(2016-12-02, 23:32)marcelveldt Wrote: [ -> ] (2016-12-02, 10:37)i0zjh02 Wrote: [ -> ]Thanks for reply Marcel I tried this already. I removed and re-added "Recent Recordings" using Widgets>Default Widgets>Skin helper Service Widgets>PVR> but I just get a spinning circle for a few seconds and then an empty list. I've tried to add other widgets from within the PVR> section and some works but most don't ie on one client the "Channels" widget works but the others don't but on a second client only the "Timers" widget is working.
I'm using ArgusTV backend PVR, not sure if thats relevant. FYI the other widgets seem OK its only the ones from the PVR> section that I'm having problems with
Can you please send me your kodi logfile ?
Or look in the logfile yourself if there are any errors listed from skinhelper service or skinhelper widgets.
Hi before i did anything else I wanted to make sure it wasnt an issue in my Kodi user profile so I renamed my Kodi folder and set it up again from scratch. I get the same error on a new install. I've pasted in my log file from launch below. hope this helps and thanks for looking Marcel
18:39:52.767 T:5396 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:39:52.767 T:5396 NOTICE: -----------------------------------------------------------------------
18:39:52.767 T:5396 NOTICE: Starting Kodi (18.0-ALPHA1 Git:20161203-5d8ef59). Platform: Windows NT x86 32-bit
18:39:52.767 T:5396 NOTICE: Using Release Kodi x32 build
18:39:52.768 T:5396 NOTICE: Kodi compiled Dec 3 2016 by MSVC 190024210 for Windows NT x86 32-bit version 6.3 (0x06030000)
18:39:52.768 T:5396 NOTICE: Running on Dell Inc. Latitude E7440 with Windows 10, kernel: Windows NT x86 64-bit version 10.0
18:39:52.768 T:5396 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
18:39:52.768 T:5396 NOTICE: Host CPU: Unknown, 4 cores available
18:39:52.768 T:5396 NOTICE: Desktop Resolution: 1366x768 32Bit at 60Hz
18:39:52.768 T:5396 NOTICE: Running with restricted rights
18:39:52.769 T:5396 NOTICE: Aero is enabled
18:39:52.769 T:5396 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
18:39:52.769 T:5396 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
18:39:52.769 T:5396 NOTICE: special://xbmcbinaddons/ is mapped to: C:\Program Files (x86)\Kodi/addons
18:39:52.769 T:5396 NOTICE: special://masterprofile/ is mapped to: C:\Users\Home User\AppData\Roaming\Kodi\userdata
18:39:52.769 T:5396 NOTICE: special://home/ is mapped to: C:\Users\Home User\AppData\Roaming\Kodi\
18:39:52.769 T:5396 NOTICE: special://temp/ is mapped to: C:\Users\Home User\AppData\Roaming\Kodi\cache
18:39:52.769 T:5396 NOTICE: special://logpath/ is mapped to: C:\Users\Home User\AppData\Roaming\Kodi\
18:39:52.769 T:5396 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\kodi.exe
18:39:52.772 T:5396 NOTICE: Local hostname: Buckley-E7440-1
18:39:52.772 T:5396 NOTICE: Log File is located: C:\Users\Home User\AppData\Roaming\Kodi\/kodi.log
18:39:52.772 T:5396 NOTICE: -----------------------------------------------------------------------
18:39:52.775 T:5396 NOTICE: load settings...
18:39:52.782 T:5396 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
18:39:52.782 T:5396 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
18:39:52.786 T:5396 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
18:39:52.786 T:5396 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
18:39:52.786 T:5396 NOTICE: Default Video Player: VideoPlayer
18:39:52.786 T:5396 NOTICE: Default Audio Player: paplayer
18:39:52.786 T:5396 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:39:52.786 T:5396 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
18:39:52.786 T:5396 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
18:39:52.787 T:5396 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:39:52.788 T:5396 NOTICE: Loaded playercorefactory configuration
18:39:52.788 T:5396 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:39:52.788 T:5396 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:39:52.795 T:5396 NOTICE: Running database version Addons26
18:39:52.857 T:5396 NOTICE: ADDONS: Using repository repository.xbmc.org
18:39:52.857 T:5396 NOTICE: ADDONS: Using repository repository.beta.emby.kodi
18:39:52.857 T:5396 NOTICE: ADDONS: Using repository repository.marcelveldt
18:39:52.905 T:7400 NOTICE: Found 2 Lists of Devices
18:39:52.905 T:7400 NOTICE: Enumerated DIRECTSOUND devices:
18:39:52.905 T:7400 NOTICE: Device 1
18:39:52.905 T:7400 NOTICE: m_deviceName : {502D7C2C-32B2-4637-8CD5-FFE10E20F69D}
18:39:52.905 T:7400 NOTICE: m_displayName : Speakers - Speakers / Headphones (Realtek High Definition Audio)
18:39:52.905 T:7400 NOTICE: m_displayNameExtra: DIRECTSOUND: Speakers / Headphones (Realtek High Definition Audio)
18:39:52.905 T:7400 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:39:52.905 T:7400 NOTICE: m_channels : FL,FR
18:39:52.905 T:7400 NOTICE: m_sampleRates : 48000
18:39:52.905 T:7400 NOTICE: m_dataFormats : AE_FMT_FLOAT
18:39:52.905 T:7400 NOTICE: m_streamTypes : No passthrough capabilities
18:39:52.905 T:7400 NOTICE: Device 2
18:39:52.905 T:7400 NOTICE: m_deviceName : default
18:39:52.905 T:7400 NOTICE: m_displayName : default
18:39:52.905 T:7400 NOTICE: Enumerated WASAPI devices:
18:39:52.905 T:7400 NOTICE: m_displayNameExtra: WASAPI: Speakers / Headphones (Realtek High Definition Audio)
18:39:52.905 T:7400 NOTICE: m_sampleRates : 192000,96000,48000,44100
18:39:52.905 T:7400 NOTICE: m_dataFormats : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
18:39:52.959 T:5396 NOTICE: Found screen: Generic PnP Monitor on Intel® HD Graphics Family, adapter 0.
18:39:52.959 T:5396 NOTICE: Primary mode: 1366x768@ 60.00 - Full Screen
18:39:52.960 T:5396 NOTICE: Additional mode: 320x200@ 40.00 - Full Screen
18:39:52.960 T:5396 NOTICE: Previous line repeats 2 times.
18:39:52.960 T:5396 NOTICE: Additional mode: 320x200@ 60.00 - Full Screen
18:39:52.961 T:5396 NOTICE: Previous line repeats 2 times.
18:39:52.961 T:5396 NOTICE: Additional mode: 320x240@ 40.00 - Full Screen
18:39:52.961 T:5396 NOTICE: Additional mode: 320x240@ 60.00 - Full Screen
18:39:52.961 T:5396 NOTICE: Additional mode: 400x300@ 40.00 - Full Screen
18:39:52.962 T:5396 NOTICE: Previous line repeats 2 times.
18:39:52.962 T:5396 NOTICE: Additional mode: 400x300@ 60.00 - Full Screen
18:39:52.962 T:5396 NOTICE: Additional mode: 512x384@ 40.00 - Full Screen
18:39:52.962 T:5396 NOTICE: Additional mode: 512x384@ 60.00 - Full Screen
18:39:52.963 T:5396 NOTICE: Previous line repeats 2 times.
18:39:52.963 T:5396 NOTICE: Additional mode: 640x400@ 40.00 - Full Screen
18:39:52.963 T:5396 NOTICE: Additional mode: 640x400@ 60.00 - Full Screen
18:39:52.963 T:5396 NOTICE: Additional mode: 640x480@ 40.00 - Full Screen
18:39:52.964 T:5396 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
18:39:52.964 T:5396 NOTICE: Previous line repeats 2 times.
18:39:52.964 T:5396 NOTICE: Additional mode: 800x600@ 40.00 - Full Screen
18:39:52.964 T:5396 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
18:39:52.964 T:5396 NOTICE: Additional mode: 1024x768@ 40.00 - Full Screen
18:39:52.965 T:5396 NOTICE: Previous line repeats 2 times.
18:39:52.965 T:5396 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
18:39:52.965 T:5396 NOTICE: Additional mode: 1280x720@ 40.00 - Full Screen
18:39:52.965 T:5396 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
18:39:52.966 T:5396 NOTICE: Previous line repeats 2 times.
18:39:52.966 T:5396 NOTICE: Additional mode: 1280x768@ 40.00 - Full Screen
18:39:52.966 T:5396 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
18:39:52.966 T:5396 NOTICE: Additional mode: 1360x768@ 40.00 - Full Screen
18:39:52.967 T:5396 NOTICE: Previous line repeats 2 times.
18:39:52.967 T:5396 NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
18:39:52.967 T:5396 NOTICE: Additional mode: 1366x768@ 40.00 - Full Screen
18:39:52.967 T:5396 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
18:39:52.967 T:5396 NOTICE: Checking resolution 16
18:39:53.169 T:5396 NOTICE: PERIPHERALS::CPeripheralBus::Register - new joystickemulation device registered on application->1: Keyboard player (0000:0000)
18:39:53.175 T:5744 NOTICE: Running database version Addons26
18:39:53.176 T:5744 NOTICE: Running database version ViewModes6
18:39:53.177 T:5744 NOTICE: Running database version Textures13
18:39:53.179 T:5744 NOTICE: Running database version MyMusic60
18:39:53.181 T:5744 NOTICE: Running database version MyVideos107
18:39:53.183 T:5744 NOTICE: Running database version TV29
18:39:53.184 T:5744 NOTICE: Running database version Epg11
18:39:53.658 T:5396 ERROR: Window Translator: Can't find window mutebug
18:39:53.666 T:5396 ERROR: Window Translator: Can't find window infodialog
18:39:53.724 T:5396 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
18:39:53.759 T:5396 WARNING: CApplication::Initialize - startup.xml taints init process
18:39:53.781 T:5396 NOTICE: initialize done
18:39:53.781 T:5396 NOTICE: Running the application...
18:39:53.806 T:5744 WARNING: PVR::CPVRClient::GetAddonProperties - Addon ARGUS TV (10.15.21.50):http://10.15.21.50:49943/ does not support timer types. It will work, but not benefit from the timer features introduced with PVR Addon API 2.0.0
18:39:53.862 T:5396 WARNING: Trying to add unsupported control type 1
18:39:54.047 T:5396 WARNING: Previous line repeats 26 times.
18:39:54.047 T:5396 NOTICE: starting upnp client
18:39:54.048 T:5396 NOTICE: Platinum [platinum.core.upnp]: Starting UPnP...
18:39:54.049 T:5396 NOTICE: Platinum [platinum.core.upnp]: Starting Ctrlpoint...
18:39:54.049 T:5396 NOTICE: Platinum [platinum.core.http.server]: HttpServer listening on 0.0.0.0:1777
18:39:54.051 T:3508 NOTICE: ES: Starting UDP Event server on port 9777
18:39:54.051 T:3508 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
18:39:54.057 T:4724 NOTICE: Platinum [platinum.core.ctrlpoint]: Inspecting device "40206c34-041e-abd4-86a3-c16cae7fdf97" detected @
http://10.15.21.55:1478/
18:39:54.086 T:4724 NOTICE: Platinum [platinum.core.ctrlpoint]: Inspecting device "08f0d182-0096-1000-82d5-244b035790c3" detected @
http://10.15.21.73:7676/smp_21_
18:39:54.087 T:4724 NOTICE: Platinum [platinum.core.ctrlpoint]: Inspecting device "08f0d181-0096-1000-8d84-244b035790c3" detected @
http://10.15.21.73:7676/smp_11_
18:39:54.088 T:4724 NOTICE: Platinum [platinum.core.ctrlpoint]: Inspecting device "08f0d180-0096-1000-911b-244b035790c3" detected @
http://10.15.21.73:7676/smp_3_
18:39:54.152 T:4724 NOTICE: Platinum [platinum.core.ctrlpoint]: Inspecting device "24e47792-9b78-11e6-9a37-c40415fadf19" detected @
http://10.15.21.1:1900/rootDesc.xml
18:39:54.563 T:7924 NOTICE: Platinum [platinum.core.ctrlpoint]: Device "40206c34-041e-abd4-86a3-c16cae7fdf97" is now known as "Kodi_Lounge" (
http://10.15.21.55:1478/)
18:39:54.661 T:5748 NOTICE: Platinum [platinum.core.ctrlpoint]: Device "24e47792-9b78-11e6-9a37-c40415fadf19" is now known as "VMDG485" (
http://10.15.21.1:1900/rootDesc.xml)
18:39:54.700 T:1632 NOTICE: Platinum [platinum.core.ctrlpoint]: Device "08f0d182-0096-1000-82d5-244b035790c3" is now known as "[LFD]Buckley-Samsung" (
http://10.15.21.73:7676/smp_21_)
18:39:54.805 T:3304 NOTICE: Platinum [platinum.core.ctrlpoint]: Device "08f0d181-0096-1000-8d84-244b035790c3" is now known as "[LFD]Buckley-Samsung" (
http://10.15.21.73:7676/smp_11_)
18:39:54.883 T:2016 NOTICE: Platinum [platinum.core.ctrlpoint]: Device "08f0d180-0096-1000-911b-244b035790c3" is now known as "[LFD]Buckley-Samsung" (
http://10.15.21.73:7676/smp_3_)
18:39:54.967 T:5160 NOTICE: Skin Helper Backgrounds --> BackgroundsUpdater - started
18:39:55.279 T:4724 NOTICE: Platinum [platinum.core.ctrlpoint]: Inspecting device "c0225400-d8a9-5078-9dbb-88618232e522" detected @
http://10.15.21.1:49152/wps_device.xml
18:39:55.788 T:6812 NOTICE: Platinum [platinum.core.ctrlpoint]: Device "c0225400-d8a9-5078-9dbb-88618232e522" is now known as "WPS Access Point" (
http://10.15.21.1:49152/wps_device.xml)
18:39:55.859 T:980 WARNING: CPVRRecording::CPVRRecording - unable to determine channel type. Defaulting to TV.
18:39:56.062 T:4724 WARNING: Previous line repeats 41 times.
18:39:56.062 T:4724 NOTICE: Platinum [platinum.core.ctrlpoint]: Inspecting device "9563e5aa-24cc-2e5e-687b-83df914507b3" detected @
http://10.15.21.55:1413/DeviceDescription.xml
18:39:56.070 T:980 WARNING: CPVRRecording::CPVRRecording - unable to determine channel type. Defaulting to TV.
18:39:56.582 T:8592 WARNING: Previous line repeats 17 times.
18:39:56.582 T:8592 NOTICE: Platinum [platinum.core.ctrlpoint]: Device "9563e5aa-24cc-2e5e-687b-83df914507b3" is now known as "Kodi_Lounge" (
http://10.15.21.55:1413/DeviceDescription.xml)
18:39:56.698 T:8496 NOTICE: Platinum [platinum.core.ctrlpoint]: Subscribing to service "urn:upnp-org
erviceId:ContentDirectory" of device "Kodi_Lounge"
erviceId:ConnectionManager" of device "Kodi_Lounge"
18:39:56.703 T:1600 NOTICE: Platinum [platinum.core.ctrlpoint]: Creating new subscriber "uuid:2b52b02b-131a-8fff-0e74-f6bcb819db01" for service "urn:upnp-org
erviceId:ContentDirectory" of device "Kodi_Lounge" (timeout = 1800)
18:39:56.710 T:1540 NOTICE: Platinum [platinum.core.ctrlpoint]: Creating new subscriber "uuid:461cbb2a-c516-99d6-100a-f5341f77b010" for service "urn:upnp-org
erviceId:ConnectionManager" of device "Kodi_Lounge" (timeout = 1800)
18:39:57.354 T:1684 NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
18:39:57.354 T:6704 NOTICE: Skin Helper Service --> Skin Helper Service version 1.0.131 started
18:40:08.551 T:6564 NOTICE: EPG::CEpgContainer::Start - EPG thread started
18:40:16.160 T:5128 WARNING: Invalid media type "channel"
