graphic card/Android/Media player/whatever that outputs Native YCbCR (whithout RGB conversion) and with video Source direct output just want one product that does this- Native YCbCR + Source direct output..
Don't you want your benq with best picture quality ? so with feed him with chinese mess colors (like @wesk05 is showing with the Quantum analyser)
Or don't you want the best sound for your yamaha RX3050 (2000$) ? so why feed him with cheap boxes ?
The source is important...and more important is to us that have projectors and big screens
About Graphic cards and HTPC Lumagen forum
Quote:From madshi.net:
"Theoretically a graphics card could support output of YCbCr. Actually the best output would be a format which is as near to the native format of the Blu-Ray disc as possible to avoid any unnecessary (and lossy) conversions. The Blu-Ray disc uses YCbCr 4:2:0. HDMI and DVI do not support YCbCr 4:2:0, but YCbCr 4:2:2 and YCbCr 4:4:4 are both supported. So outputting YCbCr is possible and would be welcome. Most TVs accept both RGB and YCbCr, so there would also be no compatability problem.
However, YCbCr output makes sense only if it's a "pure" output, without a multitude of conversions in between. If the graphics card first converts the YCbCr source to RGB, then converts it back to YCbCr for output this is actually a negative thing. Ideally the graphics card should just take the YCbCr source and output it as it is.
To my best knowledge no graphics card on the market can do this today."
http://madshi.net/htpc/page4.html
Can anyone confirm ?
if it were really, with an HTPC output in YCbCr,
can be worse, because before going to Radiance the graphics card
makes a double conversion: YCbCr-->RGB-->YCbCr.
if it were really then,
is not better exit form HTPC directly in RGB, so as to eliminate a conversion ?
there is a way to verify if indeed the graphics card,
makes this double conversion or output with an "pure" YCbCr?
P.S.
Sorry for my bad English
Yes it is true that most graphics cards - if not all - perform this double conversion.
However, if the Radiance is in the chain, sending YBC422 has some advantages and often gives better results.
Also, you have to consider what's happening after the Radiance.
If the display can process an RGB signal without first converting back to YCB422, then it might make sense to keep everything in RGB.
However, most displays do convert to YCB even when inputting RGB due to the color decoder processing, which means you go RGB -> YCB -> RGB inside the display. In that case, using RGB adds one more unnecessary conversion.
The way to check for this is to see if the color control - in the display - has any effect when inputting RGB. If it does, it means that RGB is converted to YCB inside the display for processing before being converted back to RGB internally.
While there are many possibilities, it's all down to your specific combination of source/AVR/processor/display. The Radiance prefers YCB in and out, and unless your display is able to process RGB directly or gives better results that way, YCB out usually makes most sense.
To determine whether you should output RGB or YCB from the HTPC, the best way to do so is to use the Spears & Munsil disc (either version) and check the effect of each setting on the Chroma multiburst pattern, using the HTPC to play the pattern bluray.
With my AMD 7870, RGB Full works better (I lose some chroma resolution when using YCB out) and it also gives me a slightly better peak white and on/off contrast. It's also the only pixel format that works with the PC Client 3 if you want to calibrate with Calman using patterns from the HTPC, which can be more accurate if the HTPC is your primary source (which is my case).
So try various combinations and decide what works best in your setup...
If the OPPO support Kodi,then i will be all over it....
No Kodi No Good...
That is why i am in the kodi forum everyday hopping that there will be such a device.
This is zidoo topic on kodi forum
No oppo talk here please, keep on topic
(2015-10-16, 10:56)movie78 Wrote: [ -> ]Can we please stay focus on Zidoo.
Thank you!!
YES finally thank god !!!!!!!!!!
Hdmkv, are you in beta test team for new firmware for zidoo?
More impressions about 2D picture quality on Zidoo X6 compared to other famous android boxes?
(2015-10-16, 11:55)Skank Wrote: [ -> ]Hdmkv, are you in beta test team for new firmware for zidoo?
There is a beta test team? Not aware of it. I got an e-mail from Zidoo (sales guy who sent me review unit) to download and update my review (on p.16), but link was to same v1.0.16 firmware in their forum. This doesn't fix 3D ISO playback in 3D mode in Kodi (and also at frame-packed vs. HSBS mode like external player now), and it also doesn't fix lack of 23.976. Latter maybe we can live with.
Will wait until at least 3D is fixed before I re-test and update my review and make it more complete.
