(2017-04-22, 17:42)Hennes105 Wrote: [ -> ]Quick question from a Newbee. In Estuary there is button for YouTube Trailers for TV Recordings and when selecting a Show out of the Programme Guide. Will you implement this also in Titan Skin? If yes, can you already indicate by when you will implent this?
This was actually a quick fix so it will be available in tonight's next beta version of the skin.
(2017-04-22, 18:34)Boulder Wrote: [ -> ] (2017-04-22, 14:25)marcelveldt Wrote: [ -> ] (2017-04-08, 20:14)Boulder Wrote: [ -> ]The "stars" shown for albums probably expects a scale of 1-10 for points but it seems that the official Kodi album scraper gets points of scale 1-5. Most of the albums in my library have 3-4 points so they have only 1-2 stars in the preview
That is strange... Kodi switched to 1-10 rating scale since Kodi Krypton. Maybe this is an issue when you migrated from Kodi 16 to Kodi 17 ?
Is there any way to debug this one?
Just scan your library frsh into Kodi instead of migrating it from a previous version.
Also I'd like to know if this issue exists in only the OSD and/or the media view ?
(2017-04-22, 19:44)jardine1982 Wrote: [ -> ]Hi all, I love this skin! Was wondering if I could stop the widgets reloading after I have watched something and then go back into the main menu. Thanks in advance
The reloading is there for a reason: If you watch something you'd like the widget to represent any changes.
For example to have a watched flag on something you watched or the percentage-watched indication...
The reload should only take 1-2 seconds for the library widgets.
(2017-04-23, 01:06)WayWayAfar Wrote: [ -> ]How do i get the thumbnails to show the picture? Is there a setting I'm unable to locate?
Please explain in a bit more detail what you mean of provide a screenshot to illustrate...
(2017-04-23, 11:17)Dion250 Wrote: [ -> ]The Slim OSD does not scale tall poster art properly sometimes. Most of the time it scales to the none slim one ( default one )
I'm not sure I understand what you mean... Can you please provide a screenshot of the issue ?
(2017-04-23, 11:17)Dion250 Wrote: [ -> ]Is there a way to disable the star ratings in the bottom right on the screen on the footer bar?
Yes, in the skin settings you can choose to show the studio logo or alternative ratings instead of the star tarings.
(2017-04-23, 12:33)nick_l Wrote: [ -> ]He is saying that when certain dialog boxes pop up, for instance, "Backup created successfully", the "Ok" button doesn't have focus and Is therefore impossible to click. The only way to dismiss the dialog is to use "back".
Hope that helps. Thanks for the great skin, btw.
Thanks for the additional info. I was able to track down the issue. Should be fixed in next beta update.
(2017-04-23, 14:28)Morphy99 Wrote: [ -> ]I'm a bit concerned about this in my log:
13:21:57.169 T:1384 NOTICE: EMBY.default -> plugin.video.emby started
13:21:57.170 T:1384 NOTICE: EMBY.default -> Parameter string: ?id=tv&mode=nextup&limit=25
13:22:00.561 T:1384 NOTICE: EMBY.default -> plugin.video.emby stopped
13:22:00.886 T:1384 WARNING: CPythonInvoker(34, C:\Users\Kodi\AppData\Roaming\Kodi\addons\plugin.video.emby\default.py): the python script "C:\Users\Kodi\AppData\Roaming\Kodi\addons\plugin.video.emby\default.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcaddon::Addon
I'm suffering from some performance issues so I'm wondering if this is the problem. I know it refers to Emby however this error doesn't occur with estuary skin. I'm wondering if its to do with emby smart playlists?
Those are indeed related to the plugin entries from the emby plugin.
Altough it shouldn't cause any serious issues it should be fixed. If I have some time left next week I'll take a look at it, shouldn't be hard to fix.
(2017-04-23, 20:08)marcelveldt Wrote: [ -> ] (2017-04-21, 18:51)spinecho Wrote: [ -> ]show OSD on start of playback time is default 4 seconds. I personally do not like this feature and so I change it to 0 for no OSD. However, upon restart of Kodi, it defaults back to 4 seconds. V annoying!
EDIT:
I see someone has already reported this
The issue will be fixed in the next beta update of the skin, I hope to supply this tonight.
(2017-04-21, 18:51)spinecho Wrote: [ -> ]Also Marcel, any update on "fixed list" for Showcase view?
You mean a non-wrapping showcase view ?
Well, I had a quick peek at the code but that's not an easy change as the layout is currently build up with wrapping.
It will be an awfull lot of work to change that. Maybe you should look at the poster Row view which is like showcase but without wrapping ?
Thanks for your work on this, marcelveldt!!!
Sent from my Nexus 7
(2017-04-23, 17:24)4kinghellll Wrote: [ -> ]I changed the studio icons to WHITE today and they work on TV shows but not working for COLOR icons, also is it possible for movie studio icons?
Not all studio logos are available in color. Have a look at the studio logos resource addon on Github to see which images are in there.
The resource addon for the studio logos you select, should be used for both movies and tvshows
In the beta under Edit menu shortcuts / Music / Select background/ custom multi image folder
The fanart folder I've selected is not rotating properly. When it does rotate it's not in random order. Not sure if it's code or my system. Not sure if I need to make adjustments to skin helper.
(2017-04-23, 23:44)marcelveldt Wrote: [ -> ] (2017-04-23, 17:24)4kinghellll Wrote: [ -> ]I changed the studio icons to WHITE today and they work on TV shows but not working for COLOR icons, also is it possible for movie studio icons?
Thanks i reinstalled the color icons and now working great for TV shows but still no icons for movies, the white and color work on TV shows but nothing for movies?
(2017-04-23, 20:29)marcelveldt Wrote: [ -> ] (2017-04-22, 19:44)jardine1982 Wrote: [ -> ]Hi all, I love this skin! Was wondering if I could stop the widgets reloading after I have watched something and then go back into the main menu. Thanks in advance
Ok thank you. Keep up the excellent work!!
(2017-04-24, 02:33)Tennyten Wrote: [ -> ]In the beta under Edit menu shortcuts / Music / Select background/ custom multi image folder
Skin settings --> Background settings --> Randomize images --> enable
(2017-04-24, 04:36)4kinghellll Wrote: [ -> ]Thanks i reinstalled the color icons and now working great for TV shows but still no icons for movies, the white and color work on TV shows but nothing for movies?
Like I said, studio logos are enabled/available for both movies and tv shows as long as the studio name is scraped to your kodi db offcourse.
So, the question is do you have your studios scraped into the Kodi db ? Or are you using some banned addon to watch content ?
(2017-04-23, 14:23)marcelveldt Wrote: [ -> ] (2017-04-13, 17:37)mattyspurs76 Wrote: [ -> ]Anyway, all setup how I usually like but every so often the widgets go transparent on the home pages.
I can just about make out what's what.if I press up and go into the widgets the background images change ok and info pops up to but actual widget itself is transparent.
A widget goes transparant when it's refreshing it's contents. At the same time there should also be a busy spinner displayed to indicate that it's doing work. The refresh should only take little time btw.
A few questions for you:
1) Do you see the busy spinner when the widget is transparent ?
2) Will the widget return to full opacity again after a specific amount of time (a few seconds) ?
3) Which homelayout are you using ?
Sorry, just seen the post.
1/ Not all the time.
2/ Takes alot longer than 20 seconds (at least) but by then ive usually just gone into the addon itself.
3/ Horizontal/Confluence low layout.
Just seen the new update so ill try this out and get back to you.
Tbh i had it all setup great on my windows PC but im now using an android tv box so that could be one main reason for it to slow down as i probably do have all the bells and whistles with this skin
